Question about Dometic RM2652 Refrigerator
When refrigerator is turned on, gfci above kitchen sink trips
    Problem Solver:
  • 13 Answers
Refrigerator can not be plugged in to gfi due to load on compressor start up could draw up to 15 to 20 amps for a split second on start up and pop gfi
Posted on Aug 27, 2010
Keeps popping DMI immediately when it is plugged in its a refridgerator
Refrigerators need to be plugged into a regular outlet without anything else plugged in. DMI's, GFI's, or GFCI's are designed to trip at the slightest increase in amp draw. When the compressor turns on the outlet senses the spike and trips the curcuit. So to fix the fridge plug it into another outlet that is not part of the dmi circuit.
Nov 02, 2016 | Frigidaire Kitchen Ranges
GFCI wont reset, or, runs for 5 minutes and shuts off
Refrigerators should not be plugged into a GFCI outlet. The surge of current when the compressor starts up will trip the GFCI.
Apr 18, 2015 | Refrigerators
Tripping gfci
I don't know what kind of warmer you are referring to. If you are trying to run to many appliances off of the same circuit the gfci will trip. The gfci could be warn out or defective. If the warmer is drawing lots of amps or has a short that will also trip the gfci
Dec 31, 2013 | Nemco Countertop Food Warmer 6055A
Hoover Refrigerator Model B38tf. Causes earth leakage circuit breaker to trip. Has just started to occur in last week. What is likely cause and what rectification can be applied?
If you're referring to a GFCI (Ground Fault Circuit Interrupter) breaker tripping, a refrigerator should not be plugged into a GFCI circuit because of the sudden load it requires to start the compressor, etc when it kicks on. The GFCI breakers are meant to be very sensitive, and over time the sudden energy demands caused by a refrigerator can weaken the breaker's threshold, causing them to trip often. Try connecting the refrigerator to another circuit that isn't on a GFCI breaker. If there are no other circuits nearby, you may wish to replace the GFCI breaker with a standard breaker, and replace the receptacles with GFCI receptacles, except of course, the one the refrigerator is plugged into. Be sure and consult and use a qualified electrician for this. Hope this helps..
Oct 29, 2013 | Refrigerators
REFRIGERATOR KEEPS TRIPPING THE GFCI OUTLET
A GFCI detects shorts in an electrical system and isolates power to prevent that device from harming other components upstream. GFCI's do go bad so that possibility exists. However, I would recommend trying to plug in your refrigerator into another outlet in your kitchen that has a different GFCI plug. If it does not trip then the GFCI needs to be replaced. If you do not have another available GFCI outlet and you plug it into a regular outlet, your breaker for that service line MAY trip. Better off testing with another GFCI. If your second GFCI trips, then the problem is with your refrigerator...meaning you have a short in your refrigerator. If you think this is something you can troubleshoot...BE CAREFUL!!! Always unplug your refrigerator before going into the components of the refrigerator. One thing you can do is turn both the freezer and refrigerator temperatures OFF or to their lowest setting. Plug your refrigerator in and see if the GFCI trips. If it trips you have a major short...probably in the bottom of the refrigerator. If it does not trip, turn the freezer temperature on first and see if it will run without tripping the GFCI. If it runs, then turn the freezer temp OFF. Then repeat the process testing the refrigerator components. Ice makers have been known to generate shorts in the system as well. There are various ways to troubleshoot a fridge. If you do not have the required electrical troubleshooting skills then PLEASE call a service technician.
Nov 30, 2017 | Jenn-Air Refrigerators
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GFCI on refrigerator circuit cuts off.
Yes. Refrigerators should not be on gfci protected circuits. They should have a dedicated 120v circuit .If your kitchen is new enough to be wired with gfci breakers ,it should also have an outlet dedicated for the refrigerator.
Dec 05, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Hotpoint 1 and one-half yrs old stopped working
Ck and make sure the circuit breaker on the power panel on the house hasn't tripped.. If your microwave is within 6' of the kitchen sink, ck for a tripped GFCI controlling the power the microwave is plugged into. Good Luck, Ned
Sep 15, 2009 | Microwave Ovens
Keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
Aug 09, 2009 | Bunn NHB Coffee Maker
Gfci trips.it protects 4 receptacles downstram from it.If I disconnect from downstream receptacles it will not trip.This is on kitchen counter-top circuit.All wiring and devices are only 6 months...
There can be a few different reason for a trip. 1. Amps exceed rating off GFCI ie 15 amp receptacle can only handle up to 15 amp anymore and it will trip. 2. miss wiring; neutral must be on white screws hot on black and ground, green also inlet power (line) must be on bottom screws, outlet or load must be on top 3, a short, whether it be neutral or hot touching something in the box. Frayed wire, wire next to side of interior of box or yes moisture. Also a short in an appliance aven a new one can cause a trip. Remember if the refrigerator is on this same circuit, which is not a good idea it can cause a trip. At start up the fridge can spike to near 15 amps and a voltage spike can cause a gfci to trip. There are 20amp GFCI's so that can be your last resort, if all else fails.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Jan 17, 2009 | Sharp 13K-M100 13" TV
Dometic RM2652 Refrigerator Logo
63 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
