Question about Jenn-Air JES8850BA Electric Kitchen Range
Clock and oven light comes on when burner control is turned on.burner does not heat up.
  • 139 Answers
Unplug range ..remove the back panel on the range..1/4 in srews need to be removed to see all them wires ..one of them is burnt together i bet causing this to happen ..if not the switch is bad /or the burner socket /burner .use a flash light to see sockets look good all connections all switches ..let me know /joe
Posted on Aug 27, 2010
My Frigidaire electric range wont work (burners and oven)
The clock display works on 120 volts but the burners and oven require 240 volts. I would check the breaker or the receptacle to see if they're bad.They may be supplying only 120 volts. One more less common problem could be the terminal block on the range where the power comes in. Very rarely they will melt. BE SURE TO UNPLUG THE RANGE if you have to check the terminal block. Hope this helps.
Feb 12, 2013 | Frigidaire Ovens
We recently moved, when we got to our new house we plugged in our stove. We turned on the burner and it didnt work, we tried the other three and they didnt work either.. Finally we tried the oven but there...
i would first try the breaker it sounds like you only have half the power coming to unit and the light and clock will work but the heating componets will not as they require the full 220-245 volts
it sounds very odd that everything as far as burners and elements are out but you have a clock display and light... you have lost one of the legs of power somehow...either the double breaker is not fully on and may require turning off oven breaker and resetting or half the breaker has failed... a sure way of testing would be to pull out and with a volt meter test to see that you have 220-245 volts coming to oven,,, hope this helps out repost if anymore questions...
Feb 07, 2011 | Amana Kitchen Ranges
Kenmore model number 91193412000 burners went out
Its almost impossible to tell you how to repair it without being there to view what is going on. by what you are saying, it looks like you have a short between two or more wires, possibly stuck together from heat. After switching off, remove cover at the back and follow the wiring to the clock and the burner switches and look for anything obvious. Look for a wire possibly burned off and leaning onto another electrical wire.
Jul 19, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven comes on and hits the temp and turns off
Unplug your range. Then open the control panel and remove and re-install all the wires one at a time.
Sounds like a loose connection.
If that does not correct the problem replace the electronic control.
Feb 27, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Oven not heating and oven control lights not working
Check if the oven is in AUTO cook mode. It should be in MANUAL cook mode , check if it has a MANUAL mode button. Sometimes resetting the clock will put it back into MANUAL mode.
Nov 05, 2008 | GE JBP25 Electric Kitchen Range
Burners and oven wont get hot and light wont come on
The input power is incorrect. The neutral connection may be missing
May 22, 2008 | GE Profile JTP18 Electric Single Oven
Element light is on but no heat from the burners
You only have voltage coming in on one leg of the 240 line. Either the terminal block connectors are loose or burned or you need to check the circuit breaker in the house and reset it. It is also possible that one of the wires burned off in the back of the unit between the terminal block and the clock.
Jul 20, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Jenn-Air JES8850BA Electric Kitchen Range Logo
29 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
