Front loader GE model GCYH626OHWW cycle stops at the rinse satge. Start button flashes as though it has been put on pause. Pushing the Start button and the cycle continues. Sometimes it stops again with the same syptoms. Also the machine no longer dispenses the fabric softener
  • gweber3 Aug 27, 2010
    i suspect the timer controller but will check the other suggestion.
  • Washing Mach... Master
  • 17,130 Answers
Possible fault with the timer controller unit. But to come back we can start with the program sequence.
1. On switch on does tthe water flow in?
2. If so when the water level is reached does it switch on the motor?
3. If the wash cycle continues and then stops to drain, does the water fully drain out? If not check the drain pump, drain valve, open clean and set.
4.After drain does the watter fill up, If not then the timer is nott allowing the inlet valve to open. Possible fault in timer.
5.If water comes into tub but does not rinse, then the timer does not contact the motor.... possible fault in timer.
So since the cycle stops at the rinse cycle, you can check the drain pump, drain valve and the water level sensor for dirt, open and clean.
If howeverr allthese seems fine then the timer can be the faulty component.
Try to choose another program and see if the fault changes. If so the timer is comfirmed and if you can manage with the working program, decide or estimate cost of new timer.
Hope my advice helps
Posted on Aug 27, 2010
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Front loader stops mid cycle and blinks Er until start button is pressed, the cycle will continue, and sometimes repeats this scenerio three -four times each load. any thoughts anyone?
The control board has detected an error. Press any button to wake the machine then wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously then the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters as long as the buttons are held. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the code for further advice.
Jan 11, 2011 | Frigidaire Washing Machines
Rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Oct 15, 2009 | Washing Machines
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
We purchased a GE front load washer in December 2007. Recently the boot had to be repaired. Now the machine is pausing when it gets to the rinse and spin or drain cycles. The pause light starts to flash. ...
ok Problem is not finding out the meaning of the pause button flashing but.......
you need to contact GE directly as this machine is under warranty.
Follow this link. GE APPLIANCE
If they do not help I will just contact me
Jun 05, 2008 | GE Washing Machines
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
