Question about HP Photosmart C7280 Laser Printer
HP Photosmart C7280 all in one scanner failure unabke to scan or print but can print from computer I think it is the scanner arm
SOURCE: C4480 cannot scan to pc
I can not scan from my printer to my pc. I have a hp c4480. everything works on it. bill
Posted on Aug 06, 2009
  • 1684 Answers
SOURCE: Ink System Failure: Errow:Oxc18a001 with a HP C7280
Check our web site at: www.ccl-la.com/hp.htm We have a step by step guide to correct this problem. This error is caused by air in the ink feed tubes and the guide will help you do a purge on the lines.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 19, 2009
Testimonial: "Thanks a million!!!!. Saved the day. Instructions were on point... Reply was timely. THANKS."
  • 23 Answers
SOURCE: Copying and scanning don't work but produce all-black image
please clean the scanning glass and also the feeder.
Open the machine check if any paper has struck anywhere inside.
In most of issues it will work, if this does not works call your technician to troubleshoot the problem
Posted on Jan 13, 2010
nirikip
  • 56 Answers
SOURCE: HP Photosmart C7280 color ink running out despite not using it?
  1. Unplug power cable while the printer is ON.
  2. Press and hold the '#' and '3' buttons, and plug the cable back into the printer.
  3. Continue holding the buttons down for 20 seconds, and then release it.
if doesn't initialize successfully repeat
on step 2 press and hold the '#' and '6' button and plug in the power cable.
Posted on May 13, 2010
  • 30 Answers
SOURCE: How do i repair: hp Photosmart C7280 Printer ink
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Posted on Jul 26, 2010
Can not scan to mac computer from hp c7280. What should I do? I need to know how to scan hp c7280 to my imac computer. I receive the message "refer to device documentation to troubleshoot." ...
There are multiple ways to use the scanner on your Mac. If your Mac recognizes the scanner as a device, then you can use the scan from the Mac using Preview or Image Capture apps (in your Applications folder). You can also use Picasa by going to the import function and finding the scanner and try it from there. If you are having issues getting the HP scanner to recognize the Apple device. Here is the official website for the download from HP. Apple drivers sometimes do the job of getting the scanner to be recognized, but the official drivers might do better.
Mar 02, 2011 | HP Photosmart C7280 Printer
Scanner failure-Hp c7280
make sure to go to hp.com and install all the correct drivers for that system
Jul 21, 2009 | HP Photosmart C7280 Printer
Can not scan to my computer
Scanning thru a wireless connection is not supported on these printers. Printing does not require that much data to be sent back to the computer, scanning of course does. Printers require a bi-directional signal path to allow scanning such as USB and parallel ports. Sorry to be the barer of bad news.
Buddy
Corporate Computer
Over 21 years supporting/repairing PCs and printers
Jun 18, 2009 | HP Photosmart C7280 Laser Printer
How do I scan photos to my HP from my Photosmart c7280?
you can scan from paint, use file, from scanner or camera then you can save it as a jpeg
to find paint go to start/programs/accessories then paint
Apr 28, 2009 | HP Photosmart C7280 Laser Printer
Can't scan to computer
I am not an expert, only a c7280 user. I use my printer wirelessly and was having problem scanning when using the controls directly on the printer (scan menu). By trial and error, I tried scanning by going to HP solution center on my computer and just followed the directions from the scan menu. That worked. If you can print wirelessly, you can scan wirelessly. I agree the HP support is a huge waste of time. I only get mad talking to them.
Apr 16, 2009 | HP Photosmart C7280 Printer
Should be in the HP print centre software on your computer
Apr 13, 2009 | HP Photosmart C7280 Printer
I cannot scan onto my HP c7280, but I can print to it. It connects via cat5 to switch. I cannot 'locate' the scanner.
check for the scanner drivers in the control panel,if they are there...if not you will have to reinstall the scanner drivers on your computer.use the s/w cd that came with the printer and install it all over again..then try scanning from the windows photo gallery or the MS paint and word.These do not use the twain drivers ,they use the windows scanner drivers....see if it works
Mar 12, 2009 | HP Photosmart C7280 Laser Printer
populate the destination list in the solution centre software and selet the appropriate destination....if it still does not work.
you will have to uninstall the scanner drivers from the computer in the control panel>scanners..then uninstall the printer drivers from the orinter in the control paneland then tryy reinstalling the drivers and the s/w using the disc that came with the printer...see if works
Jan 19, 2009 | HP Photosmart C7280 Printer
My C7280 HP photosmart will not scan to my computer.  I get the message "no scan options"
I have had a similar problem that appeared soon after an automatic HP software update over the internet. I solved the problem by uninstalling and reinstalling the HP software that came with the CD. I inserted the CD and ran the de-install for only the program that controlled print and scan and then re-installed the software for print and scan. Straight afterwards, the scanning started to work again
Dec 15, 2008 | HP Photosmart C7280 Laser Printer
HP Photosmart C7280 Laser Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
