Question about Sharp AR-160 Copier
Trouble code how can i fix H4 error code in my copier machine. plz help me.tnx
    President:
  • 2,072 Answers
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
Posted on May 06, 2008
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Copier displays H4 error code and would not copy
detail for error code H4: Fusing section low temperature trouble
•The set temperature is not reached within the specified time (normally 3 min) when warming up or resetting from pre-heating. Cause:
  1. Cause thermistor trouble
  2. Heater lamp trouble
  3. Control PWB trouble
  4. Thermostat trouble
  5. AC power trouble
  6. Interlock switch trouble
Solution:
  • If the heater lamp blinks normally:
  1. Check the thermistor and its harness.
  2. Check the thermistor input circuit in the
  3. control PWB.
  • If the heater lamp does not light:
  1. Check for heater lamp disconnection and
  2. thermostat disconnection.
  3. Check the interlock switch.
  4. Check the AC PWB and the lamp control
  5. circuit in the control PWB.
good luck
Oct 13, 2010 | Sharp AL-1457 Black and White Copier
Error code H4 sharp AR-203E
plz help me my prenter sharp ar203e h4 error plzzzz
923002503009
tofiqueali.ss@gmail.com
Oct 09, 2010 | Sharp Office Equipment & Supplies
Problem for Sharp AR-5320 Black and White Copier Ar 5516 display H4 error?
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Aug 22, 2010 | Sharp AR-5320 Black and White Copier
Display panel h4 code any clues?
This error is displayed when the Fixing heater has not reached normal operating temperature after a specified time.
It is usually a blown heater element.
You will need a technician to repair this.
May 01, 2010 | Sharp AR-235 Copier
Dispays h4 error
An H4 error code indicates trouble in the fusing section - a certain temperature has not been reached within a specified time. It could mean a dirty/bad thermistor or dirty/bad thermostat (both inside the fuser unit. Make sure both of these are clean and there is not debris/paper stuck inside the unit.
You can try resetting the code by : Get into SIM mode by pressing the following keys one after the other "#" "interupt" "C" "interupt" then enter 14 and the start key - confirm if requested then make sure the copier restarts.
Hope this helps.
Apr 18, 2009 | Sharp AR-5320 Black and White Copier
Irc2105
There is no such error 'E215-0000' in ar 5320, for H4 use "#, Interrupt, C, interrupt. Display goes off, Enter 14, Press Print key.
Apr 08, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
H4-00 Error Code for Sharp AR-168D
Your Tech is correct in replacing the Unit.
If the Fuser is not reaching the correct Temp it will give the H4-00 Code
The time and money it takes to repair the unit is greater than replacing.
Oredering all the parts for the unit takes longer then ordering the unit.
The only thing a tech can do is clean the Thermistor, reset with sim 14..
If that works, it might work for a hour, might work for days?
I personally carry this Fuser Unit in my car stock as this happens frequently..
Good luck
Oct 22, 2007 | Sharp AR-235 Copier
Sharp AR-160 Copier Logo
192 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
