Question about Panasonic SC-AK33 CD Shelf System
F61 ,,,,???model panasonic sa-ak 177 - Panasonic SC-AK33 CD Shelf System
  • 4 Answers
SOURCE: F61 error in my SA-AK25 Panasonic Audio System
CHANGE STK --------IC
Posted on Mar 27, 2008
zair
  • 82 Answers
SOURCE: Panasonic SA-AK600
Try to power on the unit without the speakers connected. If it works normally without the error showing, then a speaker wire maybe shorted or a speaker defective. If the error F61 is still there, then most likely the Regulator IC is defective in the unit.
Posted on Jun 01, 2008
tech48
  • 624 Answers
SOURCE: panasonic sa -ak 27
This is a common error for these Panasonic units. I work at an authorized Panasonic service center and have repaired many of these.
This error is caused by either 1 of these 2 problems, both of which will require service for replacement of parts.
1. The amplifier IC is bad and needs to be replaced.
2. There are a couple of smaller components in the amp circuit that need to be replaced. One is a zener diode and the other is a resistor.
The F61 error is caused by a bad amp circuit or power supply circuit. In most cases it is the amp circuit. More often than not, it is the zener diode and resistor that are bad. This would be preferable since the amplifier IC is very expensive and a total repair cost would be close to $200. The zener diode and resistor repair would be closer to about $100 depending on the rates of the service center.
I know this may not be the answer you were hoping to get, but it is the problem you have.
If you found this information helpful in making a decision on what to do with your stereo a FixYa! rating would be appropriate and very much appreciated, after all, it is the only reward we get for offering free help to people like yourself.
If I can be of any further help just reply to the post and I will get back to you as soon as I am able.
Good luck with your stereo, I hope you found this information to be helpful.
Dave
Posted on Sep 05, 2008
SOURCE: F61 code error
Change the audio amplifier IC are damaged that´s the mean of that code
Posted on Sep 06, 2009
satavlad
  • 405 Answers
SOURCE: panasonic sa-ak750 display f61 change 3x output ic
F61 indicates that regulator IC is gone, simply replace it.
Posted on Nov 06, 2009
How do I take a Panasonic CD stereo system model
1st check that the fan is spinning. If it is you probably need a new output IC.
Oct 20, 2014 | Audio Players & Recorders
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
Panasonic Dvd stereo system model number SA-VK960 power supply is defective. is it possible to repair?
Your Panasonic SA-VX uses a Switch Mode Power Supply ( SMPS ). Do not ever attempt to fix it yourself unless you are well versed in electronics. ou can damage the system seriously. Seek professional help.
Mar 10, 2011 | Audio Players & Recorders
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
Panasonic sa-ht540 f61 error message
If the model has a fan fitted (may have 2) that be your problem faulty fan
Aug 26, 2009 | Televison & Video
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
Panasonic SC-AK33 CD Shelf System Logo
354 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
