Question about Toys
The wife took off the cloth seat to wash and now I'm trying to figure out how to reinstall the straps onto the seat.It is model# 3791686 p1
SOURCE: carseat harness straps
You have to unloop the straps from the gold metal bar. This will allow the straps to be free so you can feed them thru the holes and re-feed them into the proper height hold. You will than noticed that there are loops at the very end of the straps which you can loop back onto the gold metal bar.
Posted on Dec 01, 2007
momsjustknow
  • 149 Answers
SOURCE: car seat instructions
Here is the link to the online manual for the 2007 Perego Car Seats. give it a few seconds to load. It will be a white page while it loads.
http://www.pegperego.com/pegcatalogue/juvenile/downloads/PrimoViaggioSIP-US_FIUS0603I61.pdf
Follow the remove instructions in reverse. It is difficult to describe, but the pictures are very helpful.
Good Luck! from Moms Just Know
Posted on Oct 24, 2008
  • 20 Answers
SOURCE: Need help reassembling the straps after washing the seat cover
First turn seat upside down. There should be a slot on each side under the seat, run strap through each slot and turn back over. Pull strap up evenly, put on clasp part on each side, then put chest clasps on, run your straps through back and secure to strap comes between legs.
Posted on May 08, 2009
SOURCE: I took the straps off my Brevi Childs car seat to
Hi I am looking to buy a Brevi Universal car seat cover and the straps as well what web site should i be looking on???
Posted on Jul 29, 2009
SOURCE: harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Posted on Sep 09, 2009
I am looking for an owners manual for a Dorel Car Seat Model #22-120. I took the cover off to wash it and now I can't figure out how to re-thread the straps!
Try their site or call them
http://www.djgusa.com/usa/eng/Carseat-Selector
Find your seat, click on it and at bottom is an Instruction manual link.
or call
Dorel Juvenile Group
Consumer Relations Department
P.O. Box 2609
Columbus, IN 47202-2609
Phone : (800) 544-1108
Mar 05, 2011 | Dorel Baby Gear
Looking for instructions for assembling a costco car seats straps
Go to this website and type in your car seat info. If they do not have the manual, I would call the manufaturer's number located on your car seat.
http://www.coscojuvenile.com/Instructions
GOOD LUCK!
PS I just took my car seat apart to wash the cloth material and found the easiest way to reassemble it was to remove the base during install of the straps and then replace the base.
Jul 03, 2010 | Cosco High Back Booster 22-200 /22-207
I have a Cosco car seat model # 02-848-BNG. I took the seat apart to wash it and can't figure out how to put the straps back on properly. Please help me. Thanks Penny
I went to the Cosco website to get a manual for you and they also need a date of manufacture. If you can obtan this, here is the link to type in your model and date. I expect the manual will help you in the strap reassembly.
http://www.coscojuvenile.com/usa/eng/Instructions
Hope this helps... Good luck!
Sep 16, 2009 | Baby Gear
Britax boulevard harness installation
Scroll down this page, someone was kind enough to take pictures.
http://www.car-seat.org/showthread.php?t=21629
Dec 08, 2008 | Baby Gear
Evenflo car seat
1. Remove the cover on the back upright (8 phillips screws).
2. Remove the white plastic clips that retain the brass clip holding the shoulder straps in place.
3. Pull the brass clips away slightly, then, turn them and push through the slot where the shoulder straps go through to the front of the car seat.
4. Pull the straps through the lower seat cushion slots.
5. Wash and reverse steps above to put back together.
Jul 27, 2008 | Evenflo Generations
I took the cover off to wash it but now can't figure out how to put it back on. I think it is a 5 point connection system model 8465wsr3
Its a GREAT seat! I have the same one!
Assuming you removed the harness.
The easiest way I have found to do this is , place the seat on the ground and put the cover on the seat. There are some elastic fastners that are loops on some models, that go onto small plastic poles. IF you don't have this, it is ok.
Then clip the harness together at the chest clip, and at the buckle. This helps you not get so twists.
Put each of the top shoulder straps through the hole in the seat cover AND the plastic of the shell of the seat. For this rear facing seat, the straps should be At or BELOW the shoulders of the infant riding in the seat. When both straps are through the plastic shells, you slide them onto the metal flat mushroom shaped piece on the back of the seat that is attached to the adjustor strap.
Pass the middle strap (the buckle) through the hole in the seat cover and shell. Pull to ensure it catches.
NExt, take the small metal cliped bottoms of the harness, and pass them through the seat cover and seat shell in the bottom of the seat, they are in the crease of the side/bottom of the plastic shell. Once they are passed through, give them a good pull to ensure they catch. Repeat for the other side, and you are good to go!
If you washed the harness, in the machine, it needs to be thrown out, call Graco for a replacement.
Jun 17, 2008 | Graco SnugRide - Giselle Infant Car Seat
Washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Jan 08, 2008 | Baby Gear
Carseat harness straps
Sep 23, 2007 | Baby Gear
Garage Sale Car Seat
If you push down on the top of the handle you should then be able to move it. Also, to remove the straps you have to feed the bottom portion of the straps from underneath the seat up through first and then you should be able to feed through the material to remove the pad.
Aug 18, 2007 | Evenflo PortAbout 5 Infant
Toys Logo
23 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
