Question about Canon Office Equipment & Supplies
There is paper from the cartridge wrapped around the printer bar. What can I do? PLEASE help!!!!!!!!!!!
    Champion:
  • 331 Answers
Very gently reach in and try to remove it. Use an x-acto knife gently; or tweezers.
Posted on Aug 27, 2010
There is a paper jam in my hp laserjet 3055 printer and I don't know where is the door of this printer to remove the anybody please help me out.
Remove the cartridge from the printer and look for the obstructing paper especially in the arms of the paper detector switches (2 nos. in the path). If you cant see any, the paper has most likely wrapped around the pressure roller / tafflon sleeve in the fuser. Carefully remove the plate just above the cartridge labelled "Caution Hot - Avoid Contact" (after the printer has been in power OFF mode and has cooled down) by removing the two screws on either side. See if the paper has wrapped around the rollers - remove and fit back the plate. In case of repeating problem look for damages to pressure roller and the tefflon sleeve. Have the fuser serviced in that case.
May 28, 2015 | HP LaserJet 3055 All-In-One Printer
Printing quality poor even after changing cartridges. Isthere a traying that stores dirt etc that needs cleaning?
is the toner smearing? it could be that you have a piece of paper caught in the fuser wrapped around the pressure roller that just needs to be removed or it could also be the imaging belt has gone bad...hope this helps and if so please mark fixya...
Jun 25, 2010 | HP Color LaserJet 2600n Printer
Paper wrapped around inside of printer and no obvious way to remove it--too tight to get hands in and it appears there are no levers to loosen roller and pull paper out --next option is throw in trash and...
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 05, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
Paper is jaming put in new toner just three days ago. the paper feeds part away and then wraps around the roller. We have doubled checked our loading of the new toner cartridge.
Hello sir; Is the paper wrap around heat roller ? if yes, then check the roller has 4 to 6 paper separation fingers does it function good, if not, please tell us which roller is?
Jul 30, 2009 | Samsung 4725FN Black and White Copier
Clear paper jam in top feeder of HP 3055
IT HAPPENED TO ME, I HAD TO TAKE HP ONLINE HELP, BUT ACTUALLY U WILL HAVE TO OPEN THE WHOLE AFD LIKE LITERALLY UNSCREW IT OPEN CAREFULLY AND THE ROLLERS AND THEN U MIGHT MANAGE TO TAKE OUT THE JAMMED PAPER
Apr 02, 2009 | HP LaserJet 3055 All-In-One Printer
Missing Toner Cartridge
Try first removing all paper from paper trays and then reinserting cartridge, etc.
Sep 23, 2008 | HP LaserJet 3050 All-In-One Printer
Paper wrapped around the red roller
lift the cover remove all the cartridges and the drum unit slowly and carefully and slightly pull the upper side of the paper not the lowerside and if it is rolled completely you have to open the heater unit to remove if you donot have any technical knowledge do not try because the red roll you are taking is a costly thing,call the service technician and get it repaired that would be more cheaper.
Aug 08, 2008 | Samsung CLP-510 Laser Printer
Easyshare printer dock seris 3
TRY THIS
UNPLUG POWER CORD/USB TO COMPUTER IN BACK OF DOCK.TAKE OUT PAPER TRAY.
LIFT DOCK (LOOK INSIDE (DEEP INSIDE AND SEE IF YOU SEE THE CARTRIDGE FILM ON A STEEL ROLLER,WRAPPED AROUND IT.)A FLASHLIGHT MIGHT HELP IN THAT STEP).
IF CARTRIDGE IS WRAPPED AROUND TAKE TO SERVICE PROVIDER(I TRIED TO FIX IT LIKE THAT AND IT WAS A HASSEL)
IF NOT WRAPPED AROUND GO TO CARTRIDGE OPEN DOOR/LIFTGREEN TAB UP.SHOULD EJECT(IF NOT TRY A BUTTER KNIFE AND PRY UNDER SLIVER DOT)NOT HARD BUT WITH ALITTLE FORCE SHOULD POP OUT.
REMEMBER TO LIFT GREEN TAB WHILE PRYING.
IF STILL STUCK MAY BE STUCK IN PRINT MODE
THATS BEYOND ME. GOOD LUCK.
Mar 19, 2008 | Kodak EasyShare Thermal Photo Printer
Hp laSERJET 1200 PAPER JAM
If you cant get paper out from inside after removing cartridge then there is No easy fix, and the roller at rear is called a fuser, these parts dont come out easy,machine will need all covers removed, plugs disconnected and brackets removed, gears pulled off and fuser removed, maybe replaced if there is a reason why it wrapped around roller
Oct 18, 2007 | HP LaserJet 1200n Printer
15 people viewed this question
old marine
old marine
