Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
How can I connect a converter box to a sony wega 36'?
5 Suggested Answers
SOURCE: sony trinitron wega 36 inch
break the wega into tiny little pieces and it's easier to get out of your house!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Aug 05, 2008
  • 218 Answers
SOURCE: Is this TV a digital tuner? or will I need a converter box
You'll need the adapter box in order to get the new digital signals. The Sony KV-36FS120 has an NTSC analog tuner.
Posted on Feb 02, 2009
joboo1
  • 257 Answers
Hi, If you have an outside antenna you will need a converter box as this tv has an NTSC tuner which is analog.
SOURCE: Problem for Sony FD Trinitron WEGA KV-36HS500 36
ONE: Unplug it for at least 4 hours. That is what we call a hard reset.
TWO: If the hard reset does not help, then it will need further diagnostics.
The following bulletin may be of help in your learning about what is going on. Please refer to it below. Then let me know if you need further assistance.
Have a great day,
Cleggsan
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If
the timer/standby indicator is blinking, this could be an indication of the
problem with the unit. The diagnostic blinking will occur automatically with no
action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks
(depending on the fault) about a third of a second apart, then pauses for 3
seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the
number of blinks. The words in parentheses are those which you will see for
each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held
high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault is
corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5,
volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Posted on May 31, 2010
Is the sony trinitron 32"
U have pay cable or satalite service tv incomming broadcasting signal.Yes,than ur tv no need for a DTV converter.Those pay boxes will revert back to analog signal for ur analog tv.If u planning to get free over the air broadcasting,than u need a converter box to convert digital signal to a analog tv.
Mar 21, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I did a reset on my Sony WEGA TV but now it's not connect with the cable box. Just says no signal. Screen is all snow and no sound other than static.
you need to reprogram channels. Itll only pick up 3 if you are still using coaxial cable from box, or change input to DVI/HDMI, aux, etc.
Oct 21, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I dont know how to set up tv with my converter box
download my KV-32HS500 it may help with your problem contact me at computec40@hotmail.com
Nov 04, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Feb 02, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Hi, Sorry this tv has an NTSC tuner which is analog. But it will work if you have cable or satellite.
Feb 02, 2009 | Sanyo DS24424 24" TV
DTV converter boxes
You need to look on the tv and see if has a digital turner symbol. If you can only pick up analog channels, you need a converter box.
Jan 22, 2009 | Sony FD Trinitron WEGA KV-36FS210 36" TV
Can the sony 36" flat wega tv model KV-36FS17 still get a picture useing rabbit ears after february 19th.
No you will need a digital converter box for this TV as of Feb 19th
Please rate my response and keep this site FREE!
Thank You!
Jan 06, 2009 | Sony KV-36FS17 36" TV
Not able to receive HD digital signals
If you are talking about the new digital over-air broadcast signals, the answer is no. You will need a converter box. If you mean something else, please try to be a bit more descriptive on what you need.
Thanks,
Dan
Oct 29, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Is the Sony FD Trinitron WEGA KV-36FV27 36" TV a digital TV
This is an Analog TV - you will require converter box.
go here to order it: https://www.dtv2009.gov/ApplyCoupon.aspx
jl
Nov 26, 2007 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
