Question about Canon PowerShot A480 Digital Camera
I dropped the camera while it was on & now the lense stays open and when i press on the camera makes noise & says restart camera & that there is an erorr
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 27, 2010
I dropped my camer while the lense was out...and the lense stayed out.. can this be fixed?
Try reset all in camera menu or remove battery & reinsert or contact Fuji for exchange or repair.They sometimes go back on their own if you turn power on & off try gently twisting/pushing lens but be gentle with it.
Aug 12, 2010 | Fuji FinePix F30 Digital Camera
Hi, i dropped my a560 the other day and the end part of the lens bent a little but i managed to put it back in its original form. however when i press the power button the lenses whirrs and tries to open...
sounds like when you dropped it it damage the gears in the camera that make the lens not work properly , you may want to take it and get it fix by the maker of the camera sorry.
Nov 29, 2009 | Canon PowerShot A560 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
I DROPPED MY KODAK CAMERA WHILE THE CAMERA WAS ON
If you pressed it too hard in, you most likely damged some other parts in addition to the damage caused by dropping it. You need to take out the lense, inspect all the moving parts. Look for broken or bented part. The opened lense should mover up and down easily. Make sure all parts are clean and put the lense back on. Good luck!!!!!!!
Jun 09, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
My sony camera displays Turn camera off and on again
I had exactly the same problem with my Sony Cyber_Shot. Here is what I did and the problem was fixed. While I turned the camera off, I pressed down the lense very softly (some up and down motion). After a couple of times, the lense retracted almost completely. Then I pressed a little harder until the lense retracted 100% as normal times. I turned it on everything was back to normal. If the lense does not have mechanical problem, you should be able to do what I did.
If there is no mechanical problem, most likly some dirt got on the sides of the lense while it was open. Try keep it very clean always.
Good luck;
Jun 09, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Lense stays open, when i press power light blinks and nothing happens.
help me
my lens is open and extended and when i power it up the light blinks and makes a noise and powrs back down
May 17, 2009 | HP Photosmart M447 Digital Camera
Lens won't in on camera and makes clicking sound.
When you dropped your camera, some dirt got on the outside of the lense or some mechanical part of the lense broke or dislocated. If some of the mechnical part of the lense is damaged, you need to open up the lense from the camera and inspect the parts. Look for loose parts, then clean it and put it back.
I had the same problem with my sony Cyber-shop, but it was not dropped. somehow one or more small piece of dirt got on the outside of the lense. Here is what I did and the problem was fixed for good.
While turning the camera off, I pressed on the lense (up and down motion) softly. After a few times, the lense retracted 95% of the normal retracted position. I then, pressed the lense a little harder in untill it was fully retracted. It has been working okay since then.
You should always keep the outside of the lense clean and do not drop it.
Good luck
Oct 11, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
How do you fix 'lens error restart camera' I put it in my bookbag. I guess i threw my bookbag around and now i have this "lens error, restart camera." The lens froze halfway and it's staying that way....
It sounds like. You really need to have some one take it apart and clean the sand out of it. The camera will make those noises when the sand gets between the gears of the lens assembly and they cant connect correctly.
ou could try helping the lens go back in GENTLY. But thats risky and you could ruin a lens that would work just fine if it where cleaned out.
let me know which model and brand you have and I could tell you better whether or not you should try anything your self.
goodluck,
Caleb
Jun 30, 2008 | Cameras
Lens stuck help anyone
if you feel that the camera is making effort to extend the lense out and the lense is still jammed, get the help of a repairer.
Sep 15, 2006 | Sony Cyber-shot DSC-W70 Digital Camera
Canon PowerShot A480 Digital Camera Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
