Question about Thermador Ovens
When I push the bake control it shows up off on the oven control viewer and nothing happens when I push the increase temperature button except off goes out
  • pjcoats Aug 27, 2010
    Really didn't help tp solve the problem
  • 10,865 Answers
Hello. The touch pad on your oven will have to be replaced. J.
Posted on Aug 27, 2010
  • 3,083 Answers
Here is a blog about a high temperature control switch, which could well be your problem:
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/11535-thermador-double-oven-no-heat.html
No model number to work with, so this blog in for a Thermador, and should apply to your appliance.
This following website has a lot of neat diagrams for appliances, and will hopefully help you:
http://www.repairclinic.com/Range-Stove-Oven-Repair-Help
Good luck, and thanks for using FixYa.
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
Oven won't start
Try pushing the "convection oven" or "bake" button first, then enter the temperature you want. Then "Start".
Sep 24, 2012 | Thermador SC272T Electric Double Oven
My oven keeps beeping F2 and it won't turn off. The top broiler coils are bright red and heat is pouring out of the oven. I have held down the off button, pushed start, pushed bake, anything I can think...
Control senses oven temperature above 615F-630F. shut down the breaker switch asap.
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jul 08, 2009 | GE JGRP17 Gas Single Oven
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Sep 25, 2008 | Ovens
Jenn_Air Oven Problem
HI thanks for your question. A common problem with gas ovens is that the oven will not get hot enough. and the part that's at fault is the ig niter. replace the ig niter. thanks the appliance doc. please rate my answer. thanks.
Aug 31, 2008 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
57 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
