Question about Dolphin Maytronics Advantage
I have a Dolphin Diagnostic Advantage Pool Cleaner. It's worked fine for the past 2 years when I purchased it. Put it in the pool today and it's not working like it usually does. It runs for roughly 54 seconds and then just suddenly stops. Bag, wheels, and inside assembly are completely free of any dirt or particles. Power light is on so it's not the fuse. What could be the problem? So aggravated! Thanks for any help.
    President:
  • Dolphin Master
  • 1,378 Answers
<span style="FONT-FAMILY: Tahoma; FONT-SIZE: 10pt">Thank you for posting your question here on <a rel='nofollow' href="http://www.fixya.com/">Fixya.com</a>.</span><br /> <span style="FONT-FAMILY: Tahoma; FONT-SIZE: 10pt"> </span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Your problem could still be in the power supply, cable or motor unit. The motor unit is the most likely problem. For starters, try the tip I posted here on Fixya, found at: <a rel='nofollow' href="http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up">http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up</a> </span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"> </span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">If that is not enough, try our sites FAQ section on Dolphins at <a rel='nofollow' href="http://www.arrowpools.net/"><span style="COLOR: purple">www.arrowpools.net</span></a>. Select the FAQ button then from the drop-down select Dolphin.</span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"> </span><br /> <span style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">It is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. For information about sending your unit in for repair use the dolphin form link on the bottom of our site</span><br /> <span style="FONT-FAMILY: Tahoma; FONT-SIZE: 10pt"> </span><br /> <span style="FONT-FAMILY: Tahoma; FONT-SIZE: 10pt">If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!</span><br /> <span style="FONT-FAMILY: Tahoma; FONT-SIZE: 10pt"> </span><br /> <st1:personname w:st="on"><span style="FONT-FAMILY: Tahoma; FONT-SIZE: 10pt">John</span></st1:personname><span style="mso-bidi-font-size: 10.0pt"></span>
Posted on Aug 27, 2010
Goes to wall and turns itself over. It is clean.
Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ...
? 3:44
www.youtube.com/watch?v=-x8hwghv8BE
Apr 4, 2012 - Uploaded by Swimming Pool Tips, Reviews & How To -MrDgvb1 Maytronics-Dolphin pool cleaner, Dolphin Diagnostic ... Solar Breeze: The Robotic Solar-Powered Pool Cleaner Review: http://youtu.be/jzWfClbOnIc ... Pentair Kreepy Krauly Legend Review, Troubleshooting & Tips:
Aug 08, 2015 | Dolphin Maytronics Diagnostic Robot...
I have a Dolphin Orbit diagnostic pool cleaner approx 3 years old haven't used it for some months. Put it back in the pool and now it won't work any suggestions
It is either going to be that your impeller is blocked or your drive system has something stuck in it. Check your wheels, axles, etc. for obstructions. If it is not either one of these, it is going to be an issue with the electrical system and you are going to have to take it into a pro that specializes in robotic pool cleaners.
Sep 17, 2010 | Smart Pool Inc Dolphin Diagnostic...
Dolphin Interactive pool cleaner stops running
If the dolphin is falling backward when it meets the water line, there is an easy fix. The automatic pool cleaners often have this problem. The easiest solution is to remove the handle floats and attach an 8 oz weight to the bottom inlet cover.
May 23, 2010 | Smart Pool Inc Dolphin Diagnostic...
I have the exact same problem with my unit!
It is probably the motor unit and should still be under warranty if it is less than 2 years old. You can use our Dolphin service form at www.arrowpools.net or contact the manufacturer at www.maytronicsus.com for service information.
Jul 12, 2009 | Smart Pool Inc Dolphin Diagnostic...
My dolphin diagnostic cleaner for my below ground pool, just stopped after years. I went to turn it on yesterday and there is power to the power box as the light goes on, but the unit is not moving. I am...
If your unit has a fuse it will be on the back side of the power supply. If the light on the power supply switch is on, it will not be the fuse though.
Try turning the cleaner upside down on the deck and connect it as you otherwise would. Power it up and it should go through a self test process that takes about 40 seconds to complete. If it turns the tracks in both direction with and without the impeller turning, it is fine and will likley start working in the pool again.
If not, contact us through www.arrowpools.net and click on the FAQ and then Dolphin cleaner catagory. You can also use the Dolphin Serice button for information about sending it in for repair.
Jul 03, 2009 | Dolphin Maytronics Advantage
Dolphin Commander goes forward 2' then back 2' then stops.
The impeller motor is likely worn out. New motor units are expensive but less so than a whole new unit. You can send it to us in Michigan at www.arrowmotor.net or find a closer service center using www.maytronicsus.com Good luck.
Jun 14, 2009 | Smart Pool Inc Dolphin Diagnostic...
Circuit board inside power supply is bad. I need a replacement
You'll need a replacement board. You'll need model and serial numbers off of the cleaner itslef to help identify which power supply and therefore what PCB is needed to replace yours. Try contacting our service center at www.arrowmotor.net and click the contact button in the upper right corner.
Jun 13, 2009 | Smart Pool Inc Dolphin Diagnostic...
Dolphin Maytronics  Advantage Logo
132 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
