Question about Intel Motherboard
During booting it will shutdown - Intel Motherboard
  • Intel Master
  • 27,725 Answers
Test your PSU or replace it
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Posted on Aug 27, 2010
Fan on Dell M5030 Starts on startup and then shuts down but computer continues to boot
Lots of fans are variable speed. Meaning they spin faster when the computer is hot and slow down when not. It's most likely spinning down. If the fan was bad the computer will either shutdown or generate an error during BIOS and halt the boot process.
Jan 11, 2013 | Dell Inspiron M5030 Laptop
How can I change boot sequence in Compaq Evo N410c?
You need to access your BIOS configuration. 1. To do this, shutdown your computer and boot it by pressing the power button. 2. You need to hit F10 when the computer first powers up in order to get into BIOS (Note that the key is usually different for different computers. If F10 doesnt work, try F2, F12, Delete or F9. 3. Once in the BIOS, you should find the boot sequence option.
Hope this helps!
Apr 11, 2011 | Compaq Evo N410C Notebook
Our laptop will not shutdown, and keeps trying to install updates over and over again... we cannot do anything
Hi, try taking the battery out for ten seconds, then restart computer. If you have received a corrupted update, you may need to reset your operating system to a time before the update; to do this boot into safe mode by pressing the ESC or Del key during initial boot fase.
Oct 13, 2010 | Acer Aspire 5100 Notebook
Shutdown
if it is in a no power no boot situation you will have to replace the bios chip or replace the motherboard. if you update the bios ALWAYS MAKE SURE YOU ARE ON AC POWER AND HAVE A FULL BATTERY. if your battery is weak make sure the power cord is plugged in and secure . if your computer looses power during a BIOS update it is bad .
Jul 06, 2010 | Compaq Presario R3000 Notebook
On start, I get a "No bootable device--insert boot disk and press any key" message
This means that the Boot sequence part of Windows has becoming corrupted. If the FIXBOOT boot command does not work for you during the repair option, when inserting your system discs, then you have no alternative than to reinstall Windows.
If there is data on the drive that you need, then I would advise getting a USB to hard drive adapter and transfering the files to another PC before reformating.
This fault usually occurs during incorrect shutdowns,, hard resets, or power loss whilst the computer is switched on.
Mar 07, 2010 | Compaq Presario 700 470024-192 Notebook
Laptop heats up and then shutdown
You could have a faulty fan which causes the CPU to go into thermal shutdown. The laptop will not boot up until the CPU has cooled down.
If the faulty is not fixed then eventually the CPU will fail.
Check the fan to see if it spins freely and replace if necessary. Also clean the heatsink and fan of dust.
Mar 02, 2010 | Lenovo 3000 Y410 Laptop
My laptop wont turn on at all and before it completely shutdown there was a message about drivers
you need to go to safe mode by typing F8 during booting
login safe mode
slow booting because of more programs running on the startup
pls do following steps
1,Start>run>type "msconfig"
select startup
remove tick mark except your antivirus
apply
ok
Nov 03, 2009 | Dell Inspiron 1525 Laptop Jet Black
HP-520 shutdowns while restaring after vista updates installed
This is something you no longer have to worry about. Vista is no longer being supported so Microsoft will no longer be releasing new updates.
Windows Vista Reaches End of Life Capital Support
May 06, 2017 | E-Machines M5310 PC Notebook
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Intel Motherboard Logo
18 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
