Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Top drawer retains about 2 inches of detergent water and dishes don't come out clean (sometimes). It also makes a loud noise during wash cycle. Drain hose is not kinked.
  • Fisher and P... Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Aug 29, 2010
I have a DS601 v2 dishwasher drawer that has suddenly stopped cleaning the dishes. The drain filter isn't completely emptying either. I've taken all the parts out and cleaned them bit this made no...
There are a few things that can cause this.
If there are no error messages being displayed during the cycle, the most common ones are:
1) Loose Impeller on the motor rotor. Check it by removing the drain filter, dish rack, spray arm and main wash filter (the giant stainless steel circular one), then twist the motor to the left and it should just pop out. If you hold the bottom of the motor in one and and the larger impeller on top freely spins, this is your problem.
2) Crack in the side of the spray arm. If the spray arm is separated, then the water pressure will being spraying sideways, rather than up to your dishes.
3) Too much fat or protein built up inside. This happens when you put too much eggs and milky stuff in there. Just run it for a cycle with detergent but no dishes. DO NOT use one of those dishwasher cleaner things in a dish drawer, they do more harm than good due to the fact that they are designed for a dishwasher with double the capacity of yours.
Mar 16, 2013 | Dishwashers
I have a Kitchen Aid 2 drawer dishwasher and its about 2 years old. My problem is the top drawer will not drain during wash cycle. The bottom drawer drains fine. model number KUDD03DTSS 10
You may have clogged pump to the drawer. open drawer, lay on your back under the dish drawer, removed the black cover (3 screws) remove 2 screws to the pump and allow the water to drain out into a bucket or bowl. make sure the pump can turn easy. Reassemble and test unit again. If fails, replace pump.
Pump
I hope this helps, good luck
Aug 14, 2011 | Dishwashers
Not cleaning dishes.
check if some dirt got in the arms of the washer as sometime this will slow the flow of water and not allow the pressure to clean the dishes well
May 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Doesnt clean dishes, seems to be no water coming into machine
There should be about 2 inches of water in the bottom of the DW.  If it is filling but not washing the pump may be bad.  That might explain the loud noise (motor bearing).  I assume that the detergent cover is opening but no water is being sprayed to dissolve it.
May 31, 2009 | Dishwashers
Dishwasher not cleaning the dishes
Hi there. Here are some solutions that may help you combat this issue with the non cleaning of the dishes during the wash.
• Choose another cycle for longer washing
time.
• Check rack loading section for proper
loading—avoid nesting items.
• Home water pressure may be too low—
should be 20 to 120 pounds per square inch
(psi).
• Check incoming water temperature. It
should be at least 120°F (49°C). (See
Factors Affecting Performance.)
• Check water hardness. For extremely hard
water, it may be necessary to install a water
softener. (See Detergent Chart.)
• Use fresh detergent.
• Check to make sure funnel in top rack is not
blocked.
• Make sure items are not blocking the spray
arms, preventing them from rotating.
• Check to see if the rinse aid dispenser
needs refilling.
Next, you mentioned in your text that you were experiencing a burning scent after the was or during it. i have a few solutions for that as well.
• Soiled dishes left in dishwasher too long can
create an odor. Use Rinse & Hold cycle.
• There will be a "new" smell when first
installed. This is normal.
• Check to see if unit is draining properly.
One more thing, sometimes food or plastic dishware will fall between the spaces in the basket that holds the dishes. these plastics can be burned by the heating element inducing a burning scent during the drying process. always make sure that all plastics are secure before you start the cycle. food can get stuck on this heater element as well causing a burned smell.
Feb 15, 2009 | Dishwashers
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Buzzing noise and won't clean
An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.or may be its due to
Heater fanIf the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Jul 16, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
203 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
