Question about Refrigerators
I have a tecumsee compressor for a cold tray Mod # aea2410yxa. Its showing 60 psi on the high and low side. It tries to run for about 10 sec. the kicks out. the power keeps the cond. fan running and it has 120 to the common side of the compressor but shows nothing on the run or start sides. i replaced the relay and the overload, could the compressor be bad?
  • 4 more comments
  • pool_player4 Aug 27, 2010
    The overload shows 120 volts going through it to the common but through the relay im showing nothimg. could it be wired wrong?
    The overload is not kicking out now but the relay is not showing any power 120 v on either side?
    I checked the amp draw on the compressor it was at 25 amps. Should i try replacing the capacitor befor givig up?
  • pool_player4 Aug 29, 2010
    Im wondering about the compressor because theres 60 pounds on both the high side and the low side? any comments?
    Im sure its wired ok. Im worndering about there being 60 psi on both the high side as well as the low side? any comments?
  • pool_player4 Aug 30, 2010
    Thank you for your help with my cold table. you gave me plenty of option to try however i'm afraid the last option is replacing the compressor,thank you for your help
  • 3,740 Answers
The compressor is kicking the thermal overload for some reason. Look on the compressor label. There is an LRA number there which is for "locked rotor amperage." 1 1/4 hp compressor for example has an LRA of 13.7 up to 16.9 amps depending on manufacturer. You need to use a clamp on amp meter to measure the amperage. If you see the LRA number is reached then the compressor is dragging / not starting / frozen in place.
One thing that is still a possibility is that there is a very weak run capacitor. You check it by disconnecting one side of it then use a meter repetedly reversing leads on R X1000 watching for a jump in the meter reading. No jump = bad cap. Or short across cap terminals = bad cap. Your 2/3rd of the way there by replacing the overload and relay. Cap must also be verified.
One more test to do is read EACH compressor terminal to the compressor case. If any 2 of them read to ground it is internally shorted. Most of the compressor none of the leads will read to the case of the compressor unless it is a multi phase very large compressor and has a delta ground.
Kelly
Posted on Aug 27, 2010
  • 3 more comments
  • Kelly
    Kelly Aug 28, 2010
    This is a 1/4 hp compressor and if it is drawing 25 amps and not starting.... it is not looking too good for continued service. Actually it seems pretty high for a 1/4 hp compressor. I had asked that you check the EACH of compressor terminals to the compressor case for continuity. (Compressor internal short test) I did not see that in your response. That test alone would let you know if the compressor has electrically failed internally. You should do this check before any other testing.
    I hate to recommend this but... as a technician I would at least try changing the cap if the compressor is not shortred internally. I doubt it is going to make much difference. However... being that this will probably require a compressor replacement (Compressor lists for $397.00 - $440.00)
    I would give the cap a whirl if nothing else just to have a new one in place once the compressor was replaced. Add labor, service call and freon... this is not a cheap repair if in fact this ends up being a compressor failure.
    I am not sure how old your cold table is but, most of the time compressor does not just up and quit unless an armature bearing failed rapidly or the compressor pump had a catastrophic failure inside. Usually if you compare your utility bill you would note a steady increase in the KWH used each month up until the failure. If you noticed this I would bet the farm the compressor failed. Depends on the application. A homeowner would notice the difference. A service establishment may not notice the difference.
    Thanks for giving FixYa the opprotunity to help.
    Kelly
  • Kelly
    Kelly Aug 28, 2010
    This is the compressor $397.11 ref: http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...
    Note the seller is in NY and from a business. I only cite this as a price comparison and not as a recommended business or purchase. That is your decision.
    Kelly
    I checked the compressors terminals to groun and non of them are grounded. you thin its worth trying to replace the capacitor?
    Im worndering about there being 60psi on both the high side and the low side? any comments?
  • Kelly
    Kelly Aug 29, 2010
    The 60 psi on both sides is an equalized (normal) system, not running. Once the compressor starts then you see the high and low side pressure differences. You can try a cap. I think with this particular compressor that a replacement comes with new caps. If you buy a cap and it doesn't start you may just have a spare cap on your hands. It is worth a try as it is the cheaper alternative. And to be honest.. if this were me working on your cold table I would not be changing a compressor until I had swapped out thermal overload, PTC relay and the cap(s) Just a must do p;rocess pre compressor change. Some have 2 caps 1 for starting and 1 for running.
    Kelly
    Genius:
  • 1,340 Answers
Since it has 60 psi,I would say the compressor is fine because there is pressure.I would look at the condensor.If it is not able to convert the gas into liquid,there is probably a safety control which is shutting it down to prevent overpressure.I saw your answers to whatever some of the others asked(they won't let other experts see each other's comments)and it is not likely that your 2 new things you replaced are bad.Good luck! Greg
Posted on Aug 28, 2010
  • 1,998 Answers
Yes sounds like its bad to me a tecumse compressor is one of the worst compressors they put in appliances today in all actuality they dont put enough oil on the inside of the compressor which cause them to burn out quicker most of the time when we change a compressor out and it is originally a tecumse well switch to any other kind but a tecumsee thats how good those work.Theres no way to give an accurate warranty on them because they blow out so easily. they are not a well made compressor by far.also a question for you when you changed the overload and the relay did the line get even slightly cold or did it just stay warm the whole time? In all I think its a waste of a compressor and out of changing out over 4-500 of them withiin the past two years i can tell ya try a differnt brand. please remember to rank this opinion and if you have any further questions message me back. Have a great day
rickead1
  • 905 Answers
Hmm, it sounds as if your compressor is wired backwards. Here's why.
You should have the 120vac applied to the run and start windings, and the common should be tied to the neutral. When the overload opens, the neutral is interrupted, killing both start and run windings. Your Potential Start relay is dependent upon the voltage ramp-up of the start winding. If it doesn't see this ramp-up, because it is placed on the hot side of the winding, it will not disengage, and causes the thermal overload to kick out.
I am not sure if the compressor itself will be damaged by miswiring though.
At this point, I would ensure that the compressor, the capacitors, the Potential Start Relay, the overload is all wired according to the diagram found on the unit's panel. If it is, check for continuity across each windings terminals, as well as each terminal to the compressor housing. You should have continuity from terminal to terminal on the same winding, but no continuity from terminal to the housing. If you do, then the compressor is grounded, and will need to be replaced.
Charge a/c 2.50 134a replaced low psi.switch still low psi switch shuts off com.low gauge showes 23 to27psi
Dis you evacuate all the air before charging the system? What is the high pressure side reading? How long does it take for the compressor to shut off? Have you checked the TPS? Maybe the computer is been told the engine is at 60% throttle which kills the compressor clutch for more power, have you replace the AC clutch relay?. I don't know lots of reasons for this.
Jul 20, 2016 | Cars & Trucks
1989 s 10 blazer won't take freon has 55 psi on low side while filling with comp. On only 20 psi high side where should I look for prob.
Sounds like the fittings are reversed.
With the compressor running, the low side should drop below zero then climb to 60 or 80 psi as you add freon.
You would need to jumper the low pressure switch to engage the compressor clutch to add freon. The compressor must be running.
Mar 22, 2015 | Cars & Trucks
2003 CYRYSLER CONCODE AC NOT COLD
Sounds like compressor is not working.
Aug 26, 2014 | Vehicle Parts & Accessories
Location of ac high pressure cutout switch on a 97 Plymouth voyager. Could it be a different problem? Had to replaced the PCM and a couple sensors because of a short in the wiring cluster. Now the ac...
HIGH PRESSURE CUTOFF SWITCH LOCATED ON AC COMPRESSOR DISCHARGE LINE LEADING TO THE CONDENSOR.THE HIGH PRESSURE CUTOFF SWITCH WILL CUT OFF THE AC COMPRESSOR IF SYSTEM PRESSURE RISES TO HIGH CAUSED BY RESTRICTION IN THE REFRIGERANT CIRCUIT OR OVERHEATED CONDENSOR.MAKE SURE COOLING FAN IS RUNNING WHEN THE AC SWITCH IS ON.THE COOLING FAN KEEP CONDENSOR COOL, IF COOLING FAN DONT RUN.YOUR AC WILL STOP BLOWING COLD AIR.HAVE THE REFRIGERANT SYSTEM CHECK OUT.MAKE SURE YOUR LOW SIDE PRESSURE IS 10 - 37 PSI. THE HIGH SIDE PRESSURE SHOULD BE 112 - 210 PSI. CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.
Jul 29, 2011 | Plymouth Voyager Cars & Trucks
I just finished charging it it's at 100 psi low side tube gets cold right at fill point rest of system does not. Dryer is hot.
100 AT PSI ON THE LOW SIDE TOO MUCH REFRIGERANT.LOW SIDE NEED TO BE 28 PSI. HIGH SIDE SHOULD BE 200 PSI.YOU NEED A MANIFOLD GAUGE SET TO SEE YOUR LOW AND HIGH PRESSURE SIDE.YOU PUT TOO MUCH REFRIGERANT IN AC SYSTEM IT WILL EXPLODE CAUSE SERIOUS INJURY AND DAMAGE THE COMPRESSOR.
Jun 11, 2010 | 1997 Audi A8
Air conditioner in 1999 mercury tracer won't work. It's not the compressor nor does it have a leak. what could be the problem?
the tracer is the same as the ESCORT, right?? TRY THIS--I WORK ON PLENTY OF ESCORTS--LOOK UNDER THE AIR CLEANER/CONE ASSEMBLY--THERE WILL BE A BLACK METAL BOX(FULL OF RELAYS) ONE OF WHICH IS THE A/C RELAY--TRY TAPPING ON IT WITH A LONG SCREWDRIVER OR SOMETHING SIMILAR WHILE U HAVE THE A/C ON. IF THE A/C SUDDENLY STARTS WORKING U NEED TO GET A NEW RELAY BOX(I THINK ITS CALLED A GEM MODULE) i do have a question- does the blower motor work?? how do u know the compressor is good??do you have 12 volts going to it??? this relay box is pretty common to go bad--u have to remove the air cleaner in order to get to it.get back to me.
Sep 07, 2009 | 1999 Mercury Tracer
96 Tahoe no Cold Air
YOU NEED 28 PSI ON LOW SIDE AND ABOUT 190 ON HIGH SIDE.YOUR REFRIGERANT IS LOW THAT WHY COMPRESSOR CYCLING ON AND OFF.
Jul 22, 2009 | 1996 Chevrolet Tahoe
Where do I recharge ac at
there are 2 ports one for low pressure and one for high pressure. the low pressure is bigger in diameter and is usually close to the dryer and or fender and firewall. the high pressure is near the condensor on the fron of the vehicle. if there are caps for the ports low will be blue and high will be red. low side pressure should be 35-50 psi and high pressure should be 135-150 psi
May 11, 2009 | 1998 Dodge Dakota
1997 Deville ac compressor locked out - low
70 psi static does need a charge.find compressor relay, jump relay and compressor will start. add refrigerant,replace relay and a/c should work fine
Apr 16, 2009 | 1997 Cadillac Eldorado
Evap fans not turning on
If this is a commercial unit, you're too low on refrigerant (freon). Freezer should be about a minus 10 degrees for the evap and high side is ambient converted to a psi for the type of refrigerant that is in the system plus 25-30 psi.
The evap fans will not come on because the evap is not cold enough.
Hope this helps and good luck.
Apr 09, 2009 | Freezers
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
