Question about Radio Shack Pro-96 Scanner
All channels locked out
Main screen has message that states "all" channels locked out! I have done everything that manual said do and still get the same message. This is my first experience with a scanner of this quality and no doubt I am scanner illiterate. Detailed info on how to solve this would be greatly appreciated.
Thank you
ken
  • ameshack Aug 03, 2008
    I turn the scanner on and it scans, but I can't get a responce from any button I push. There is not a message saying lock out. It doesn't even beep when I press a button
    Thanks
  • Ron Miner
    Ron Miner Aug 30, 2008
    all channels blocked out
Is the Attenuation set to Global on? That may be the issue.
Posted on Aug 01, 2008
Try programming it.
Posted on Jul 13, 2008
My panasonic TX37 lzd 80 tv has on screen message no signal on some freeview channels and the picture is fuzzy
Change your main board but before check if the power supply is ok. Good luck,
Serge.
Feb 26, 2016 | Panasonic Televison & Video
Osd is saying the main menu is locked how do i unlock
Win Tyler,
Information on resolving your locked screen on your LCD is listed below.
In the TV Menu Settings menu you can
select TV Button lock to lock the TV
Menu and the side panel buttons. When
this option is enabled, only the power
button functions. To unlock the TV Menu
and side panel buttons:
1. Press the Menu button on the TV. A message appears stating that the TV is locked
2. While the message is on the TV, press the channel up and volume increase button
simultaneously.
If you are using the DVI connector, you may need to verify the following settings:
Source - The default setting is Auto. The T V automatically detects if a computer (PC) or video
device is being used. If the image does not display correctly, you can select the source, PC or
Video, depending on the device you are using.
Color - The default color space is RGB. If the colors are not displaying correctly, you can change
the setting to YUV.
You can download and view the online users manual from the link below.
Manuals & documentation for your LCD TV W2306C
Product Support
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Nov 18, 2015 | Dell W2306C 23 in. HD-Ready LCD Television
Main menu locked om dell w2306c
Use the side panel buttons to unlock the TV Menu and side panel buttons:
  1. Press the Menu button.
A message appears stating that the TV Menu and buttons are locked.
2.While the message is on the screen, press the volume decrease and channel up buttons on the side panel simultaneously. A message appears stating that the TV Menu and buttons are unlocked.
GOOD LUCK AND PLEASE RATE THIS POST!!!
May 09, 2011 | Televison & Video
Wii, error reading Sports game
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aaaabbbb19
Dec 25, 2009 | Nintendo Wii Console
Radio Shack Scanner Model # 20-527 1000 channel triple trunking
The manuals for radio shack equipment are available on the Radio Shack website. I just viewed and downloaded the one for the 20-527 last night and that is an older unit. In the search window, put in the Cat number, and searched it. If this doesn't work search the word manuals and try that. You can totally re-initialize the 20-527, those instructions are there too. The disadvantage; you loose all your programmed information and will need to start over. Which is ok if you'd like to start fresh again.
Jul 13, 2008 | Office Equipment & Supplies
Child lock on tv
All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
May 24, 2008 | Televison & Video
Channels locked out
Mrs. Santa brought me a new PRO-97 yesterday. I'm new to this - just wanted an aircraft frequency scanner, but got the whole shameal. I had a bad AC adapter and attempted to fix the power problem as directed in the manual by re-initializing the scanner. That blew all memory away.
I received the feared All Channels Locked Out message and through a little research and fiddling, realized the scanner was pre-programmed. An Addendum came with the scanner with instructions to reload the 155 pre-programmed frequencies:
1) Turn off the scanner and then turn it on again.
2) When 'Multi-system Trunking Scanner' appears, press PGM.
3) Press 1.
This will reload the pre-programmed frequencies erased by the re-init. Press scan and it'll be as new as outta the box!
Best wishes,
Farnk
Aug 16, 2007 | Radio Shack Pro-97 Handheld Scanner
PRO 96 Scanner
I had the same problem. I called Radio Shack and they said there were no channels were programed to scan. I am very new at this so I would be able to help you program but call Radio Shack at 18008437422 and hit option 2 twice. The person I got on the phone was great. Just be sure to have the numbers you want to program in front of you.
Dec 28, 2006 | Radio Shack Pro-96 Scanner
Radio Shack Pro-96 Scanner Logo
259 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
