Question about The Times Case Corporation Tractors International Harvestor
We have an IH 986 with clutch problems. We have installed 6 clutches, 2 flywheels, new linkage, new cab mounts; everything has been replaced. After 8 hours of use, it is impossible to shift from neutral into any gear without shutting the tractor off. If this definitely a clutch problem or could it be a TA problem.
  • 2,019 Answers
I have not worked on an IH 986 specifically, but there are lots of other things it can be other than the clutch.
First of all, since it was apart 6 times, you should tell us if there was ever any visible evidence of anything wrong?
Is the disk wearing prematurely or anything?
But assuming it was never the clutch or flywheel any of these times, there are other things it could be.
For example, if the end of the transmission shaft is supported by a pilot bushing or bearing in the back of the crankshaft, that can be enough binding to prevent shifting. Always replace the pilot bushing/bearing, (if there is one).
Another could be a bad bearing, low oil, or grabbing synchro in the transmission. Unselected gears are supposed to freewheel on their bearing on the shaft. If the bearing is binding, it is like selecting 2 gears at once. If gear oil is low, this is a common problem, because synchros will bind, tear up, and throw bits of brass into all the bearings. This will not destroy the bearings because the brass is soft, but it will cause gears that need to spin freely on the shaft, to bind up.
This is probably not a clutch problem, but a problem with a bearing or bushing between something that is spinning and something that rides on it but is not supposed to spin at the same speed.
But please check the grear oil level first.
Posted on Aug 27, 2010
Clutch not disengaging
Slippage
  • Slippage is a clutch problem that occurs when the pressure plate is unable to hold the friction disc against the flywheel tightly when the clutch is engaged. This causes the disc to rotate at a different speed than the flywheel. The high temperature caused by friction against the disc will eventually damage the clutch plate and necessitate a replacement. On clutches with mechanical linkage, adjustment can forestall replacement for a time.
    If you notice the engine revving abnormally as the clutch is released, and the car accelerates gradually, then it could be a slippage problem. It's possible that grease or oil on the disc is causing the slippage or the engine mount could be broken, causing the linkage to be bound up by an improperly moving engine.
    Another common cause of slippage is when the friction plate is simply worn out from use. A clutch will not last forever, and over time the clutch will begin slipping. Adjustments will not fix this problem, as a worn out friction plate will require complete replacement.
Vibration
  • A grabbing or chattering clutch is an indicator that there is a problem inside the clutch mechanism. It is an easily noticed problem. Symptoms include a vibration or jerking as the clutch is released, especially when accelerating from a stop. This problem may be the result of a damaged or broken disc, flywheel or pressure plate. It may also be caused by loose springs or worn engine mounts, according to the Integrated Publishing website on Clutch Troubleshooting.
Jan 11, 2013 | 2004 Yamaha YZF-R6
Tip
2004 Hyundai Tiburon Clutch.
First you need to remove the Transaxle.
Manual Transaxle System REMOVAL
1. Remove the engine cover.
2. Remove the battery terminal.
3. Remove the air duct.
4. Remove the battery tray.
5. Remove the air cleaner.
(1) Upper
(2) Lower
6. Remove the back-up lamp switch.
7. After removing the CKP sensor, O2 sensor and oil pressure switch wiring bracket, separate the connectors.
8. Remove the brake fluid leveling sensor connector.
9. Remove the speedometer driven gear connector.
10. Remove the clutch release cylinder mounting bolt.
11. Remove the cotter pin of the shift cable (transaxle side).
12. Remove the cotter pin of the select cable. (transaxle side)
13. Remove the clip of the shift cable (transaxle side).
14. Remove the clip of the select cable (transaxle side).
15. Separate the steering column shaft joint.
16. Separate the power steering oil pump hose.
Be careful not to leak after separating.
17. Separate the hose after removing the clip of the power steering return hose.
18. Remove the upper connecting transaxle bolt.
19. Separate the start motor.
20. Install the engine support fixture.
21. After removing the tire, remove the caliper.
22. Remove the transaxle side cover.
23. Remove the transaxle side under cover.
24. Separate the tie rod end.
25. Remove the wheel speed sensor and the knuckle mounting bolt.
26. Drain the oil.
27. Remove the transaxle mounting bracket.
(1) Insulator bolt
(2) Body side mounting bolt (Upper)
(3) Body side mounting bolt (Side)
(4) Transaxle side mounting bolt.
28. Remove the front roll stopper.
(1) Insulator bolt
(2) Stopper bolt (Upper)
(3) Stopper bolt (Lower)
29. Remove the rear roll stopper.
(1) Insulator bolt
(2) Stopper bolt
30. Remove the drive shaft.
31. Remove the front muffler.
32. Remove the sub frame mounting bolt.
33. Install the transaxle jack.
34. Remove the transaxle lower mounting bolt to the engine.
35. Remove the transaxle assembly.
INSTALLATION
Installation is the reverse of the removal.
Then inspect and replace the clutch place and pressure plate.
INSTALLATION
1. Apply multipurpose grease to the release bearing contact surfaces and the release cylinder contact surface of the clutch release fork assembly.
When installing the clutch, apply grease to each part, but be careful not to apply excessive grease. It can cause clutch slippage and judder.
2. Apply multipurpose grease into the groove of the release bearing.
3. Apply multipurpose grease to the clutch release lever fulcrum contact surface of the clutch release fork assembly.
4. Clean the surfaces of the flywheel and pressure plate thoroughly with fine sandpaper or crocus cloth, and make certain that all oil or grease has been removed.
5. Apply a small amount of multipurpose grease to the clutch disc splines and input shaft splines.
Do not apply more grease than necessary. Too much grease could cause clutch slip or judder.
6. Using the special tool, install the clutch disc to the flywheel. When installing the clutch disc, be sure that the surface having the manufactures stamp is towards the pressure plate side.
7. Install the the clutch cover assembly onto the flywheel and install the six (6) bolts through the clutch cover into the flywheel.
8. Tighten the bolts by one or two turns at a time, in succession, to avoid bending the cover flange.
If a special tool is not available, tighten the bolt temporarily and then torque to specification in diagonal torquing sequence indicated below.
TIGHTENING TORQUE
Single mass flywheel:
15~22 N·m (150~220 kg·cm, 11~16 lb·ft)
Dual mass flywheel:
20~27 N·m (200~270 kg·cm, 14~19 lb·ft)
9. Remove the special tool.
10. Install the transaxle. (Refer to GROUP - Manual Transaxle Assembly)
11. Adjust the clutch pedal free-play. (See CH-6)
INSPECTION
1. Check the diaphragm spring end for wear and uneven height.
Replace if wear is evident or height difference exceeds the limit.
2. Check the pressure plate surface for wear, cracks and color change.
3. Check the rivets for looseness and replace the clutch cover assembly if necessary.
CLUTCH DISC
1. Check the clutch facing for loose rivets, uneven contact, deterioration due to seizure, adhesion of oil, or grease, and replace the clutch disc if defective.
2. Measure the rivet sink and replace the clutch disc if it is out of specification
3. Check for torsion spring play and damage and if defective, replace the clutch disc.
4. Clean the splines on the input shaft and install the clutch disc.
If the disc does not slide smoothly or if play is excessive, replace the clutch disc and/or the input shaft.
CLUTCH RELEASE BEARING
The release bearing is packed with grease. Do not use cleaning solvent or oil.
1. Check the bearing for seizure, damage or abnormal noise. Also check the diaphragm spring contacting points for wear.
2. Replace the bearing if the release fork contacting points are worn abnormally.
INSTALLATION
Then remove pressure plate and Clutch plate.
1. Insert the special tool (that came with your clutch kit) in the clutch disc to prevent the disc from falling.
2. Loosen the bolts that attach the clutch cover to the flywheel in a star pattern.
3. Loosen the bolts in succession, one or two turns at a time, to avoid bending the cover flange.
on Jan 13, 2010 | Hyundai Tiburon Cars & Trucks
Replace throwout barrings location install rattle when in gear.
get a service manual on CD over on ebay for about 5 bucks. jack car way up, drop the drive shaft, disconnect shifter and clutch linkage, unbolt the bell housing from the transmission and remove, unbolt pressure plate and take off flywheel, have flywheel resurfaced and reinstall, install new clutch and pressure plate, replace throwout bearing, put transmission and bell housing back in, connect shifter linkage and clutch cable or hydraulic, put drive shaft back in and you are done.
Jun 29, 2011 | 1996 Ford F150 Regular Cab
Need a copy of the manual pages, showing how to replace the clutch
Removal & Installation To Remove:
  1. Remove the transmission.
  2. Install a flywheel locking tool.
  3. Remove the pressure plate mounting bolts from the flywheel.
  4. Remove the pressure plate and clutch disc.
To Install:
  1. Insert a clutch disc alignment tool through the disc splines and into the flywheel pilot bearing. Pressure plate balance mark location subaru-07-00-6722.gif
  2. Install the pressure plate on the flywheel with a gap of 120° or more between the "0" balance marks on the flywheel and pressure plate. Hand tighten the pressure plate mounting bolts.
  3. Tighten the pressure plate mounting bolts using a crisscross pattern 12 ft-lb (16 Nm).
  4. Remove the clutch disc alignment tool.
  5. Install the transmission.
Dec 28, 2010 | 1998 Subaru Legacy
How do you change a clutch on a s10 chevy blazer?
1. remove the driveshaft.
2. remove the transmission.
3. remove the bellhousing
4. unbolt the pressure plate from the flywheel.
5. remove the clutch.
6. inspect the flywheel and pressure plate for scoring, checking, or other damage. repair/replace as needed.
7. place a clutch alignment tool into the clutch disk, insert it into the pilot bearing on the flywheel, and bolt the pressure plate back into place. Install a new throwout bearing on the clutch fork. remove the alignment tool.
8. install the bellhousing, connecting the clutch linkage.
9. replace the transmission and driveshaft.
I would *strongly* recommend buying a shop (service) manual which describes this process in greater detail. It is not rocket science, but it *is* a lot of work with many detailed steps that I glossed over above. If you are not certain that you are capable of this work, you need to take it to someone who is.
The transmission is heavy, you will need buy/rent/borrow a transmission jack to be able to safely get it in and out. Plus you need the proper ramps, wheel chocks, etc. to safely raise the truck enough to do all this, and you need a smooth, level surface to work on. A concrete garage floor is ideal, a driveway may be adequate if it does not slope much. Don't even attempt it on dirt or gravel.
Sep 06, 2010 | Chevrolet Chevy Cars & Trucks
Clutch adjustment for Interntional Tractor 986
tighten/shorten the cable that is attached to the back of the pedal
Apr 03, 2010 | The Times Case Corporation Tractors...
How to fit a new clutch into a ford escort 1300cc 1994
1991-96 Models
See Figures 1, 2 and 3
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Remove the transaxle assembly.
  4. If the clutch assembly is to be reused, matchmark the pressure plate and the flywheel so they can be assembled in the same position.
  5. Install flywheel holding tool T84P-6375-A or equivalent, in a transaxle mounting hole on the engine and engage the tooth of the holding tool into the flywheel ring gear.
0900c1528008df86.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Install a flywheel holding tool in a transaxle mounting hole on the engine, and engage the tooth of the tool into the flywheel ring gear
  1. Loosen the pressure plate-to-flywheel retaining bolts one turn at a time, in a crisscross pattern, until the spring tension is relieved, to prevent pressure plate cover distortion.
  2. Support the pressure plate and unfasten the retaining bolts. Remove the pressure plate and clutch disc from the flywheel.
If the flywheel shows any signs of overheating (blue discoloration) or if it is badly grooved or scored, it should be refaced or replaced.
  1. Inspect the flywheel, clutch disc, pressure plate, release bearing, pilot bearing and the clutch fork for wear. Replace parts as needed.
To install:
  1. If removed, install a new pilot bearing using a suitable installation tool.
  2. If removed, install the flywheel. Make sure the flywheel and crankshaft flange mating surfaces are clean. Tighten the flywheel retaining bolts to 71-76 ft. lbs. (96-103 Nm) on the 1.8L engine or 54-67 ft. lbs. (73-91 Nm) on the 1.9L engine.
  3. Clean the pressure plate and flywheel surfaces thoroughly. Position the clutch disc and pressure plate into the installed position and support them with a dummy shaft or clutch aligning tool. If the clutch assembly is being reused, align the matchmarks that were made during the removal procedure.
  4. Install the pressure plate-to-flywheel retaining bolts. Tighten the bolts in the correct sequence to 13-20 ft. lbs. (18-26 Nm). Remove the alignment tool.
0900c1528008df87.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Position the clutch disc and pressure plate into the installed position and support them with a clutch aligning tool
0900c1528008df88.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 3: Tighten the pressure plate-to-flywheel retaining bolts to specification in the sequence illustrated
  1. If the release bearing was removed, lubricate the release fork where it contacts the bearing and install the bearing in the fork.
  2. Install the transaxle assembly.
  3. Lower the vehicle.
  4. Bleed the hydraulic clutch system, if needed.
  5. Connect the negative battery cable.
  6. Road test the vehicle and check the clutch for proper operation.
Sep 30, 2009 | 1994 Ford Escort
1989 vette L98 external balance eng. w/6 speed ZF trans. installed new LUK (GM) dual mass flywheel w/ OEM replacement clutch/pressure plate assy. - eng. is out of balance. what is proper allignment for...
The clutch disk and pressure plate should be balanced and can be mounted in any position that the mounting holes line up. If there is a hole for an alignment dowl, then it is recommended to do so. otherwise it doesnt matter.
The internal balancing is taken care of by the flywheel only.
Jul 10, 2009 | 1989 Chevrolet Corvette
Wanting to replace the clutch because it is slipping.
Hope this helps. Best of luck to you!
Greg
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative battery cable.
  3. Remove the transaxle.
  4. Gradually loosen the clutch pressure plate bolts, in a crisscross pattern. Support the pressure plate and remove the bolts. Remove the pressure plate and clutch disc.
  5. Inspect the pilot bearing. If it is worn or damaged and does not turn easily by hand, remove it using a puller/slide hammer.
  6. Check the flywheel surface for scoring, cracks or burning and machine or replace, as necessary.
  7. Install a flywheel holder to keep the flywheel from turning. Loosen the flywheel bolts evenly and gradually in a crisscross pattern. Remove the flywheel.
  8. Inspect the clutch release bearing for wear. Replace it if it sticks or does not turn easily.
  9. Inspect the release fork for wear or damage and replace as necessary.
To install: 7923kg32.gif Structural view of the hydraulic clutch system
7923kg33.gif Exploded view of the clutch assembly
Click to Enlarge
7923kg34.gif Flywheel tightening sequence
7923kg35.gif Pressure plate tightening sequence
  1. Lubricate the release fork fingers and pivot with molybdenum grease and install in the release fork boot.
  2. Install the clutch release bearing on the release fork.
  3. Install a new pilot bearing in the flywheel, if removed.
  4. Be sure the flywheel mounting surface and the crankshaft or eccentric shaft mounting surfaces are clean. Remove any old sealant from the flywheel bolt hole threads and the flywheel bolts.
  5. Install the flywheel.
  6. Apply sealant to the flywheel bolt threads and install them hand-tight. Install the flywheel holding tool. Tighten the bolts, in a crisscross pattern, to 71–76 ft. lbs. (96–103 Nm).
  7. Apply a small amount of molybdenum grease to the clutch disc splines and install the clutch disc on the flywheel, spring side toward the transaxle. Install a suitable alignment tool in the pilot bearing to position the clutch disc.
  8. Install the clutch pressure plate, aligning the dowel holes with the flywheel dowels.
  9. Install the pressure plate bolts and gradually tighten, in a crisscross pattern to 20 ft. lbs. (26 Nm). Remove the alignment tool.
May 20, 2009 | 2004 Kia Rio
How do you replace clutch in 1997 toyota corolla? Do you need to replace entire clutch assy or just the clutch disc?
I see. sounds like you need a new clutch. OK, here is a step by step guide to follow. it will help with the removal and installation of your new clutch.
Remove the Old Clutch Step1 Verify that your vehicle's clutch is the source of your problems and not the pedal-arm bushings, activating cables or the slave-master cylinder. Step2 Unhook the positive battery cable, the clutch cable or hydraulic slave cylinder to get the transaxle ready for easy removal. Eliminate anything that may hinder your efforts, including exhaust pipes and the speedometer. Step3 Secure your car in a safe position before jacking up the front end. Step4 Stabilize the engine with a jack below the oil pan. Remove the transaxle by undoing at least one engine mount. Step5 Separate the engine from the transaxle by removing the bolts that surround the flywheel bell housing. Step6 Push the transaxle away from the engine until the input shift clears the pressure plate. Step7 Disengage the bolts surrounding the pressure plate and take it and the clutch disc out. Check to see if the flywheel's friction surface is scored, checked or has hot spots. Remove, machine and reinstall the flywheel, if needed. Step8 Examine the pilot bearing (bushing) located at the flywheel's center to be sure the needle bearings are lubricated and that there's no galling. Also look for any oil leaking around the rear main engine seal. Replace the clutch Step1 Follow the instructions for replacing your car's clutch carefully to avoid having to remove the transaxle. Step2 Check that the transaxle's input shaft isn't leaking; replace if needed. Step3 Take out the flywheel and the old seal and install a new seal. Install a New Clutch Step1 Clean the crankshaft flange before putting in the flywheel. With the flywheel on top of the flange, secure the bolts in a star formation to the specified torque for your vehicle. Step2 Install the clutch disc and pressure plate. Prior to putting in the transaxle, attach the new release bearing to the release fork. The fork should move freely. Step3 Hoist the transaxle into position and move it forward until the input shaft glides into the clutch disc's spindled hole. Do not apply force. Step4 Reinstall any bolts or mounts that were removed to replace your car's clutch. Grab the transaxle, release the jack and lower your vehicle. Step5 Consider replacing your car's clutch cable. If you don't replace the cable at least adjust it for the right amount of free-play. Step6 Confirm that your clutch's self-adjusting action is performing correctly by depressing the slave cylinder's piston into its bore. Step7 Drive your car to be sure your clutch is working properly.
PLease rate and god bless:)
Apr 03, 2009 | 1997 Toyota Corolla
The Times Case Corporation Tractors International Harvestor Logo
840 people viewed this question
Top The Times Toys Experts
ray gallant
Are you a The Times Toy Expert? Answer questions, earn points and help others
