Question about CDV Software Blitzkrieg for Windows
Trying to run Blitzkrieg 2 on Windows 7. Getting an "internal error when accessing one of the application's libraries" so can't get it running. Any help from my friends?
  • 30 Answers
Llk
Posted on Aug 27, 2010
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
Blitzkrieg will not work on windows 8.1
Blitzkrieg is a B***h of a game to get working on anything after XP
I own a copy myself and on windows 7 it runs really fast and the graphics are all over the place.
Unfortunately I dont think you can get it working unless you mess with the compatibility settings.
Nov 23, 2013 | CDV Software Blitzkrieg Anthology for...
How can fix microsoft visual c++ runtime library
Which program is it?
This is what I did.
1. Turn On PC as normal
2. Wait for prompt error to show up
3. When it appears, Run Task Manager (here you can see the task running the Error Prompt)
4. Right Click on the task and Choose > Go To Process (will take you to processes Tab)
5. See the highlighted Process, Right Click and Choose Open File Location
6. Windows Explorer will appear and you can see the Application Folder (name of application)
In my case, a 'browser toolbar application' was trying to auto initiate itself
7. Open Uninstall Programs > Search for Application Name > Uninstall (NOTE: PLEASE DO NOT UINSTALL IF THE PROGRAM IS A CORE FILE like Windows related program)..
8. Restart PC.....its gone :)
Another alternative:
Do a system restore. Click start > program > accessories > system tools > system restore.
Restore it to a known good date when your computer was fine.
I hope this helps.
Carlo
Nov 28, 2012 | Computers & Internet
Have a hp xw9300 , trying to load software from ge ( anaconda) and getting kickstart errors and ioerror errno 2 ) no such file or directory: '/tmp/part-include. system was setup just exactly like
are you running Linux or a windows operating system? if running windows you will need a software named Linux Reader, a free Windows application that emulates the look and feel of the Windows XP Explorer and allows read-only access to ext2 and ext3-formatted drives
Oct 15, 2012 | HP xw9300 Workstation PC Desktop
Hi I bought the game blitzkrieg 2 and installed it to my computer but when i hit the play button there's in error sign that reads as follow Internal error when accessing one of the applications libraries...
maybe there is something error occured when the installation take place. Make sure that the application is safe from virus and scan it. Then, re-install it for better action. Hope I help.
May 12, 2010 | CDV Software Blitzkrieg for Windows
Http/1.1 internal server error
If you are running two versions of ASP.NET, you may get HTTP:/1.1 500 Internal Server Error when creating a new Web project or opening an existing Web project in Visual Studio.
This problem may occur when IIS is not sure what version of ASP.NET to use or where to locate ASP.NET files. One of the following solutions should fix the problem.
Solution 1.
  1. Remove web.config file from inetpub/wwwroot directory
  2. Go to IIS, Right click on Default web site / All tasks / Check server extensions and let it run
  3. Reset IIS by right click on IIS or call iisreset from Run command
Solution 2.
  1. Install ASP.NET again using the following command from your Run command: C:WINNTMicrosoft.NETFrameworkv1.1.4322aspnet_regiis.exe
    Make sure to change the windows folder and ASP.NET version folder with the version what you want to install
  2. Reset IIS
Solution 3. Applies to Windows Server 2003
Note: This is a Microsoft KB article:
When you try to create a new Microsoft ASP.NET 1.1 application after you change the script mapping of the existing ASP.NET 1.1 Web application to ASP.NET 1.0 on a Microsoft Windows Server 2003-based computer, you may receive the following error message:
The Web server reported the following error when attempting to create or open the Web project located at the following URL: 'http://localhost/822319ev1'. 'HTTP/1.1 500 Internal Server Error'.
CAUSE
This issue occurs because Windows Server 2003 does not allow two versions of ASP.NET to run in the same application pool.
WORKAROUND
To work around the problem, do one of the following:
Restart the IIS before you create a new ASP.NET 1.1 application. At the command prompt type the following command: iisreset
OR -
Create an ASP.NET application in a separate application pool. Create the script-mapped application (ASP.NET 1.0) in a separate application pool -- for example, in the ScriptMapappPool application pool. Then, create a new ASP.NET 1.1 application in an application pool other than ScriptMapappPool. For more information about how to create an application pool, visit the following Microsoft Web site: Configuring Application Pools http://msdn.microsoft.com/en-us/library/1kdfe21k(VS.80).aspx
Dec 10, 2008 | Acer Aspire 5610 Notebook
CDV Software Blitzkrieg for Windows Logo
1,455 people viewed this question
Top CDV Software Video Game Consoles & Games Experts
James Wishart
comandomcl8
Level 1 Expert
Bill Boyd
Are you a CDV Software Video Game Console and Game Expert? Answer questions, earn points and help others
