Question about Hitachi Televison & Video
I have a 70' rear projection Hitatchi. the colors are no longer algined. how do i fix this
  • Hitachi Master
  • 8,617 Answers
You will need to install the convergence repair kit for that chassis. www.tvrepairworld.com should have the repair kit you require.
Posted on Aug 27, 2010
70 rear projection jvc no picture and bulb ok
Hello, remove the lamp and make sure it didn't go bad. If it's ok the a color wheel or fan would be my next guess, but check the lamp first, I see cheaper lamps that don't match up correctly fail early. let me know what you find...tks
Feb 24, 2015 | JVC HD-70FH96 70" Rear Projection HDTV
I have a 52 inch hitatchi rear projection tv and it now has a blue streak down the middle. How do I fix this?
usually the lamp unit causes this. however it can be the projection unit. replace lamp unit with used one to save on trouble shooting
Jan 01, 2010 | Hitachi 50UX57B 50" Rear Projection...
What are the best video settings for a Hitachi (46GX01B), 46 inch, rear Projection TV (from 2001) in regard to: contrast,brightness, color, tint, sharpness, etc. The setting level goes from 1% to 100%....
The best setting are the ones you prefer the most.In general most sets are optimized for 50% on color and tint and usually 70% or more for bright and contrast.
Nov 08, 2009 | Hitachi 46GX01B 46" Rear Projection...
Hitatchi 52" rear projection TV has blue spot in middle of screen
Hello :
I suggest u retrace you the steps u took to replace your lamp make sure no foriegn objects got on the prism where the light shines throung the optics engine, if you remove the lamp compartment througly. If you had a perfect picture prior to replacing the lamp, then retracing your steps you might find something that does not belone. One final note: Did you purchase the right lamp 120watts anything higher than this wattage could damage your optics engine. I suggest never vacuuming the compartment because particals fly around from the suction and could get on the glass of the color wheel asembly.
Sep 25, 2009 | Zenith D52WLCD 52" Rear Projection...
Color alginment is off
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 20, 2009 | Philips 60PP9202 60" Rear Projection...
Hitatchi ultravision 70 in rear projection
Its too simple to do in Java.
Accept String from user through appletviewer.
Use Concept of String .
From Begining fetch on by one character of that String.
now apply Sleep(700) by implementing Thread class.
Inside sleep(700) block simply display each character.
SATYA PRAKASH (INDIA)
satyaprakashjsr@gmail.com
09304850882
Feb 12, 2009 | Hitachi 50UX58B 50" Rear Projection...
I have a Hitachi 50V500A LCD rear projection set. It is 4 yrs old. There is a streak of Blue color running down from top of screen to the middle of the screen. I have changed the bulb but it has not...
This is a very common problem with your model. My best advice is to have a hitatchi authorized service center come out and give you an estimate then call Hitachi and complain to them about the problem. They will useually supply the part for free and you will only have to pay labor to put it in. A good shop will run you $300-$400 to put it in for you.
Oct 28, 2008 | Televison & Video
Hitatchi ultravision 53" rear projection lcd tv
You have a problem with the optical engine- The only repair would be to change the engine for about $500-$1,000 plus labor. This is a major repair (sometimes caused by dust particles getting on the LCD panels inside the engine, but disassembling the engine to try and clean it is not a reasonable option)
Aug 21, 2007 | Hitachi 60V500 60" Rear Projection...
Convergence
you have bad convergence ics
Apr 13, 2007 | Toshiba TP61H60 61" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
