Question about Canon HV10 HD Camcorder
I have a Canon DV10 - an HD 1080i to miniDV tape camcorder that at one point a couple years ago got "out of adjustment" such that tapes could not be played back. I sent it in for service to Canon and was told the heads were dirty though I had at that point used it very little. It seemed to work fine once back and could be used to playback tapes before and after the "out of adjustment" period. The problem is that I have 3 tapes with data on them which I would very much like to access (kids were at a very cute age) and I know the data is there. I know this since when playing back these tapes the unit shows blue screen only BUT when fast forward is pressed during playback it behaves as it would with any other tape - jittery, fast moving images without sound are seen. I assume this means the camera record speed was slightly off during that period. I have since upgraded to another camera (a Sony) and I'm willing to "experiment" with any recommended adjustments to see if I can rescue these movies. Any help appreciated!
  • Canon Master
  • 5,412 Answers
There are companies who can transfer video files to DVD - see if one of them can help
Posted on Mar 07, 2017
SOURCE: No Picture, sound or anything during playback...
cleaning cassette may help - if the picture comes back but soon goes blue screen ? your heads need thorough cleaning or replacement ;
Posted on Jul 31, 2007
SOURCE: pink or grey horizontal lines on video download or viewing
I have the same issue and have for over a year (haven't had the time to send it to Canon for a few weeks to analyze, but have cleaned it numerous times). But I can tell you that the problem is internittent and the recordings are fine. Eventually, don't know the remedy, but it will suddenly stop doing that and I can download fine, and watch on camera fine. When it does happen, I just keep recording. It never shows up permanently. I re-tyr downloading or viewing and about the 3rd or 3th time (let it sit for a few hours between) it is normal!
Posted on Aug 22, 2008
SOURCE: Canon ZR100 camcorder blue screen playback, tape eject beeping
no video record and blue screen
Posted on Nov 30, 2008
quang123
  • 107 Answers
SOURCE: JVC GR-D33U won't play back some tapes
I still thinking alignment is matter on your CAM and one more thing in your CAM it have the rubber roller it call itself pinch roller if that worm out or defective it can damaged the tape and depend the thickness and branch of those tape it make different resul you can check yours tapes which one is no picture open the lid door and look carrefully any mark deteriorate on the tape
I sugges you to bring it to JVC to check the pinch roller and re-align the tape guide and back tension it delicated and need special instruments and software service it
Posted on Dec 08, 2008
zohail
  • 1223 Answers
SOURCE: During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
Posted on Apr 24, 2009
How to transfer sony dcr-hc26 videos to pc using usb cable thanks
The Sony HDR-HC26 is a miniDV tape based camcorder. No surprises if you can't get USB streaming working.
ALL miniDV tape based camcorders transfer DV-format video by conneting the DV port of the HD camcorder to the Firewire port of your computer. USB won't work. The "DV" in miniDV = Digital Video. It is as digital as the digital video from flash memory or hard disc drive or DVD based camcorders - only better because it is not compressed as much as the others.
Memory cards are not the only way to store digital video - and while not as good as miniDV tape, memory cards are not as bad as DVD based consumer camcorders...
Firewire IEEE1394, DV and i.LINK are all the same thing.
If your computer does not have a firewire port, hopefully it has an available expansion slot (PCI for desktops; PCMCIA or ExpressCard for laptops), so you can add one.
Oct 17, 2010 | Sony DCR-HC26 Mini DV Digital Camcorder
I have a Canon ZR90A and started noticing horizontal gray lines displaying across the screen when it plays back. What is causing this?
The most common cause of horizontal lines during playback is dirty heads/tape path. If you have a head cleaner tape, try playing it for about 5 to 10 seconds and then try your tape again. Repeat as necessary. Try not to run the head cleaner for long periods of time because you may wear down your heads quicker (cleaning cassette is somewhat abrasive). If you do not own a head cleaning tape, I highly recommend purchasing one. Sony (in my opinion) makes the best miniDV head cleaning cassette. We use this brand in our repair shop and they last for years. I have posted a link to the particular tape I am speaking of. Your local camera/camcorder shop may have these for sale.
http://www.amazon.com/Sony-DVM12CLD-MiniDV-Cleaning-Cassette/dp/B0000632H7
Hope this helps you.
www.austintelstarservices.com
Sep 12, 2010 | Canon Video Cameras
I bought a JVC GR-SXM250u Super VHS camcorder a couple days ago and the picture has horizontal lines flashing in and out so I can't see in the display both in pause mode and in record mode. He said he...
you may have a faulty camera there,,,or the vcr tape may be faulty and has spred some of the tape on the recording head try running a cleaning tape through the vcr first to clean the heads,,then use a new tape (not the old tape!) to try that out,, if its cleans the head up throw away the old tape so you never put it back in this vcr
Sep 04, 2010 | JVC GRD250 MiniDV Digital Camcorder
Sony dv premium ME DVM60 Mini DV tape. How many times(hr) to use
Recommend contacting your local service provider directly or online here:
Contact Us
Jul 29, 2017 | Canon Sony DVM-60 Min. miniDV tape - 6Pack...
I recorded a MiniDV with a HD camera the Canon HV30 to be specific. When trying to play it back on my Canon zr950 i get an error message. Will my tape only playback on an HD video camera? What do I do?
Canon ZR950 is an older Standard Definition camera that records in DV format, and does not recognize HDV format recorded by HV30.
HV30 can be switched to DV format, which should be playable on ZR950.
Dec 10, 2009 | Canon VIXIA HV30 DV Camcorder
I have gray lines on my Canon video camera display - on tape and playback. It happens on playback to the TV as well. Other tapes have it on display also. Thoughts?
Its sign of clogged/ dirty video head in your camcorder, put Video Head Cleaning tape in camcorder to clean video heads, problem will be solved.
MiniDV Video Head Cleaning Tape is available in stores.
Thanks.
Dec 04, 2009 | Canon ZR200 Mini DV Digital Camcorder
Sony MiniDV DSR-PD170 won't playback recorded video
the tape path of the camera needs to be adjusted ,so you need to get that fixed.
regards
Aug 04, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
I can record and see it recording but i can not view my recording. At first the tape wouldnt eject but i was online and i went to troubleshoot for the cannon mini dv camcorder zr200 and it told me to tap...
1. Connect the camcorder to a TV and check if you can playsee the tape.
2. Take that tape and check it using another miniDV camcorder.
this way you will know if the issue is within the camcorder or the tape.
If is within the camcorder .. take it to a service dealer and see how much is to fix it. Chances are that is not worth to be fix. A brand new ZR900 is just 200 USD ...
Dec 23, 2008 | Canon ZR200 Mini DV Digital Camcorder
Canon MiniDV mv700i audio problem
A mechanical problem! The tension regulator belt is not well aligned, you need pro fix to do the alignment.
Sep 13, 2007 | Canon MV700 Mini DV Digital Camcorder
Canon HV10 HD Camcorder Logo
91 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
