Need user manual for celestial splt air con KFR 70 GW/K or more importantly how to use remote control. Thank you
3 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: i dont have my celestial KFR-28GW\A remote control
Hi, the best way to tell without the manual, would to be to pick up a anolog thermometer, and insert it into the face of the a/c. This will tell you which setting will give you cooler air temperature. They are very inexpensive, and you can get them at most any hardware store or appliance parts store. This will be useful in your auto a/c, refrigerator and so forth. Best of Luck, and Happy Holidays,
Shastalaker7
Posted on Dec 21, 2009
hvac1960
  • 2133 Answers
SOURCE: i have an celestial air
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Posted on Jan 22, 2011
My Celestial KFR-36GW/C3 has stopped cooling. it just blows air! Please help ASAP!
hate to tell you this... but... it's a valve problem, one that requires depressurization of the freon to replace. Then the air dryer replaced and freon needs to be recharged by a licensed contractor. The intentional venting of freon is against Federal Law IAW the Montreal Protocols on Greenhouse Gas emissions. In some cases, it could be a bad compressor in the exterior unit. A qualified service person has pressure testing equipment to diagnose the problem quickly. (A bad compressor also requires depressurization... licensed contractors have freon recycling equipment.
Jan 25, 2015 | Heating & Cooling
I need to know to do after changing the batteries in my remote control KFR09 Soleus Air P-05-ID-Remote Control KFR-09GW
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Jun 02, 2014 | Soleus Air P-KFR09-05-ID Remote Control...
When i change the batteries the remote control KFR09 Soleus Air P-05-ID-Remote Control KFR-09GW
After battery change, it should be set up with set-up codes to your device again. Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Jan 22, 2011 | Heating & Cooling
Hello, I just have a new A/C Haier machine KFR-72GW/03EAF13. When working it keeps blowing air and never stops even when fixed temperature is reached. How can I set the sleep mode ? this is usually...
You please go with site in where you can get different launges of manual and your remote model user's guide.
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html
Dec 21, 2010 | Haier Heating & Cooling
I cannot operate my Celestial A/C with the remote
It only mean that the remote receiver of the A/C is not
working, it have to be replaced. May this info help
you.
Jan 06, 2010 | Heating & Cooling
I dont have my celestial KFR-28GW\A remote control
Shastalaker7
Dec 17, 2009 | Heating & Cooling
Celestial split system air conditioner
I am a repair man and have had this problem quite a few times, check that the remote is set to heat and 30 degrees.usually a symbol like the sun,very similar to cool easy to mix up.If the a/c is set to heat the indoor fan will not start till outdoor unit has heated coil.
Jul 16, 2008 | Heating & Cooling
Heating & Cooling Logo
162 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
