Question about Dell Inspiron 1545 Notebook
Its hard - Dell Inspiron 1545 Notebook
  • 6,831 Answers
Hello
If you are talking about the fan noise, you will need to understand the following.
The fan seed is proportional to the heat on the system, hence, the hotter the CPU, the faster the fan must rotate in order to give the sufficient cooling.
So, if the fan was not always this loud, you will need to open up the unit and clean out the dust particles preventing sufficient cooling at low revolutions of the fan.
Hope this can be of help.
Kind regards
Andrea
Posted on Aug 27, 2010
What are some example of hard drives?
A hard drive is the main component that the computer relies on.
On the hard drive, the operating system is stored, also includes your pictures, videos, music, documents, etc.
No operating system on...
there are other portable hard drives or mass storage devices
2.5 3.5 internal and external hard drives
usb external hard drives
usb pendrives
usb flash drives
ide internal hard drives
sata internal hard drives
hope this helps
Jul 13, 2012 | Samsung Computers & Internet
When pc boots My wdc hard disk shows sec master hard disk S.M.A.R.T status bad backup and replace
your hard disk getting damage so take back up fast and replace hard disk with new hard disk smart test when hard disk want when hard disk surface going some hardware problem
May 22, 2012 | Western Digital Computers & Internet
Aspire one can not detecthard drive
Repair laptop hard drive is not detected
Solution 1
1. Open the hard drive cover (remove two screws)
2. Remove the hard drive screws, then slide the hard drive (see the arrows)
3. Wait 15 minutes, then plug the hard drive
4. Turn on the laptop.
Solution 2
1. Remove the hard drive
2. Clean the gold layer with a pencil eraser
3. Plug the hard drive, then turn on your laptop
Solution 3
2. Plug jumper on the hard drive
Solution 4
1. Remove the hard drive, plug the external cable.
2. Connect the hard drive to another computer, with USB connection
3. If the hard drive can be detected, eject the hard drive
4. Plug the hard drive to the laptop, then turn on
Intended to make the hard drive can work with the help of another computer
Solution 5
1. Remove the laptop hard drive
2. Plug the laptop hard drive to my PC.
SATA1 - PC hard drive
SATA2 - Laptop hard drive
3. Boot the computer from a PC hard drive
The purpose of using a PC computer main-board as drivers of the laptop hard drive.
I hope this information helps. Thank you for using FixYa!
Oct 15, 2011 | Acer Aspire One PC Notebook
I have a laptop which it does'nt detect the hard drive what is the problem?
The problem could be one of these -
The hard disk needs reseating to make proper electrical connection.
or
The hard disk is faulty.
or
The BIOS has not detected the hard disk.
or
The hard disk controller is faulty
To determine the fault -
Reseat the hard disk and boot up the laptop.
Check the BIOS configuration - does it detect the hard disk. The BIOS may have a hard disk diagnostic, if so then run the diagnostic.
For a further hard disk test - remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If the hard disk is OK then this computer will detect it as an external hard drive and you can open the folders and files.
If not then the hard disk is confirmed faulty.
To get the Gateway working, install a new hard drive and install Windows, the laptop's device drivers and your programs.
Sep 05, 2010 | Gateway 450ROG Notebook
Hi i m hems i m upgrading hard disk on my ( acer aspire 1641nwlmi ) laptop hard disk is 160 gb but it's not detecting my new hard disk , my new hard is ok but i have quistion 160 gb is supporting my laptop...
The Aspire 1641 is supplied with a 80Gb hard drive. If the new 160Gb hard drive is not detected in the BIOS then the BIOS cannot support this size hard drive.
Check your manual/specification to see the maximum size hard drive it can support.
You can install the 160Gb hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Aug 24, 2010 | Acer Aspire 1641WLMi Notebook
PXE - E63 error
This error is related to the hard drive.
It could be a faulty connection on the hard drive - try re-seating the hard drive.
The hard drive may be faulty - go into the BIOS and see if the BIOS detects the hard drive.
If the BIOS cannot detect the hard drive then the hard drive may be faulty ot the laptop's hard disk controller could be faulty.
To determine if the hard drive is faulty, remove the hard drive and connect it into an USB hard drive adapter and plug this adapter into a working compute's USB port. If this computer cannot see this hard drive as an external hard drive then this hard drive is faulty and needs to be replaced.
When the new hard drive is installed in the Compaq laptop, insert your Windows installation CD and install Windows, plus the Compaq's device drivers and your programs to get a working laptop again.
May 26, 2010 | Compaq Evo N610C Notebook
Complaining about hard disk not inserted
The problem is either the BIOS is not detecting the hard drive or the hard drive is faulty or the disk controller is faulty. Check the BIOS setting to see if it has detected the hard disk, and if there is a hard drive diags run it to test the hard drive. Try reseating the hard drive and if it doesn't work, remove the hard drive and connect it to an USB hard drive adapter. Plug this adapter into a working computer's USB port and if this computer detects this as an external hard drive and you can view and open the various folders and files, then the hard drive is OK. If you haven't any files or folders in the hard drive, then format the hard drive from this computer to test this hard drive. If the hard drive is OK then the fault is probably the disk controller. If the hard drive is faulty, then you need a new hard drive in your computer.
Jun 10, 2009 | HP Compaq nx9420 Notebook
What is comando 2 cheats
go on 1.www.gamewinner.com 2.www.cheat beast.com
Dec 26, 2008 | Prima Codes & Cheats: Spring 2005 Edition ...
Hard drive removal
  1. Loosen the two Phillips-head screws that secure the hard drive cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the inside edge of the hard drive cover and remove it.
  3. Loosen the spring-loaded Phillips-head screw that secures the hard drive.
  4. Hold the Mylar tab and pull the hard drive toward the outside edge of the base enclosure to disconnect the hard drive from the system board connector.
  5. Lift the hard drive out of the bay and remove.
  6. Place the hard drive in a static dissipative bag.
Replace the hard drive
  1. Remove the hard drive from the static dissipative bag.
  2. Place the hard drive into the hard drive bay.
  3. Push the hard drive toward the inside of the base enclosure until the connector is seated.
  4. Tighten the spring-loaded Phillips-head screw that secures the hard drive.
  5. Insert the hard drive cover into the enclosure.
  6. Tighten the two Phillips-head screws.
Nov 16, 2007 | HP Pavilion Ze4805us Notebook
Dell Inspiron 1545 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
