Question about Hitachi 53SDX01B 53" Rear Projection Television
Getting sound and no picture. had a tv repairman out said it was a the main board (can't remember exactly what he called it) said it would be close to $700 to repair which is almost what i paid for it. Wondering if anyone could tell me the part name and number and if its it a kind of (plug & play) hook up, another words a guy with no experience can hook it up.
  • Hitachi Master
  • 8,617 Answers
Thats a deflection problem which indicates the Deflection board is the problem. You should be able to get a replacement board or your board rebuilt from www.tvrepairworld.com boards are very easy to replace.
Posted on Aug 27, 2010
  • 3 more comments
  • seanj1020 Aug 27, 2010
    is this still the case if there is no light or picture? Is this the board on the shelf next to the 3 bulbs, to the right if you're looking from behind the t.v.?
  • Sonny Berry
    Sonny Berry Aug 27, 2010
    The deflection board is the large board on the Right when looking in the rear of the TV. It Has the Large HV transformer with the large red wire
    Ok looked to the right their is a board that the power supply runs into, it is side mounter on the wall. There is a very large board on the bottom not sure if it is several boards placed together though. Don't know what the HV transformer would look like. All wires seem the same size but there is a red one coming off of the board with the power supply
    Hitachi
    Part # JT20491
    Deflection Printed Wiring Board (PWB) Assembly
    any Idea if this would be the right part?
  • Sonny Berry
    Yes thats the part number for the deflection board. Which should solve that issue for you.
PN59D550C1FXZA 59in Plasma picture comes and goes
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Check the Va and Vs voltages. These voltages should be so accurate as marked on the silk screen behind the display panel. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 28, 2016 | Televison & Video
Vizio VW42L went black screen, no sound could turn on but not off, with remote or on the side. Called a repairman, decided to purchase a new TV. Year gone by, plugged it in and it has worked for several...
Yes,the tv main Tuner signal board it is the problems and the causes it have intermittents shorts in sides.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv main Tuner signal boad for the replacement.
Jul 10, 2011 | Vizio 42 in. LCD TV
My brand new lg tv went out and has a burnt smell and one of the usb ports does not work. the tv will turn on, but there is no picture or sound
sounds like the main board need to be replaced. call lg for repair, if no warranty you are looking at $300 for the part plus repairman's fee
Jan 16, 2011 | LG 47LX6500BNDL Complete 3D Bundle 47 in...
The tv screen is black and wont turn off no sound no picture can only turn it off by unpluging
Good day sir, hi, as i see it, there is a problem with the tv's power board. this board produce stable power to the main board that controls the sound, and picture. Replacing the board is highly technical, you need to get the exact board replacement which you can only get on your dealer, call them for service. Check first the warranty.
Jan 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Vizio 32" no picture only sound 1 year old 720 I
call 1-877 MY VIZIO if your set is still under warranty. If not, you'll have to find a local TV repairman to get it working again. Let him know that he can order a main board from http://www.encompassparts.com/models/?VIZVW32LHDTV10A Expect to pay somewhere around $200 if you find someone willing to do the repair.
Jul 14, 2009 | Vizio L32 32 in. LCD HDTV
No picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
May 31, 2009 | RCA M50WH185 Television
I get sound on my TV but no picture
its the problem of loose connections or some of the components getting short circuited on the main board needs to be checked by a meter.
Jan 14, 2009 | GrandTec Ultimate GWB-4000 Digital Media...
Vivitek RP56HD22A loosing picture but sound is still there
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 23, 2017 | Vivitek V37835 46 in. LCD Television
SOUND NO PICTURE ONLY RAINBOW
I just fixed this problem on my neighbor TV. I don't have a manual or schematic, and didn't pay any attention to the reference designators, so I will just have to describe it. The problem was a bad solder joint. Visible thermal fatigue. Looking at the main board, (didn't even need to slide the cassis out). There is a small, narrow, vertical board in the center, adjacent to the yoke connectors with a funny looking little transformer on the very top. Check the connections on that.
-John
Dec 15, 2006 | Apex Digital GB5108 51" Rear Projection...
Hitachi 53SDX01B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
