Question about Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs
Scotsman ice machine CME 1056RS\r\nThe bin full light on the controler stays on and shut off the machine I clean the lenses on the sensor Check the bin control it is open Not to long ago I have replace this sensor and the control
  • 4 Answers
Change the board and eyes at the same time.
Posted on Nov 29, 2010
    Problem Solver:
  • 13 Answers
The sensors dont see eachother that is the problem
Posted on Aug 27, 2010
Bin full light stays on
You need to pull the bin full sensors and clean or replace them. Pull the front cover off remove the ice deflector you will see the water sump tray pull the ice deflector grate out of sump. Now where the ice fall into the bin on the right and left side in the shout there is 2 sensors they will pull out sideways, they will both have a wire ran to them pull wire and sensor up to where you can see the red sensors om them take a descale solution Scotsman brand mix per instructions and clean the eyes now would be a good time to clean and disinfect the whole machine. Install them back and start machine if this dose not clear the bin full light then replace them.
Jan 16, 2014 | Scotsman Cooled Modular Contour Cuber...
Scotsman cme 1656 bill full stay on after cleaning
Ok did you damage the bin thermostat cap tube? The bin thermostat is what tells the unit the bin is full if so replace it.
Nov 14, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Cme256 scotsman
Remove and clean or replace the bin control sensors ( set of two ) part number 11-0540-21. Most of the time you can remove them and clean the little lights and this will do.
Jun 27, 2013 | Kitchen Appliances - Others
MV450 Scotsman Ice machine
1. bin full when bin is empty means that the bin control sensor is dirty or need to be replaced. But since your having problems with water over flowing also i would bet that your machine needs a good cleaning. is you water full light on or off? if off and water sump try is full then you need to pull water sensor out and clean or replace it. if water sensor light is on then you need to replace water inlet valve.
Jun 26, 2013 | Kitchen Appliances - Others
Scotsman cme 506ae-1a harvest to soon. Where is the adjustment timer the harvest is also too long?
The water float rod in front of the unit serves as the fill stop as well as the harvest initiate. Difficult to remove to clean really well but not impossible. Harvest time is handled by the controller. First two or three harvests are long as the controller times out the harvests based on the blinking light of the bin full indication. After that is should get shorter.
Jul 04, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My binsensor lingh is on but my bin is not full so my ice machine
I see you already said you bin sensor light was on. The drop door has a metal tab that waves over a sensor as it opens, if that part when it closes does not tell the board that door is shut the the board thinks the bin is full. I know you already know that but until I can talk to Scotsman on the phone or review their service manual for your model. One good thing about Scotsman is they are very helpful to their customers. Unless the machine is obsolete.
Apr 23, 2009 | Scotsman Ice Machine, Cuber, 1930 lb....
Scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Jul 17, 2008 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman Cooled Modular Contour Cuber Air Condensed 975lbs Logo
991 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
