Question about Texas Instruments TI-86 Calculator
My ti-86 screen is black is that normal. I have not used it in years, but i put fresh batteries
  • 37 Answers
Hello, First of all no; it is not normal for your screen to be black. How can you enjoy the wonderfulness that is Ti with a dark screen. For the solution; it sounds like your contrast needs to be adjusted. Hold 2nd and down. The screen should lighten. If it reaches about where you can not see the cursor, then press 2nd and up and this will darken it. Hope this helps; Happy Calculating
Posted on Aug 27, 2010
How do I reset my TI-86 after a long period of no use.
Every time you change batteries this will happen to you. First press 2nd then press and hold the down arrow. Hold until their is no black in the background but you can still see the numbers on the screen.
Sep 05, 2014 | Texas Instruments TI-86 Calculator
Still dark screen after trying to hold down the second key and then the down arrow
I got frustrated with mine so I started to press the 2nd, then releasing, then hitting the down arrow, and back and forth... and it worked! Please try this instead, it worked and I've been trying to use the hold and press this and that, but the alternating worked better!
Jan 09, 2012 | Texas Instruments TI-86 Calculator
I have TI-89. I didnt use it since 2 years. but now after changing its battery it showing me just black screen with many straight lines. What should i do
Take out one battery. While holding the "On" button, put the battery back in. It may take more than one attempt, but it should start working again. Tell me how it works out, and hope this helps!
Oct 10, 2010 | Texas Instruments TI-86 Calculator
My screen is black after putting in new batteries in my TI-86
Adjust the contrast. Turn the calculator on. Press and release the 2nd key. Press and hold the down-arrow key until the screen lightens. If you go too far, repeat the process using the up-arrow key instead of the down-arrow.
Aug 17, 2010 | Texas Instruments TI-86 Calculator
The screen is black when I turn it on. I've replaced the batteries and no change. I try to change the contrast and nothing happens. It is a couple years old, but I should still work.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
To adjust the screen: Darken or lighten display
To darken screen
Press [2nd] key and release it.
Press and hold [UpArrow] until screen is dark enough.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
Hope it helps.
Dec 03, 2009 | Texas Instruments TI-86 Calculator
Switched the TI-86's batteries but im getting a black screen
After changing the batteries the calculator is o restored to factory defaults, but the screen contrast may change. The screen may be too light to see anything. Darken it a bit.
Hope it helps.
Thank You for using FixYa and for rating the solution.
Dec 01, 2009 | Texas Instruments TI-86 Calculator
Black screen
Try adjusting the contrast. It may be too dark. Turn the calculator on press the 2nd key and the down arrow. This is how to adjust the contrast and will lighten the screen. You can darken the screen the same way, but use the up arrow instead.
Aug 25, 2009 | Texas Instruments TI-86 Calculator
Blank lines across the screen of a TI-86 graphing calculator
Try this, hook up new battery and go to MODE and darken and lighten the screen.. do it ten to fifteen times. if that doesn't help, try hook up most left and most right's battery terminal to a DC supply at 4.5V. dont go above 4.5 it will fry your calc (it is design to handle 3V). now you are forcing extra juice into the dead LCD screen lines... and reapeat the MODE + darken trick. I fixed mine like that! Works! and remeber to leave it completely black(darkest) for a while to keep that dead line alive!
Jul 06, 2009 | Texas Instruments TI-86 Calculator
No power up
turn it on and immediately pull out the battery: fixed my TI-85 if not its ded :-(
Feb 01, 2008 | Texas Instruments TI-86 Calculator
Texas Instruments TI-86 Calculator Logo
291 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
