Question about Fisher and Paykel GWL11 Top Load Washer
Washer will not fill with water and is turning very slow
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now have you removed the inlet hoses from the machine end to check if any water is going to the machine?Turn the taps off 1st before you remove them.What water temp have you selected?Is it hot, cold or warm?Does your machine start beeping and show an error code in lights?Please reply with additional information on the questions and I am sure I can help you.
Posted on Aug 27, 2010
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
Slow filling
Is your water valve fully opened?? Check the water shutoff valve and ensure that it is fully opened. IF it is, then do a simple test by disconnecting the hose from the washer, and get a large bucket, and turn on. If strong flow, then you may have some sort of clogged screen inside the washer (check inside the inlet connection).
Mar 21, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Hot water doesn't turn on to fill the washer
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jan 16, 2011 | Roper RAS6233KQ Top Load Washer
E 10 code what do u do
I'm assuming your washer is a Kenmore or Frigidaire front loading washer. E10 error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
Jan 10, 2011 | Frigidaire ATF6000ES Front Load Washer
Front load GE washer will not fill with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 03, 2010 | GE WSXH208A Front Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Sporatically slow cold water fill (Kenmore Series 80)
Could be you have trapped the hose at the rear of the m/c.
If this is not the case, then I suspect you will need a new cold inlet valve fitting..
Please leave feedback.
Ta.
Dec 09, 2008 | Washing Machines
Hot water is filling up washer very slow
There is a screen in the valve where the hose hooks on. It could be getting plugged up. turn off the water and pull off the hose to see if it's full of particles. I can sometimes clean it out by putting a bucket under the water inlet and spaying a little water from the hose into the opening. If not you may need a new valve.
Apr 18, 2008 | Kenmore 24032\24036 Top Load Washer
Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Jul 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
