Question about Bosch SHU5315UC Dishwasher
When I turn on the Bosch dishwasher it drains but does not fill or complete any cycle.
    Problem Solver:
  • 13 Answers
Need to change board which make the machine go threw the cycles
Posted on Aug 27, 2010
Where is the fill pipe at on a ge
can any1 help me, my bosch unit is not filling up but the fan in the drain keeps running iv tried draining all water out of unit giving a shake but is not working, I pulled the panel off the side and held down this red piece like a float valve and then the unit filled up but would not complete cycle, any suggestions
Jan 16, 2013 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
My Bosch dishwasher fills with water but when it comes to the wash cycle it does nothing.
If your dishwasher is brand new, then call Bosch service as they can repair it under warranty.
Feb 26, 2012 | Bosch Dishwashers
Bosch lifestyle dishwasher not filling with water. I undid the bottom and it blew out an air block and started. When reconnected again it is doing the same thing
hey can any1 help me I have a bosch automatic, when I turn the unit on the little fan in the bottom keeps spinning and no water enters the unit, iv drained all the water out of the unit cleaned the drain checked to make sure water is getting to the unit then I pulled the panel off the side and held down this red piece like a float valve down and it then fills with water, but its not completing a cycle, any advice what could be wrong?
Apr 09, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
i know this sounds daft but --
turn off water. disconnect fill hose from water supply. wait 5 seconds and reconnect fill hose then try it out
Oct 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Won't complete the cycle
Try using a quick cycle and see what happens. Don't use sanitize or any extra heat cycle. Sometimes during sanitize high temp rinse or other cycles the timer motor is stopped until the water heats up. The sensor could be defective. Not all machines do this and I'm not real familiar with your particular one.
Jul 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwaher shy56a
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Mar 25, 2006 | Bosch SHY56A02 / SHY56A06 Built-in...
Bosch SHU5315UC Dishwasher Logo
55 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
