Question about Motorola Mobility SLVR L7 Cellular Phone
Phone & pc
My phone is not properly detecting in usb ,,,i tried in 3 to 4 pcs but windows says that your usb malfunctioned...i given it for service station,,but there they are using windows 2000pro ...there it was detected but he is telling that phone is good ....so what steps i have take care while connecting it
    Guru:
  • 1,463 Answers
Hello
if you got to the Motorola Worldwide there select your region and then look for your phone software and download from them.
riz.
Posted on May 06, 2008
USB DEVICE NOT RECOGNISED: One of the USB device attached to this computer has malfunctioned and windows does not recognised it.
The problem you have stated can be due to several causes. Please eject your USB drive from your computer and insert it again. If windows does not detect it, then restart your computer and try again. If the problem is still there, please check the Device Manager if the USB port is properly working and if it is possible to use the troubleshoot. The best way to check whether your USB device is properly working or not, insert it to another computer other than your's. If the problem persists, check your USB device's warranty period and simply go for the replacement and contact your retailer or service provider.
You can go to Device Manger by following the steps below:
My Computer Icon>Right Click on the Icon>Properties>Device Manager
Thanks for using FixYa.
Hope this helps,
Mrityunjay.
Apr 03, 2011 | Computers & Internet
I have a 5th generation iPod Nano. I've had it less than one year, and now whenever I plug it into my computer with the USB cord that came with it, my computer says "USB device not recognized" and that the...
  • Check system requirements. - iPod nano (5th generation) requires the following minimum versions of Windows: either Windows XP (Service Pack 3 or later), Vista or Windows 7. If you have one of these versions of Windows, verify that Windows is fully up to date by downloading and installing software updates from Microsoft. If you have Windows XP with Windows XP Service Pack 1 or Windows XP Service Pack 2, download and install Service Pack 3 using Windows Update.
  • iTunes online? - Confirm that iTunes has been downloaded and installed.
  • AMDS online? - iPod nano requires Apple Mobile Device Support (AMDS), which should be automatically installed with iTunes. To verify whether it is installed, click Start > Control Panel. Open the Add or Remove Programs control panel and verify that Apple Mobile Device Support is visible in the list of currently installed programs. If it is not, remove and reinstall iTunes.
  • Check USB connection. - Disconnect all USB devices from the system with the exception of the iPod nano and any USB keyboard and mouse. Then restart your computer. Verify that you are using a high-powered USB 2.0 port. Test with an alternate iPod USB cable if one is available.
  • AMDS - Re-verify that AMDS is running and installed.
  • iTunes usage - Remove and reinstall iTunes.
hope this helps
Oct 14, 2010 | Audio Players & Recorders
How do I transfer pictures from my phone to my pc? I have tried everything...
Three possible solutions. 1, a cable that connects your phone to a USB port on the PC. Windows explorer should see the phone's memory as a removable disc or card. 2, turn off the phone and take the SIMM card out of the phone. Use an adapter to plug it into the PC. Some PCs and printers have ports that may match your SIMM. 3, slowest solution, email the pictures to your PC.
May 18, 2010 | Cameras
When ever i plug my pen drive to the pc it is not detected & 1 error is given that the hard drive is not recogonized. due to malfunction....etc
it is because your USB port is not working and has malfuctioned you should try inserting your pendrive on other ports
Apr 20, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
External HDD is not detected
check the Hdd on a another usb slots uninstall and reinstall the drivers and also check the usb compatibilty if it is 2.0 or not
Nov 05, 2009 | SimpleTech 320GB SimpleDrive External by...
I was given a phone and when you power it on, it automatically asks me for an unlock code. How do I bypass this? Its the motorola L7 I am pretty sure. and it is a Metro PCS phone.
just download "Motokit "software from modmymoto.com.& install it in ur PC.Select Data/fax mode in usb setting of ur mobile.
then open the MOtokit software & connect ur phone..Software will automatically detect ur phone.
then of top left side of the software select " mobile" & then"info"..it will give u the Unlock code & security code of ur mobile...
Nov 04, 2009 | Motorola Mobility SLVR L7 Cellular Phone
USB gamepad is not detected.
Get the latest dirvers from the manufacturers website and install it on your pc.After that connect the gamepad.It should work fine.
Code 10 error is due to incomplete drivers or driver malfunction
Aug 13, 2009 | Logitech Rumblepad 2 Game Pad
Cannot connect my PDA to PC
Normally for when you connect any device to pc using USB port, windows detects it. Sometime it may take time.
Few initial things you may check....
1) You must have your PDA in ON condition
2) If PDA is not getting connected on port, try connecting to other USB port (assuming that pc normally have more than one USB port)
3) Make sure the cable that you are using between PDA to PC is working properly (normally you can check this by using other cable)
4) If you have intalled some anti virus program on your pc then check the settings of same.
5) last but not least check the settings of window's firewall (part of OS)
If everything of above is fine then either USB ports of pc or of PDA might not be working.
All the best!!
Regards,
Av
Dec 10, 2008 | Computers & Internet
Can't connect my Motorola Rokr E6 to my PC
ur window has infected change ur window and install ur data cable into ur pc.
Feb 14, 2008 | Motorola Mobility ROKR E6 Smartphone
Motorola Phone Tools
Try connecting the phone via USB with the power off & once connected, power on phone. Thanks.
Jul 05, 2007 | Motorola Mobility V365 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
