I am getting a 49.5001 and 49.4C01 event that is cleared after power cycling and stays gone for hours then comes back.
My apc back ups es 650 has a continous chirp what doe that mean?
the chirp means a power event has occurred and the unit needs reset to continue operation , power events can be a few things ( to large a current was applied as a load to it , the power stayed off till battery failed and it had to charge it back up when power comes back on )
Apr 29, 2014 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Samsung HL72a650 tv power cycles
EURO STAR LCD TV 32" BLANK PROBLEM
Jan 23, 2014 | Samsung HL Televison & Video
Why is Fridge Freezer not switching itself back on after 2 hours?
Good Afternoon S Trowell - Thank you for your post! Based on the symptoms you are describing it appears that the thermostat has lost its calibration and is not cycling on or off at the proper temperatures. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis and to proceed further.
May 06, 2013 | Frigidaire FRT125GW (12 cu. ft.) Top...
My printer reads too many events waiting do not power off lexmark 543dn
If the printer is not updated, please update the firmware. Click on the link to get download the firmware.
http://bitly.com/xHO5Dc
For further assistance, please contact Lexmark Technical Support.
Jan 16, 2012 | Lexmark X544dn All-In-One Laser Printer
Hp color laserjet 3000dn getting 49.2 FC6 service error. not printing magenta. got new magenta toner - did not resolve. please advise
Any 49.xxxxx error is a critical firmware error
If power cycling the printer doesn't clear the error, try printing from a different program.
If it works, go back to the job that failed. Print. If the error comes back, that program is hosed.
If the error persists remove the network cable and any cable that goes to the computer.
Remove the JetDirect. Power on. If error is gone, power down and reinstall the JetDirect. Power up. If error is gone, chalk it up to reseating. If error comes back...replace the JetDirect.
If the error continues with the JetDirect removed, there could be a bad memory DIMM or formatter.
Good Luck
May 27, 2011 | Office Equipment & Supplies
Hi. i have a dell vostro 1000 which would not charge its batt so i bought a new batt that had no charge then charged it and it worked once. but now will not charge nor will the batt charge light stay on....
Could be many things, not necessarily in this order, but the ac adapter has gone bad(highly suspect), the power converter/charge board has gone bad, the power plug receptacle has an intermittent break in it from years of use (might be able to re-solder that one back on the board ) - or the new battery is not as new as you thought. In any event, You should send it to an authorized repair center - looking at a $100 bill or more.
Oct 02, 2010 | Dell Vostro 1000 Notebook
How do I program a Micronta programmable timer--I set the time to have it go on, but how do I set it to go off?
LCD Programmable Timer (630-0892) Operation Faxback Doc. # 17153 Setting The Time and Day Follow these steps to set the current time and day. 1. Slide RUN/PROG/TIME SET to TIME SET. 2. Press HOUR to set the hour digits. Pressing and holding down HOUR rapid- ly advances the hour digits. NOTE: P appears to the left of the hour digits to indicate P.M. hours. 3. Press MIN (minute) to set the minutes digits. Pressing and holding down MIN rapidly advances the minute digits. 4. Press DAY until the correct day abbreviation appears. 5. Slide the RUN/PROG/TIME SET switch to RUN. The colon flashes to show the clock is running. NOTE: Keep this switch set to RUN to prevent accidentally changing the time. Setting The Timer The timer has 14 settings (1-14). Odd numbered settings specify a time to turn on the appliance and even numbered settings specify a time to turn off the appliance. Follow these steps to set your timer. 1. Slide the RUN/PROG/TIME SET switch to PROG. The display shows the first setting. If you have not entered any setting, the display appears as shown in the illustration. 2. Press Event to select a setting to enter or change. 3. Press Hour to set the HOUR digits and press MIN to set minute digits to the correct time. NOTE: Be sure P appears to the left of the hour digits when you want to set a P.M. hour. 4. Press Day to select the day of the week for this setting. If you want the setting to apply to every day of the week, repeatedly press DAY until all day indicators appear on the display. 5. When you finish entering the setting, press EVENT. The timer advances to the next setting. 6. Repeat Steps 3 through 5 to enter additional settings. NOTES: Be sure to set the timer to turn off the appliance. The appli- ance remains on as long as there is power if you do not set a time for the appliance to turn off. To replace an existing event, select its setting number and set the new event time. To clear an event, select its setting number and press CLEAR twice. Be sure to clear both the on time and the off time for an event. If you set the timer to turn on the appliance every day, be sure to also set the timer to turn off the appliance every day. 7. Set the RUN/PROG/TIME SET switch to RUN. NOTE: You must set this switch to RUN to turn on or off the appliance either automatically or manually. When the timer automatically turns on the appliance, ON appears on the display and the indicator lights red. When the appliance turns off, the indicator turns off. Reviewing The Settings To review the settings in your timer, set RUN/PROG/TIME SET to PROG. Setting 1 appears on the display. Repeatedly press EVENT to view the other settings. NOTE: To determine event being programmed, pull the power for a period of 5 minutes. Then re-power the unit. The first event will be "ON" and the next will be "OFF", etc. There will be a number to the side of the display that tells you which event you are programming, The even numbers are "OFF" and the odd numbers are "ON" events. (EB 3/17/97) (EB 7/16/97)
Privacy Policy
Sep 10, 2010 | Vacuums
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
404 people viewed this question
k24674
