Question about Kenmore 72175 Air Conditioner
Kenmore 35710. went on holidays. turned it off. got home. turned it on. got what looks like "FE" message, and it won't work. has been great machine until this glitch.
  • Kenmore Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 30, 2010
2004 Sante fe 3.5L 2WD went out to go to work and wouldn't turn over, (assumed dead battery), went down and got new battery and installed, still wouldn't turn over, (assumed starter shot),removed...
TEST POWER LEADS TO STARTER FOR POWER
AT STARTER (BATTERY POSITIVE TO STARTER BATTERY NEGATIVE TO ENGINE BLOCK)
THEN TEST FOR SIGNAL POWER TO SELENOIDE ON STARTER
(KEY TURNED TO START POWER SHOULD GO TO SELENOIDE)
IF NO POWER TO SIGNAL WIRE CHECK FUSES AND RELAYS
ON STARTER CIRCUIT
IF THIS CHECKS OUT MAY BE AUTO TRANSMISSION NUTRAL PARK SWITCH
TRY TO START IN NUTRAL OR WHILE SHIFTING TRUE GEARS SLOWLY WITH SHIFTER
IF STANDARED CHECK NUTRAL SAFETY SWITCH
May 08, 2011 | 2004 Hyundai Santa Fe
The heater on our 2002 hyundai santa fe won't turn on. It worked great yesturday. Went to turn on this morning and nothing happened
Check your fuses first should be in the passenger compartment.... can find the location of the fuse panel in the owner's manual. From there I would suspect the blower relay which is usually in a fuse box under the hood
Dec 22, 2010 | 2002 Hyundai Santa Fe
Have 2002 sante fe just recently had new transmission installed new battery but today its very cold out car started up ok but noticed for the first 15 minutes my brake light and battery light stayed on...
cold can play hell with electronics. if it happens again (provided the battery is the proper one for that vehicle) hit the accelerator and see if the lights go out. sometimes just a good warm up will rectify the issue. happy holidays
Dec 31, 2009 | 2002 Hyundai Santa Fe
Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
Nov 04, 2009 | Kenmore 98702 Stacked Washer/Dryer
Door lock
dl meand door lock. A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error. Potential Causes ? Door Lock Mechanism broken or removed from the Door ? Check Door Lock/Switch Assembly ? Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) ? Door Lock/Switch Assembly Failure Replace failed component.
Sep 22, 2007 | Kenmore Elite 45986 Front Load Washer
Screen is blank
You tell me that you tried new batteries. Have you tried a set of NiMH batteries? They are the best for digital cameras. Please try a set, preferably ones rated 2200 or higher. If this doesn't help, the lens could be jammed. Hang onto the batteries though, because they are rechargeable and can be used in anything that takes AA batteries.
Apr 14, 2007 | Olympus FE-115 Digital Camera
Kenmore 72175 Air Conditioner Logo
228 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
