Question about Whirlpool Accubake SF362LXTS Kitchen Range
Shorting out - Whirlpool Accubake SF362LXTS Kitchen Range
  • 139 Answers
Un plug the range ..remove the back panel ..1/4 in screws..look at all them wires inspect all wires for burnt wires/connections ...check the bake element is it burnt ..look around where it exploded to see what happened ..wright down model and serial #s ...call local appliance parts store or local used appliance store to save $ let me know if i can help more ..good luck/////////////////joe/
Posted on Aug 27, 2010
999 injection relay tick continuously when turn to on
found on the net
Listed below are the Ducati error codes for the 999/749 series which are very handy to know...
If your stead decides to create an error and then flashes her yellow warning strobe (the EOBD light) then follow these steps....
1) Turn the ignition to 'OFF' (Whilst stationary that is.... )
2) Depress and hold the left hand instrument panel button
3) Turn the ignition to 'ON' whilst still depressing the left hand button
4) You should then see the error codes displayed
5) Make a mental note of the codes and cross reference with the following list.........
ERROR CODES
1.1 = Throttle Position Sensor (TPS) Disconnected
1.2 = Throttle Position Sensor (TPS) short circuit to earth
2.1 = Pressure Sensor short circuit to power supply
2.2 = Pressure Sensor shorted to earth
3.1 = Water Temp Sensor shorted to power supply
3.2 = Water Temp Sensor shorted to earth
4.1 = Air Temp Sensor shorted to power supply
4.2 = Air Temp Sensor Shorted to earth
5.1 = Battery Hi
5.2 = Battery Lo
10.1 = Horizontal Coil shorted to power supply
10.2 = Horizontal Coil shorted to earth
11.1 = Vertical Coil shorted to power supply
11.2 = Vertical Coil shorted to earth
12.1 = Inj1 shorted to power supply
12.2 = Inj1 shorted to earth
13.1 = Inj2 shorted to power supply
13.2 = Inj2 shorted to earth
14.1 = Inj3 shorted to to power supply
14.2 = Inj3 shorted to earth
15.1 = Inj4 shorted to powersupply
15.2 = Inj4 shorted to earth
16.0 = Pump Relay
17.1 = L/H Fan shorted to power supply
17.2 = L/H Fan shorted to earth
18.1 = R/H Fan shorted to power supply
18.2 = R/H Fan shorted to earth
19.1 = Starter Solenoid shorted to power supply
19.2 = Starter Solenoid shorted to earth
30.0 = ROM/Eprom error
34.0 = Signal Panel Sensor
36.0 = Speed sensor
37.0 = Immobiliser (transponder)
37.1 = Immobiliser (antenna)
37.2 = Immobiliser (instrument panel serial driver)
37.3 = Immobiliser (serial cable disconnected)
37.4 = Immobiliser (ccm serial drive)
37.5 = Immobiliser (key not recognised)
37.6 = Can Line error
__________________
May 17, 2014 | 2003 Ducati 999
Tip
Ducati Fault Codes
Engine Fault Codes - Ducati 749/999
To see the fault codes, with the ignition off hold both dash buttons down and turn ignition on.
1.1 TPS Disconnected
1.2 TPS short circuit to earth
2.1 Pressure Sensor short circuit to power supply
2.2 Pressure Sensor shorted to earth
3.1 Water Temp Sensor shorted to power supply
3.2 Water Temp Sensor shorted to earth
4.1 Air Temp Sensor shorted to power supply
4.2 Air Temp Sensor Shorted to earth
5.1 Battery Hi
5.2 Battery Low
10.1 Hor. Coil shorted to power supply
10.2 Hor. Coil shorted to earth
11.1 Ver. Coil shorted to power supply
11.2 Ver. Coil shorted to earth
12.1 Inj1 shorted to power supply
12.2 Inj1 shorted to earth
13.1 Inj2 shorted to power supply
13.2 Inj2 shorted to earth
14.1 Inj3 shorted to power supply
14.2 Inj3 shorted to earth
15.1 Inj4 shorted to power supply
15.2 Inj4 shorted to earth
16.0 Pump Relay
17.1 LH Fan shorted to power supply
17.2 LH Fan shorted to earth
18.1 RH Fan shorted to power supply
18.2 RH Fan shorted to earth
19.1 Starter Solenoid shorted to power supply
19.2 Starter Solenoid shorted to earth
30.0 ROM/Eprom error
34.0 Signal Panel Sensor
36.0 Speed sensor
37.0 Immobiliser (transponder)
37.1 Immobiliser (antenna)
37.2 Immobiliser (instrument panel serial driver)
37.3 Immobiliser (serial cable disconnected)
37.4 Immobiliser (ccm serial drive)
37.5 Immobiliser (key not recognised)
37.6 Immobiliser (ccm program)
38.0 Can Line error
Source http://moto-files.weebly.com/ducati-fault-codes.html
on Dec 20, 2016 | Motorcycles
3 log beeps on power on
Gigabyte doesn't list 3 long beeps as an error code, so I'm not sure if you're actually getting 3 short beeps or maybe 1 long and 2 short or... But, for reference, Gigabyte's error code list is as follows (depending on whether you have an AWARD BIOS or an AMI):
(AWARD BIOS)
1 short beep: System normal
2 short beep: CMOS Error
1 long beep and 1 short beep: Memory error
1 long beep and 2 short beep: Graphic card error
1 long beep and 3 short beep: AGP error
1 long beep and 9 short beep: Memory Error
Continuous long beep: Memory not correctly installed
Continuous short beep: Power supply unit failed
(AMI BIOS)
1 short beep: Memory Error
2 short beep: Memory parity check error.
3 short beep: Basic memory 64K address check error
4 short beep: Real Time Clock malfunction .
5 short beep: CPU error
6 short beep: Keyboard error
7 short beep: CPU interruption error
8 short beep: Graphic card error
9 short beep: Memory error
10 short beep: CMOS error
11 short beep: CPU cache memory malfunction
It might not be a lot of help, but it's somewhere to start... and at least this way you'll know what to be listening for.
Nov 30, 2013 | Gigabyte Computers & Internet
Inisperon 530s powers on and beeps
1 short DRAM refresh failure
2 short Parity circuit failure
3 short Base 64K RAM failure
4 short System timer failure
5 short Process failure
6 short Keyboard controller Gate A20 error
7 short Virtual mode exception error
8 short Display memory Read/Write test failure
9 short ROM BIOS checksum failure
10 short CMOS shutdown Read/Write error
11 short Cache Memory error
1 long, 3 short Conventional/Extended memory failure
1 long, 8 short Display/Retrace test failed
Aug 26, 2012 | Dell Computers & Internet
Advent Sienna 500 won`t switch on and keeps bleeping
First thing is to identify beep codes.
Beep Code Descriptions
Aug 25, 2012 | Computers & Internet
Long beeps not booting up
problem....the beeps are beep beep beep beep..........contiues...........plus the computer will then not recieve signal????
May 25, 2011 | MSI K9VGM-V Motherboard
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
What is code 14 on 03 zx636
Hi, here you go:
Service Code Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction, wiring open or short
25 Gear position switch malfunction, wiring open or short
31 Vehicle-down sensor malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
33 Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
34 Exhaust butterfly valve actuator sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank Key detection
39 ECU communication error
51 Stick coil #1 malfunction, wiring open or short
52 Stick coil #2 malfunction, wiring open or short
53 Stick coil #3 malfunction, wiring open or short
54 Stick coil #4 malfunction, wiring open or short
56 Radiator fan relay malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
64 Air switching valve malfunction, wiring open or short
67 Oxygen sensor heater malfunction, wiring open or short (Equipped Models)
83 Oxygen Sensor #2 inactivation, wiring open or shout (Equipped Models)
94 Oxygen sensor #1 malfunction, wiring open or short (Equipped Models)
95 Oxygen sensor #2 malfunction, wiring open or short (Equipped Models)
Feb 01, 2011 | kawasaki ZX-6R Motorcycles
Wont turn on
yes they tell you if there is something wrong
Beep Code Descriptions Document
Sep 25, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Whirlpool Accubake SF362LXTS Kitchen Range Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
