Question about Samsung SyncMaster 931B 19" LCD Monitor
I have a samsung 19" LCD 931BW. Problem is- When i turn on the pc, nothing displays on the monitor though the CPU already is booted. After several CPU resets, there is already display. I think the monitor needs to be warmed up first as it doesn't display immediately.
  • 11,361 Answers
<P>You may have dying power supply due to bad DC filter caps, that would be my first thing to look at.</P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">If you are going to DIY and have proper tools and know safety precaution then please read on:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: <A rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums"><FONT color=#800080>http://s807.photobucket.com/home/budm/allalbums</FONT></A><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Post back what you see inside so we can guide you further and it will help out other people in the future also.<o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><A rel='nofollow' href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</A><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">Capacitors kit: <A rel='nofollow' href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</A> he can make you a set of caps for you.</SPAN></P>
Posted on Aug 27, 2010
I have problem with my monitor LCD 931 BW. after turn on the monitor,the monitor display windows but after 4 5 seconds,the monitor will black.but the power at the button is turn on, whats the problem...
You need to try it with another PC first to make sure it is not PC problem, most failures in monitors are due to bad caps as you can see the failed SAMSUNG albums.
Please read my guide and look at the albums so you will have more understanding if it turns out to be the monitor problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 10, 2011 | Samsung 19" LCD Syncmaster 931BW Monitor
When i turn on my lcd samsung syncmaster 540n it displayed a lot of colored vertical and horizontal lines.no video when i attached my cpu but it turns on when i powered my cpu
boot up in safe mode (press f8 while booting) If your monitor works now, you need to go the the samsung site and download the driver for you monitor. I assume windows 7, since that is where most of the monitor problem occur.
Mar 08, 2011 | Samsung SyncMaster 540N 15" LCD Monitor
Samsung 19 "LCD SyncMaster 931BW ...Colored
Hook a spare monitor to the computer to insure there is no problem, if everything checks out okay,the problem is in the Samsung screen display and is not cost effective to repair, far cheaper to buy new. But if both screens show the same problem, it is a video graphics card issue in the computer, one further thing if the video cord is detachable from both ends, sub another cord.
Feb 04, 2011 | Samsung 19" LCD Syncmaster 931BW Monitor
My Synchmaster 931BW LCD takes a long time to turn on and it appears to be increase everytime I turn it off, once I turn on my computer the monitor light keeps flashing but does not display image, after a...
Typical symptom of dying power supply due to bad caps with domed tops as you can see in my SAMSUNG albums. Make sure to replace them in a set.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Jan 25, 2011 | Samsung 19" LCD Syncmaster 931BW Monitor
My syncmaster 931bw driver blue light is flickering and will not turn on
If it does the same when attached to another PC, then you will have to open it up and troubleshoot it.
Please read below first:
Jan 13, 2011 | Samsung 19" LCD Syncmaster 931BW Monitor
My Samsung SyncMaster 931BW monitor has been working fine for me. It was working fine last night turn it back on this morning and the screen is just black. Reset computer checked the cords and power outlet...
Try it with another PC to make sure is is not the PC video card problem, also chek the cable. If it still does not work, then you will have to open it up.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Oct 05, 2010 | Samsung 19" LCD Syncmaster 931BW Monitor
Monitor don't start with start of PC.
Replace the electrolytic capacitors on the power supply board.
Some will have bulged, but it'll be a good idea to replace all of them
May 15, 2010 | Samsung 19" LCD Syncmaster 931BW Monitor
I have Samsung LCD 931BW and it seems to be in sleep mode but cant get out of it pressing buttons ...al rewired cables, another computer
Not likely to be sleeping but the failure in the power supply due to bad caps (bulging, leaking), very common in ALL LCD monitors. If you are going to DIY repair, please read below and look through my albums so you will know what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 21, 2010 | Samsung 19" LCD Syncmaster 931BW Monitor
CHECK SIGNAL CABLE
MEANS THERE I SN O DISPLAY SIGNAL FROM YOUR PC..........PROBLEM IS WITH YOUR PC NOT WITH LCD
Mar 09, 2010 | Samsung 19" LCD Syncmaster 931BW Monitor
Samsung SyncMaster 931B 19" LCD Monitor Logo
224 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
