Question about HP PhotoSmart C4480 All-in-One Printer InkJet
I do not know how to connect my Photosmart C4750 to my wireless router.
    Brigadier General:
  • 10,406 Answers
Use an Ethernet cable to connect the network-port on your desktop/laptop to one of the LAN ports on the router.
Start Internet Explorer.
Access the web-server "inside" the router.
Run the "Wireless Network Setup Wizard",
to configure a SSID, your level of encryption (use 'WPA') and a password/pass-phrase.
Then, on the printer, configure its wireless interface to connect to that SSID, using that password.
Posted on Aug 30, 2010
Connecting Hp wireless printer to my Acer 210 tablet
A wireless printer must connect to the wireless router so you must know the SSID & password of your wireless router.
Initial setup must be done fist by connecting and loading the drivers to the PC. Once done you can print wirelessly because you are printing to a networked TCPIP port.
Apr 12, 2013 | HP Photosmart 5514 Wireless e-All-in-One...
I need an owners manual for a HP Photosmart C4750
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3831745&
This URL contains both the User Guide and Reference guide for your printer. Once you select your language just download it.
Hope this helps
Feb 20, 2012 | HP Office Equipment & Supplies
Can't print wirelessly from HP C4750
Original CD must to do this activities: un install the drivers, re install once again,select connectivity as wifi ..if your wire less router/wifi unabled.. If any difficulty in wire less connectivity go to hp web site down load the pdf file read care fully, do as specified.
Feb 01, 2012 | HP PhotoSmart Office Equipment & Supplies
I have a CISCO Basic Wireless Router. Can this particular Router be connected to an HP Photosmart wireless printer? There is no WPS easy button on the router.
The router is capable of at least Wireless B (11MB) and possibly Wireless G (54MB) or Wireless N standard speeds. The HP Photosmart will do at least Wireless B speeds (and depending on which model - even possibly the faster "G" or "N" standards, too), so yes; it can be connected wirelessly.
You'll have to set up the the HP Photosmart printer the same way you set up other wireless devices to connect to the router. You'll need to input the SSID, Security Encryption Type (WEP or WPA) and associated security "Key" to match those settings that are in the router.
If you can't remember those settings, or never set up the wireless options, you'll have to access the Cisco Router's built in web set up page. Since you didn't include your particular model number, you'll have to look up this info at Cisco's web site yourself.
If you have trouble, include the model of your router and I'll see what additional info I can get for you.
Please rate this reply - thanks!
Jan 11, 2011 | Cisco Linksys WirelessG Broadband Router...
Iam trying to set up a photosmart D7360 to work in my home for all PCs so I'd like to set it up wireless. I'm currently using a router. How do I start? I have a brand ne HP lap top and the photosmart is in...
HP Photosmart D7360 is Not completely Wireless Capable, However if you want to make it Wireless, You will have to use HP bt450 Bluetooth Wireless.
However since this printer has Ethernet Port, you can still make this printer wireless.
You will have to connect this printer thru Ethernet cable ( network cable ) to Router ( this is called wired networking )
Once you have connected the printer to Router, insert the disk in CD Drive and start the installation process, It will prompt you to choose the type of Connection, Choose Wired/Wireless Network and continue with further installation to complete.
How this works,
With any PC that is connected Wireless to Router, You will be able to print wireless from the PC to Printer.
Jul 03, 2010 | HP Photosmart D7360 All-In-One InkJet...
Cannot connect my HP Photosmart C4750. Have tried for 2 days. Can only connect with USB. CANNOT connect wirelessly!!!
system on and your printer connect with usb than printer power on. detect your new printer than install the printer driver and use.
Mar 01, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Purchased a HP Photosmart C4750 Wireless, it keeps going offline? Won't Scan wirelessly. O/S - XP.
Set your wireless security to WPA with the cipher set to auto. If you have the cipher set to TKIP, the printer won't stay connected.
Even if you set the printer to use TKIP and the router to use TKIP, it won't hook up, and if it does, it won't stay connected. I have tried telling HP about this issue, but so far, just canned responses to my emails
Jan 25, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Hp Photosmart C6180
In order to have a network connection you need to connect your printer to a wireless router that you have. make sure that your computer is already connected to that network.
1. Connect the printer to the router wirelessly. Press the "setup" and then press the arrow key and look for "network". Press ok when you see "network". Press the arrow key and look for wireless setup wizard. After you have successfully connect your printer to the router press ok
2. Check the ip address of the printer by printing wireless configuration page.
3.install the software for the printer
Aug 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP PhotoSmart C4480 All-in-One Printer  InkJet Logo
257 people viewed this question
Seeker5211
Seeker5211
