Recalls are only for safety reasons. No one is going to get killed if your car wont shift out of park. There is a fuse, I dont know where you get info from. Usually its the same switch that works the brake lights, if they work, the switch and fuse is good. the shifter is most likely bad, just fix it. You can always call a Salvage Yard and buy a used one, then replace it when it fails again, and again.
If you read my complaint, the one that you replied too you would know exactly where I got my informations sir. I plainly said the owners manual and if you don't want to believe what I'm telling you then get a chrylser 300 touring owners manual and look for your self. However I don't need your help at this point we took our car this morning and it was exactly what I said it was the entire gear box had to be removed and a new one put in simply because chrysler doesnt make the replacment for the pink washer type part available to the consumer. Ther is a tiny spring holding the part in place and you just remove the spring slip the pink thingy off the rod put the new one on and put the spring back in place and bingo its fixed. But chrysler wouldn't make all that money now would they.
So the owners manual doesnt have a fuse diagram showing what fuses are where? So you are saying the brake switch that operates the brakes and the shifter doesnt have a fuse? Fuse number 8 is what works the brake lights, Fuse 44 works the Ingegrated Power Module. You didnt have the entire gearbox replaced, thats the TRANSMISSION. If all you needed was a "pink washer", I'm sure that can be found. Why did you have the whole "gearbox" replaced? I'm sure you mean "shifter assembly" You wanted free advice, and you got free advice, just because you had to pay the dealer, dont get mad at me. I didnt build it, design it, or sell it to you.
Coming from the movie, we tried to move the 300 from park. It would not move! This is extremely ridiculous! Why does some have to be hurt in order for recalls to be granted? It's the same thing is someone is pregnant or gets ill and you need to get them to a hospital. Shame on you Chrysler!!!
Most cars there is a way to Bypass this (so you wont get stuck) I'm not familiar enough with your 300 to say it has one or not. Some cars if the key is turned to ACC you can move the shifer, but not when ON or Running. So you turn key, then shift into Neutral, then start the car, I wouldl ook in the owners manual. Nobody ever reads that!
