Question about Canon ImageClass D880 Copier
Fuser I need a fuser for my copier but I don't know where it is located to replace it. Can you help
  • 42 Answers
On the paper exit end of the copier you must remove 3 plastic covers
1. one that the paper exits and lays on 2. upper cover {have to slide upper half of copier to left to get to the screw} 3 small plastic cover pops out right behind where paper lays as it exits.
pull back black plastic sheet
undo 3 connectors
remove 2 screws with a phillips #2 offset screwdriver
fuser lifts up and out-very tight quarters here go slow and easy
need any further assistance just ask!!
Posted on Jun 11, 2008
Where is the fuser located on MXC 311
The fuser unit is located in the right hand side of the machine. If you open the right door, inside the upperpart of the machine you will see 2 grey handles, 1 towards the front of the machine, the other towards the rear. If you pull these handles out you can then remove the fuser unit. There are 3 known faults for loud fuser noises,1 is the fuser drive gear inside the machine strips the teeth on it, second, the main drive gear in the rear of the machine strips the teeth(usually caused by the 1st problem getting broken teeth stuck in the remaining teeth causing the drive motor to strip the main drive gear) & thirdly, the pressure release mechanism breaks on the fuser unit itself. If it is any or these then unfortunately you will need the assistance of a dealer to replace the damaged parts.
Hope this helps.
Dave.
Oct 13, 2014 | Sharp Office Equipment & Supplies
Says I have a paper jam but don't
Remove fuser assembly mounted on the top, check paper input & out put sensors clean or blow air on it to clean the dust, if found any sensor flag dis located, locate it properly, if found damaged replace fuser unit..
Feb 01, 2012 | HP Color LaserJet 3500 Printer
Need to replace the thermistor on my Savin 9945 DPE Copier- how do I access the thermistor unit? Where would it be located on the machine?
replacement of parts of copier is done by a technician, well if you could follow this you can replace the thermistor. open the right side and the front cove, the fuser is located on top of the OPC carriage unit, push the blue level going to the right side while pulling the fuser unit. after removing the fuser unit remove its the top and bottom cover. the two thermistors is located on top near the fixing separation claw beside the two thermal fuses. Good luck!
Aug 26, 2011 | Savin Office Equipment & Supplies
I am receiving the mesage "Replace supplies" ..... I don't know what supplies they mean. I read where I need to check the 'gauge' -- but I don't where to check it. Can you...
On the control panel, go to information>print supplies status. You will then get a sheet printed with the counts of fuser, transfer belt and toners. There is also the option to just view them as well. You can also press the help button (one with a question mark) and that should tell you what is wrong.
Jun 23, 2011 | HP Color LaserJet 4650DTN Printer
Hello i'm french, i have an oki c 8800 with : service call 173 fatal error. i don't understand what is this error and i want to know how to repare
Error code: 173
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
May 27, 2011 | OKI C8800dn Led Printer
I getting 50.2 fuser error in hp laserjet printer what i do i don't know can u any one help me
the 50,2 error is a fuser error, and should be serviced by a repair facility. You can try to replace the fuser yourself, but the labor should be pretty cheap compared to the cost of the fuser assembly.
May 06, 2011 | HP LaserJet 5100tn Printer
Is it possible to find a used fuser for a Bizhub c250? I only have a few months left on the lease and don't want to put out the money for a new one. Also, can I install this myself or will I need a...
These are not too bad to replace yourself if you or someone you know is at all mechanically inclined. As far as used, you would probably spend the same for one plus shipping as you would for new. Or at least close enough to make it not worth it in my opinion. precisionroller.com has them for $257 with free shipping. Part# H1895
Hopefully this helps and just holler if you have any further questions.
Mar 19, 2010 | Konica Minolta bizhub C250 All-In-One...
I need to replace the fuser gear on a XC1040
You have to remove that small cover on the bottom of the frame. It has 2 phillips screws to remove it. it is the cover about 3 inches high that runs around the lower front part of the machine.
Once you do that, you only have to remove one screw , unplug the heat rod and lift the fuser up and out. It really is pretty easy.
Mar 08, 2010 | Xerox Office Equipment & Supplies
HP Color Laserjet 2840
Need to order a replacement FUSER it's located in the rear of the printer. If you live in the USA you need 110V if you're in Euro 220V see below for the part number you need to order.
RG5-7602-000
RG5-7603-000
Fuser ***'y, 110V, CLJ 2820/2840
Fuser ***'y, 220V, CLJ 2820/2840
CLJ 2820/2840
Aug 06, 2008 | HP LaserJet 2820 Printer
I have a Sharp Z-72 copier with a H code. What does it mean?
The fuser has a problem. With that model most likely it will need a fuser lamp replaced, sometimes it can be the thermo fuse located on the fuser.
Hope that helps...
Lbcoaster
Jul 14, 2008 | Sharp Office Equipment & Supplies
Canon ImageClass D880 Copier Logo
old marine
old marine
