Question about Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S Lens
Nikon d40 with nikon DX 55-200mm lens will not auto-focus or shoot, no errors being displayed
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 29, 2010
  • Tony24UK Dec 04, 2010
    I fixed my nikon lense by keeping the fire button pressed down and then forcing the fine adjustment ring around until it clicked a few times, and now my auto focus works fine. You know if it has worked because as you are turning the fine adjustment ring the auto focus tries to take over.
18-55 DX lens won't operate on auto focus but camera will shoot pictures if lens is on manual focus
Hi dear Sir,Flexible connectors on printed circuit boards, misaligned.Defective contacts.
The SWM (silent wave motor) in lens is locked , dirty or damaged.
Best regards
Feb 28, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
D40 with a Nikon AF-5 DX 55-200 lens will not auto focus.. The 18-55 does auto focus OK...
I had a similar problem with one that I bought. and come to find out, the gears internally in the lens where broken. I would return the lens, and get another one. Also when you go to buy a lens for your camera make sure that you bring the camera with you to test the zoom before you buy it.
Just FYI you also need to remember that with a smaller zoom your focus time will be slower, and it will take getting use to, unlike the larger zooms, you are trying to focus on a large area but being very detailed at the same time.
May 05, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon DX AF-SNIKKOR 18-55MM 1:3.5-5.6G11 ED auto focus don't work
If you're looking at the camera without a lens on it, there should be a little flat protrusion in the lower left. Make sure that it is protruding and not obstructed.
Dec 19, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
D40 does not shoot on auto mode
on the side of the lens check to be sure it is set to auto and not manual.
Oct 15, 2009 | Nikon D40x Digital Camera
A/F PROBLEM
The D40 (& D40X & D60) will not autofocus with the G series lenses. The three cameras above require a newer DX series of lenses for the AF to work.
Jan 04, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40
The G series lenses won't work in AF mode on the newer, entry-level Nikons. They require the DX series.
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S Lens Logo
1,013 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
