Question about Whirlpool Dryers
Gas dry will not ignite at any setting check breaker ok, everything is working wontt get heat. model#LGN1000HQ1 serial# MJ4004651
    Problem Solver:
  • 13 Answers
Is the gas on and there is asensor that has to prove pilot
Posted on Aug 27, 2010
My ge dryer ( model # dde5900ral ) does not always provide heat during the drying process in the regular drying modes. I have found that I can place the dial to timed dry between the 90 & 120 minutes...
Hi
1.Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2.Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3.Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4.Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5.Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps... Please post back if you need more information.
Daniel
Nov 08, 2010 | GE Dryers
My kenmore dryer runs but not drying and no heat.plz let me know waht i should do?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Sep 25, 2010 | Kenmore 63942 Dryer
Dryer has warmth but clothes are not drying. vent is not clogged, temp set at regular,drum is turning What could be the Problem?
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 25, 2010 | Maytag PYE2300AY Electric Dryer
Doe's not dry, No hot or warm air
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 24, 2010 | Bosch WTMC1301US Electric Dryer
The dryer is not heating to dry the cloths.
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 20, 2010 | Dryers
DRYER WONT START,IT HUMS, MODEL #LNC8760A71
Hi
If the dryer is not turning on or is not drying the clothes then you would need to check for the following things—
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 13, 2010 | Dryers
Appears to be working but not drying clothes
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 02, 2010 | LG Dryers
GE Dryer model DWSR405GB0WW Gas dryer will not heat up when auto dry cycles are used (thatt use automatic sensors, such as the permanent press dry cycle or the "auto dry" cycle). Only works in manual timed...
Hello there
when a gas dryer will not heat up properly there can be several different reasons i will try to explain them here for you ok
No heat If your dryer doesn't heat, check these: Igniter Gas valve coils Thermal fuse Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too. The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one. Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Mar 29, 2010 | Dryers
Does not dry completely
how well did you clean that duct, the duct is problem 90% of the time when the dryer does everything else, pretty much if the dryer heats and tumbles its doing its job
May 04, 2009 | Dryers
Maytag Atlantis Dryer
As you are looking at the igniter you may notice a little rectangular sensor to the left.
This tells the dryer that the igniter is glowing and it is OK to open the natural gas valve. If this sensor isn't working, the gas valve remains closed
Once the burner is lit, there is another sensor above the flame that is round. (flame sensor) This tells the dryer that the flame is lit.
If this sensor isn't working the dryer turns off the burner after a brief period.
This sensor can be cleaned or replaced.
Jun 22, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
23 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
