Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
It appears that an intake valve may be stuck on my Briggs & stratton engine, It is back firing through the carb. Was running fine & then started this. It is very hard to turn over as well, but does start & running poorly. How can I fix this problem without big expense.
  • 10,319 Answers
Gap all valves to .008 and try again to start it up
Posted on Aug 27, 2010
I had the same issue... almost... I had an exhaust valve sticking. It stuck closed and bent the push rods and it ran awful... could barely get it to crank. It was only running basically on one cylinder. I bought a head kit for the side I needed from jacks small engines.com and new push rods and valves and removed the engine then the oil pan and camshaft and replaced the valves and rebuilt it all. Make sure if a valve is sticking you get an oil pan gasket as well because that's the only way to get to it is taking the engine out and the oil pan
Posted on Jul 10, 2013
Valve adj. B&S gen. Model 030246 10 hp. OHV
Briggs and Stratton Valve Clearances
outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
Briggs & Stratton Intake and Exhaust Valve Clearances. Model Series, Engine Type, Intake Valve Clearance ( in. ) Exhaust Valve Clearance ( in. ).
Briggs and Stratton 10hp Generator Carburetor Repair ...
? 6:17
https://www.youtube.com/watch?v=O-fROtibEvE
Jun 5, 2010 - Uploaded by IFIXIT4U
In this video I will show you how to clean the carb on a Briggs10hp. This is a Nikki carb.
Nov 03, 2015 | Measuring Tools & Sensors
Why does my briggs & stratton 19.5 backfire through the air intake?
need to have carb rebuilt or you can rebuild yourself good luck
Jun 28, 2014 | Briggs & Stratton Garden
My briggs and stratton 18 hp vanguard model 356447 will not start just back fires through the carb. I have good comprssion and spark at both plugs. I replaced the flywheel key as thought the backfireing...
check intake valves for proper seating. If the valves do not close completely it will allow the engine to backfire thru the carb. Another possibility is internal timing caused by the misalignment of the timing gears between the crankshaft and cam gears.
Oct 29, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Vanguard backfires through carb
If you say the valve stems were bent..first did you find out what bent them they just bend...and is the valve face seat damaged..if they were not...your engine is out of time or you did not set the valve stem lash when replacing them this allows the intake valves to be open slightly under the firing stroke firing back through the carb and intake...you should have around four thousands of an inch clearance when the springs are completely relaxed and and you should be able to wiggle the valve rocker tappits ...check that if they are correct your engine is out of time..good luck
Oct 10, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Fuel problem with John Deere 23hp engine
time to pull the hose off the fuel pump coming from the tank and drain the tank and check flow of gas coming from tank hose, and possibly inline fuel filter is plugged or there is junk in your tank/line from tank not letting enough fuel to run to pump so pump can pump it to carb !
May 15, 2012 | Briggs & Stratton Briggs Stratton...
Carb shooting air and fuel out top instead of taking in air
Get an air filter made from foam or paper. The ion ones don't work well.
Also sounds like an intake valve is stuck open. When piston comes up it pushes air/fuel back out through the carb. Do a compression test on both cylinder to confirm this.
May 06, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 60200 series engine intake valve tar
I'm having the exact same problem with a Briggs & Stratton 80202 engine on my Mclane reel mower. I cleaned out the valves and cylinder head, put it back together and it runs nicely. I ran it for about a half hour then turned it off to adjust the blade. A couple hours later I went to start it and no compression. The Intake valve is stuck open with gum from running it for a half hour! The can of gas I have is less than a month old. I'm going to try a different brand of gas.
Jan 09, 2010 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
1,133 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
