Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My tv will turn on an make a noise in the back with a flashing small light. This is to the right of the main tv bulb. There is no picture but sound will come through. I though this could be a ballast or a bulb but am not sure. I have a mistsubishi model WD-57833
  • Mitsubishi Master
  • 5,138 Answers
Replace Lamp, Call Mats Electronics they have them for $99.00
1-800-628-1118 The small flash you are seeing is coming from the Ballast Board it has a spark cap on it that arks when Lamp is Bad.
Posted on Aug 27, 2010
Dark Picture
Your backlight transformer has failed, this is not a simple fix and requires the replacement or one or more of the boards in the back of your tv.
Mar 07, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Can anyone point me in the right direction?I have had my samsung DLP (model SP50L6HD) for 4 years. This morning my children were watching TV and the tv started turning itself on and off. I switched it...
Jul 24, 2011 | Samsung HLM507W 50" Rear Projection HDTV
Set was on and made a loud pop noise and the picture went off. the red light was flashing and no picture. then it made a strange buzzing type of sound a few times. turned off for a couple mins and then...
It sounds like your screen inverter has just gone >bang< unfortunately.
Most screens inside use 2 main circuit boards, and you are most likely going to have to change one of them.
It's possible also for it to have been just the backlight bulb making the loud pop noise too. The inverter may have given out too much power and blown the bulb (a lot like you hear when a house bulb goes bang).
If you can't actually hear any TV sounds (normal sounds like music, voices etc. when they should be there), then it means the problem is more serious, and would need a specialist repair place to check out the electrical circuit inside.
Mar 30, 2010 | Sony KDF-E42A10 42 in. LCD Television
When I power the TV on there is no picture, the lamp light is flashing, and there is a squeaking noise coming from there rear of the TV. It kind of sounds like a wheel turning and rubbing against...
The squeeking sound could be the high voltage trying to strike the lamp, it will try several times to strike the lamp then shutd down. Take the bulb out and see if it s blown. Even if it is not blowen it sounds like you have a bad bulb.
Sep 01, 2009 | Samsung HL-R4667W Rear Projection...
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
