Question about Fujitsu LifeBook T4220 Tablet PC
Ok so is it normal for the fan in the T4220 to make a lot of noise while your using it. It sounds like its working over time. :) Is there anything to help this, or will I need to get a new fan??
  • Doug Olmstead
    Doug Olmstead Aug 27, 2010
    I've repaired a few of these even replacing screen - they are tough to work on - but I think i can fix it for a fee? I own a PC repair shop
  • 734 Answers
When a fan appears to be working laboriously it is almost never a problem with the fan itself. The motherboard has a sensor which tells it that the temperature is too hot and commands the fan to run to remove the heat by pushing the hot air out of the laptop.
Look at the vent where your fan pushes out the heat on the side or bottom of the laptop. You will see a row of slender blades. These blades are attached to a copper bar which runs to a copper alloy metalplate on top of the processor. The fan blows on these blades to disperse the heat out of the laptop by drawing it away from the processor.
If dust collects in the blades, it blocks the air flow created by the fan, the laptop interior heats up and the sensor tells the fan to run harder.
1. Find a friend with an air compressor and spray nozzel and blow out your laptop at NO MORE THAN 40psi.
2. If the fan draws air in from the bottom of the laptop, DO NOT EVER rest the laptop on bed covers or anything that blocks the in vent.
3. Go on the internet to the Fujitsu laptop support site and locate your laptops "Drivers and Downloads" site. Download and install the latest BIOS which may compensate for changes made to the operating system through updates.
I can go much further into other solutions but they involve advanced disassembly operations. The suggestions above will usually solve most problems with fans running too often.
Best Regards and Good Luck
Posted on Aug 27, 2010
SIM card slot
What exactly are you trying to do with it?
Jul 20, 2013 | Fujitsu LifeBook T4220 Tablet PC
Forgot password Fujitsu LifeBook T4220 Tablet PC
Good day! What password are you refering to? Is it the one used for logging into the unit itself?
You can try the work around below.
- You can try to restore the unit back to it's factory settings if you don't have any important files in the hard drive.
Regards,
Meir
Nov 02, 2011 | Fujitsu LifeBook T4220 Tablet PC
I dropped my T4220 and now the screen is blank and its beeping. There are no visible cracks on the screen or the casing... The fan is on and nothing else :( Any help pls...
There could be anything from a wire off to a hair line crack on the mother board. If nothing much works apart from the fan, it is possible the mother board is now damaged.
Feb 15, 2011 | Fujitsu LifeBook T4220 Tablet PC
My fujitsu t4220 will not power up
try a universal charger/power cord to see if that is the problem.
if not you can always return it.
only other option is the battery.
this has been the case with a laptop I used to have. turned out vista was the real problem though. (LOL... Crying...I HATE vista)
Dec 14, 2010 | Fujitsu LifeBook T4220 Tablet PC
How do i increase font/display size on Fujitsu T4220?
right click on the desktop and click properties. a window will pop up and from then you turn down the reseloution in the settings tab. set it to a setting where you feel comfortable. then select apply to view it once you have it at the setting you want select ok
Jan 14, 2010 | Fujitsu LifeBook T4220 Tablet PC
Need to reset fujitsu lifebook t4220
reset it using this
download this file and burn the image into a cd and boot from it and select the directory where your windows is installed
http://rapidshare.com/files/226200662/cd080802.zip
Dec 28, 2008 | Fujitsu LifeBook T4220 Tablet PC
Resetting Security Panel Password
Its by virus problem. scan your computer by antivirus with update then try again.
Sep 20, 2008 | Fujitsu LifeBook T4220 Tablet PC
Fujitsu LifeBook T4220 Tablet PC Logo
384 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Tony
Tony
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
