Question about Canon PowerShot S90 Digital Camera
When I turn on my Canon S90 the screen just shows menu items, not what the lens is directed at. I have to go into play mode to view saved pictures on my memory card, and then back into shooting mode for the screen to show what the lens is directed at. Doesn't seem to matter what shooting mode I'm in. Tried removing battery and putting it back in - and the battery is fully charged.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 27, 2010
I have a Canon Rebel t2i. The LCD screen does not display any images including menu items. How can I get it to work? Details below...
This appears to be a deeper problem than can be fixed with advice on here. I suggest you take it for a professional repair. Check the repair estimate with the value of the camera.
Nov 25, 2016 | Canon EOS 550D Rebel T2i Digital Camera
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
Canon eos rebel xsi screen is black when taking a picture but shows picture afterwards..Menu works also so screen works but just black when trying to take a pic..
Set the shooting mode to a Creative Zone mode. Press MENU to enter the menu. Under the Setup tab, select [Live View function settings] then press SET. Select [Live View shoot] and press SET. Select [Enable] and press SET. Press MENU to exit the menu. Press SET. The image should now appear on the LCD instead of through the viewfinder.
Refer to "Live View Shooting," Chapter 5 in the manual for more details and the limitations of the LiveView mode.
Dec 26, 2010 | Canon EOS Rebel XSi Digital Camera
My CANON EOS REBEL xs does not show the picture I am trying to take on the screen. The screen is either blank or shows a menu screen
Set the shooting mode to a Creative Zone mode. Under the Setting tab, select [Live View function settings] and press SET. Select [Live View shoot] and press SET. Select [Enable] and press SET. Press the MENU button. Press SET.
Jul 09, 2010 | Canon Rebel XS / Eos 1000D Digital Camera...
I'm having a problem with the lens
If your Canon SD110 shows saved picture in memory card in playback mode but does not show live view in camera mode then it is problem of ccd imager chip failure, that will be replaced.
Canon offers free of cost replacement of ccd imager in SD110, click Canon CCD Imager Advisory for details.
Thanks.
Jan 12, 2010 | Canon PowerShot SD110 / IXUS IIs Digital...
Display screen no longer works while taking pictures
Sounds like they accidentally pressed the DISP or DISPLAY button on the back of the camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time with the camera turned on.
Aug 01, 2009 | Canon PowerShot A630 Digital Camera
No view on screen of what is showing in front of lens. Menu and playback shows but nothing when i turn to camera mode or video mode.help!
CCD Failure !
Lucky u can get it repaired Free just call Sony in ur region see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
May 05, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 | Cameras
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot S90 Digital Camera Logo
26 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
