Question about Logitech Harmony One Advanced Universal Remote with Color Touch Screen
The number keypad no longer works right. When attempting to change channels using the keypad, only the first number registers - for example, 720 goes to channel 7. Some times I can get additional numbers with multiple presses. Seems like the keypad needs to be cleaned. Is cleaning possible?
    Problem Solver:
  • 6 Answers
Take it back to the store you bought it from and exchange it for one that works for 50 bucks you expect something that works DONT take no for an answer Tell them you called before you drove 50 mile and talked to some associate and they said COME ON DOWN WE WILL EXCHANGE IT NO PROBLEM give no names we dont want to get anyone in trouble. do we?
Posted on Aug 27, 2010
Kitchenaid kebi14bbl2
call the service center for your Kitchenaid. Explain to them the problems with your model #. Sounds like you have to replace the board.
Jan 06, 2014 | Ovens
Why does my LCD HDTV go to a blue screen when changing channels
if using a box it may be normal but not nice, I would suspect the set is a bit slow reacting to signal change. I remember some nasty JVC sets that when going up or down a channel the screen would blank for about two seconds and come on, normal since all those had that feature(no channel surfing)>
Sep 03, 2012 | Vizio 42 in. LCD TV
Keypad numbers no longer work to input/change channels, but the up/down channel changer still works -- how does one fix?
Connect the remote to your computer and launch the software that came with your remote. Chose the device that your having an issue with (I'm guessing the tv) from the devices tab. Click on settings. Customize Buttons. Check at the bottom of the screen if the numbers are in the command column of not. If the are missing provide them. Press done and follow the prompts If that does not fix it. Repeat the previous steps to get back to this screen and choose reset defaults. Press done and follow the prompts
Jul 06, 2011 | Logitech SST-659 LCD Remote Control
Hi, When I push the start button on my prowler 720 control box, it automaticlly goes from green to red. When disconnect the prowler from its control box it stays green. Is there something on the prowler...
The power cord pins are numbered, 1 through 4. So are the transformer plug holes (the female pin holes in the "power pack"). For example, if you don't match number 1 to number 1, the green power light on the transformer will light for about 5 or 10 seconds, but the robot will sit there... well, like a powerless robot. Match the pin hole numbers and you have a working robot!
Apr 22, 2011 | Pentair Prowler 720 Pool Cleaner
Some keys register different characters. For example the O registers the number 6 when it is typed.
This should be a simple fix, look at your keyboard, you should have a function key and if you look at the number pads above the top row of letters there should be either a numerical symbol or a key pad, your keyb board is simply using several keys as an extended numerical keypad. If you look closely at the letters there are small numbers on them. To fix hold down function key and pressing the keypad button. You can also try pressing the number lock.
Al
Aug 04, 2010 | Sony VAIO Notebook
Hello, need to know how i should wire a single 14" sub spk to my ST4-720 ??
havent heard of too many 14" speakers... but it all depends on what ohm the speaker is. single 4 ohm- bridge it on one set of channels. left + right- . if its a dual 4 ohm i wouldnt reccomend using it at all. you could technically bridge each coil on each set of channels. but it may not sound right. kinda hard to set the gains and match them. dual 2 ohm- run the sub stereo. one coil to one channel, the other coil to the other channel. single 2 ohm. dont use it unless you get another sub like what you have. then run it stereo. one sub to one channel. the other sub to the other channel.
Dec 27, 2009 | Sony ST4-720 SPL 4-Channel Power Amplifier...
Can only change the channel to single numbered channels.
Three dash option does mean it will look for three numbers. You would then have to put in three digits, so for example if you want to go to channel 31 then key in the numbers 031, for channel 42 key in 042, If you want a lower such as channel 8, then key in 008. Try this.
Aug 04, 2009 | Televison & Video
Pantech duo voice mail keylock issue
try sending the call str8 to ur voicemail so u will be back into the regular call menu
May 26, 2008 | Pantech Duo Smartphone
Keypad not working when phone in use
There is a button on the left side of the phone which pops up the keypad.( dauden )
Mine registers just fine. (born2shop)
Dec 23, 2007 | LG Prada KE850 Cellular Phone
Logitech Harmony One Advanced Universal Remote with Color Touch Screen Logo
77 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
ka4iup
ka4iup
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
