Just received a Minolta Bizhub 7272 used, and I am getting an error code. SC46-25. Any idea what the problem could be?
  • 944 Answers
Check if you have your optic mirrors clean, as well as the lamp and the CCD lens.The CCD couldn't read the white stripe at power up.
Other possible causes:
- Optics motor
- Bind on any paper tray lift (try the machine with the trays open and close them one at a time if the error disappears)
- Look for a pinched wire in the registration unit.
If not solved please call the Minolta Bizhub customer care.
This error code actually occurs only if there is a problem related to the optics.
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 27, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Sc 21-05 for konica minolta 7272
The transfer and separation corona cleaning system locks, lubricate or replace corona unit
Jan 11, 2013 | Konica Minolta Bizhub 7272 Image Control...
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
Bizhub 350 All-In-One Laser Printer: Our department has just received a Minolta photoco...
You can download all manuals user manuals for your machine at kmbs.konicaminolta.us . However user manuals will NOT have C-codes in them for the customer.
I do not see a error code C-6xxx. If you would post the error I may be able to help you with the problem.
May 17, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Getting 0048 error while faxing with a bizhub 161f
For the 0048 error code the malfunction is in the reception part and the possible causes of error is can`t receive correct signal after receive PPS_PRI_Q or PRI_Q,EOR_PRI_Q.
Aug 05, 2009 | Minolta BIZHUB 161F Black and White Copier
Konica Minolta bizhub 250 malfunction error 3452
Try shutting dow the unit totally, even try unplugging it from the wall for 15 minutes.
If the error code does not go away, then a technician is needed
Jun 12, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
53 people viewed this question
k24674
jasbo
jasbo
