Linksys Wag354G v2 keeps disconnecting from the internet
    Novelist:
  • 173 Answers
Make sure that the latest firmware is installed on your ADSL2+ gatewayand make sure that you select the correct modulation based on your ISP's recomendation, you can check those settings by accessing the configuration page of the device using your browser(IE/Mozilla/Safari), the default IP address is 192.168.1.1 username and password is "admin" here's a link for the user interface of the router.
http://ui.linksys.com/
oh also check if your micro filter is still working properly sometimes that will also cause the connection to drop if it's also ready failing.
hope this help you solve your connection problem
Posted on May 06, 2008
I lost the cisco program cd for wusb100 v2
Go to Linksys website and download the drivers for the adapter
Jan 26, 2012 | Computers & Internet
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
Dec 23, 2010 | Linksys Bundle: BEFW11S4 802.11b Wireless...
I get message says ( you're connected to the access point, but can Not find the internet ?
What is your OS?
The table shown below lists all Linksys adapters that will work with a Windows Vista environment.
I wonder if your OS is Win XP.Post back!
Minimum Requirements
• 400 MHz or Faster PC
• 256 MB of RAM Memory
• CD-ROM Drive
• Avaliable USB Port
• Microsoft Windows 98SE, Me, 2000, and XP
WUSB54GSC version 2.0 is compatible with Microsoft Windows XP, Vista 32 / 64-bit edition with latest updates and Windows 7 32 / 64-bit edition with latest updates
Product
Driver Vista 32 Vista 64 PCMCIA WPC54G V1 3.100.64.0 OK WPC54GR 1.0.3.0/2.0.1.9 OK WPC54GS V2.1 4.100.27 / 3.100.6 OK WPC55AG V1.3 4.1.2.38 / 7.1.0.9 OK WPC100 OK OK WPC600N 4.150.31.0 OK WUSB WUSB54GC V3 OK OK WUSB54GSC 4.1.20.0 OK WUSB54GSC V2 4.118.4.0/4.170.61.0 OK WUSB54GR 1.0.2.0 / 3.0.1.0 OK WUSB100 OK OK WUSB100 V2 4.9.9046.1 OK OK WUSB300N 1.0.7.2 / 1.0.3.2 OK WUSB600N 1.1.0.0 / 2.1.4.0 OK OK WUSB600N V2 1.4.4.0 / 2.3.4.0 OK OK
Dec 07, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Cant connect to the internet with linksys wrt160nv2
if this is DSL connection then you have to configure your modem before you connect router
follow this
first disabled wireless on your modem/router
.1) Turn off DHCP on your modem/router I am assuming this is verizon westell
2. Configure the first VC port to Bridge-Bridge mode
3. Keep hitting "apply" in the windows until the 7500 reboots
4. Plug the "Internet" port on the linksys to one of the normal ethernet ports on the modem /router
5. Turn on the Netgear and wait for the green Internet light to go solid
good luck if this does not work provide more info on your setup
Jun 12, 2009 | Linksys WRT160N Wireless Router
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
Wag354g
From the pieces I am gathering I cannot see how to replace the supplied modem/whatever from BellSouth with the modem in the WAG354G (I see no identification of the required configuration options) however we may be able to use only the lan side of the device as an access point connected to the modem device supplied with the DSL service from BellSouth. In order to do this you will need to provide the manufacturer (Alcatel, Netopia and Westell are three possible manufacturers) and model number of the device provided by BellSouth -- it appears they have 4 or more. I may be able to determine some options based on what you provide. I believe the Vista compatibility issue for the router is not related to usability but some special configuration software that can be bypassed using the following web-based approach.
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4280&p_sid=OLWdxSTi&p_lva=4240&lid=9091191710B08#
The preceding should get us access to the wireless configuration if needed as follows
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4240&lid=9091191710B08
Dec 22, 2007 | D-Link DGL-4100 Router (DGL4100)
My router keeps disconnecting the internet
a blinking power light suggest that the device is already broken. Go to the command prompt and ping the roouter. If you can still ping it then i suggest to upgrade the firmware of your router.
Oct 27, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Can not share internet connection with WAG354G
Right click on my network connections and click on properties.There u have ur wireless connection showing.Right click on it and click on properties.Click on advanced tab.There u have Internet connection sharing BOX.In this box u have two options.Check the first connection and click on OK button.A small window appears click on yes and ur internet sharing started.After this on the other network card use the other series of ips from the wireless connection.If any problem persist ask me.I am here for help.
Regards,
Sandeep
Oct 25, 2007 | Computers & Internet
Computers & Internet Logo
786 people viewed this question
David Payne
David Payne
