Question about Canon PIXMA MP960 Printer
My Canon MP960 printer won't scan. I'm pressing all the right buttons, but it won't scan. I'm not getting an error page or anything, and I don't know why it won't work.
rockfixya
  • 679 Answers
SOURCE: ERROR 5800
1. Turn off printer.2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color.
3. let go button Stop/Reset, continuing to hold POWER.
4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons.
5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key)
6.turn off printer by POWER button, then turn on.
7. You should be set. If it didn't work, try it again, slowly. It WILL work!
Posted on Jan 28, 2009
  • 10 Answers
SOURCE: how can you scan on printer canon mp 180?
Try scanning using the following method
Open Word document
Click on Insert - Select Picture - Select Scanner or Camera
In the popup window, check whether the Canon MP180 option appears, if so, select the same, this should scan the document.
If the Canon MP180 doesn't appear, then the drivers are not installed properly, you can download the same from canon.com
Posted on Jul 22, 2009
komguy
  • 2306 Answers
SOURCE: my canon mp240 printer will not scan
It won't scan unless it's connected to a computer, and has the scan software running. Will it copy a document on the glass?
Posted on Aug 03, 2009
  • 566 Answers
SOURCE: I forget how to scan and save on my Pixma MP960 -
You can download the manual and guides from CANON Support:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13988
Posted on Aug 14, 2009
SOURCE: trying to scan, but keep getting error code
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Posted on Sep 05, 2009
It says E5, which means I need to replace my FINE ink cartage, but I don't print with this printer, ever, only scan. It won't let me do ANYTHING since it's started flashing this a week ago. Why...
Hello! Here is your solution.
1. Press Stop/Reset button for 5 seconds. 2. After 5 seconds your printer will start one process. 3. Now release to hold the button.
Now your printer is ready to use.... thanks
Sep 13, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Error 5200 of canon pixma mx328. i already tried turning it on and off several times and even got the cartridges and returned them back but still when i tried to print a page error 5200 still...
Error no 5200 is caused by its temperature high.. to solve your problem follow the instruction given below::
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 23, 2011 | Canon MX300 Office All-In-One Printer
Canon MX860 I have run out of ink but need to urgently scan an office document. This printer just says out of ink and does not let me do anything PLS HELP! Ron
All you have to do for some errors is to press and hold for some seconds the right red stop button and it may proceed normally!
Jan 02, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
E-24
E24 = Purge unit error. You may need to also clean out you waste ink. try this below..Resetting Printer Canon MP140, MP160, MP180, MP210, MP220, MP460, MP470, MP500, MP510, MP530, MP600, MP610, MP800, MP820, MP810, MP830, MP960, MP970 1. turn off the canon printer 2. resistant "resume button" (red triangles) + key "power" at the same time. 3. tetep hold the "power", release the button "resume Button" 4. without releasing the button "Power", double click the "resume", then then release both keys. 5. click the "resume" four times fast 6. press one time the "power" to confirm "reset counter absorber." 7. to function "disable the printer" press the "power" once again.
Below is your user manual.
http://www.retrevo.com/support/Canon-MP140-Multifunction-Printers-manual/id/3124ci174/t/2/
Aug 24, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
I need to scan some photos but am out of ink and scanner does not want to scan. Will the scanner not work when out of ink for my Canon PIXMA MP960
what makes you think I am going to give you my fix for free if you were going to charge me for your answer? I don't think so,
Jan 07, 2010 | Canon PIXMA MP960 Printer
U052 error
UO52 error is either a print head temp sensor error or faulty EEPROM data from the print head. You need to re-set the print head. If that fails then a new print head is required.
http://www.tradebit.com/filedetail.php/4588590-canon-pixma-mp960-printer-service-manual
Complete Pixma MP960 service manual from Canon
Sep 24, 2008 | Canon PIXMA MP960 All-In-One InkJet...
Error Message "Page too Complex"
Hi Sccfire, This apparently is a fairly common problem with the 2800 series printer and associated with connection to a PC using USB. It can only be overcome by manually configuring the printer?s USB port to work in standard mode rather than at high-speed USB2.0 mode which probably won?t be to much of a problem. Here is a link from a support page on HP?s site that should walk you through the process: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506095 Let us know how it goes and please don?t forget to rate the posting.
Jan 05, 2007 | HP LaserJet 2840 All-In-One Printer
Canon PIXMA MP960 Printer Logo
493 people viewed this question
old marine
old marine
