DeLonghi PACW130E Portable Air Conditioner Logo
Posted on Aug 27, 2010
I have a DeLonghi PACW130E that says HL in the display. whats the problem?
What does the code HL MEAN and how to fix
'make model (what it is)' in all questions please. 'HL' is always high limit and refers to an over heat situation.
Spa display is reading HL. The HL reading in the display stands for Hi-Limit. The hi-limit is measuring the temperature at the heater, not the actual water temperature of the spa.
HL Error - Arctic Spas Utah
What does error code L means on the delonghi cooktop
The L indicates that the child lock feature has been enabled. This ensures that the burners do not function while you clean the cook top and that a child can't turn on any burners.
The procedure depends on your cook top model. For some induction models, to toggle the child lock feature off, press the front right burner zone display and the booster function key (circle with a solid circle inside on the right of the selector zone) simultaneously. Then press the front right burner zone display again until the L disappears from the display.
See page 23 of the manual for the Delonghi DEIND804 available here: https://www.appliancesonline.com.au/public/manuals/Delonghi-DEIND804-Induction-Cooktop-User-Manual.pdf .
For an electric ceramic cooktop DTCH808, to turn off the child lock completely, press the bottom right + in a circle and the - in a circle (in the center surrounded by 4 of the + in a circle areas) simultaneously and then release the keys. Press the - in a circle again. See page 21 of the manual here: https://www.delonghi.com/Global/InstructionManuals/EN/EN-DTCH80B_im.pdf .
I hope this helps. Please add a comment with the model of your Delonghi cook top if these instructions do not apply to your cook top.
How do I set the time on my delonghi coffee maker?
hi hazel.
this is all i could find.
How to Set Clock on Delonghi coffee maker? Plug the appliance in; when the coffee machine is connected to the outlet for the first time, "AM 0:00" appears on the display. To set the time, press the SET CLOCK button (fig. 1) and keep it pressed until the correct hour is displayed: then release the but- ton. The time can be set at any moment.
important safeguards save these instructions - De'Longhi
www.delonghi.com/Global/InstructionManuals/GB/GB-1321026IDL.pdf Search for: How to Set Clock on Delonghi coffee maker?.
How do set the time on my delonghi coffee maker Google Search
2answers
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Delonghi prima donna esam6600 the lcd display stop working
If you are proficient at working on these machines, you should be able to get a replacement display from your local Delonghi agent to fit yourself. The fault is likely to be in the onboard driver or the display itself. Simply replacing it should sort it.
2answers
What does hl mean on air conditioner
My delonghi air conditioner has the HI code. What does that mean? It works for a while then shuts off
When ever I turn the air condition on. this symbol (HL) appear on the small screen, and it won't open What does that mean? Thank u
I think what you are seeing is "FL", rather than HL. FL indicates that the water collection bucket is FULL & needs to be drained. Sometimes. the LED letters on the screen can be hard ti read.
Hope this helped you and thanks for choosing FixYa.
2answers
What does ft on display mean? portable a/c
my guess would be "filter" check to see if it needs changing or is clogged.
12helpful
2answers
Error e6 displaying on single split model one inverter 12k
I have a DeLonghi one inverter and when I want to turn On the heater then the code error display E6 and the error code is Communication malfunction. So can you tell me how can I fix it
Top DeLonghi Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
