Question about Behringer Pmp3000 16 Channel Audio Mixer
I'm using garageband and for some reason it won't record on my computer all the time it has worked previously , but i can't get it to record in the moniter input
  • Behringer Master
  • 5,603 Answers
It is not clear what your configuration is. The monitor OUTPUTS are monaural. For recording you should be using the MAINS OUTPUTS and those NEED to use the the MAIN1 IF you are using TRS balanced lines, else if you record with unbalanced cables you need to use the MAIN2 outputs...
Monitor outputs are intended for stage monitors and vary ONLY with the monitor controls at each channel and the monitor sliders and do NOT vary with the sliders.
Posted on Aug 27, 2010
Why does my mixer take so long to select something from the menu and why does it freeze up?
Sounds like you need more ram or computer space. You didn't list what time of mixer or computer so can only answer basicly. If using a computer (which it sounds like) see how much the mixer needs andhow much space available on your hard drive. This is called a latency problem. Basicaly how long does it take for the computer to respond to commands while it is doing a task. either get a bigger hard drive and more ram or clear out some files on your computer. You can also go into settings and change the settings. You'll have to look through the manual on latency problems.
Nov 22, 2014 | Fostex Mr 8hd CD 8 Track Recorder with CDr
High pitch feedback
you are sending the signal back on itself, hit the usb to main switch to off.
Nov 12, 2013 | Peavey PV6 Mixer
Behringer XENYX 2442 FX: Turntable into CD/tape IN. CD/tape OUT connected to USB device IN. Why is there no signal from mixer to the computer?
If I read correctly, you have outputs on the Behringer (CD/Tape Out) connected to inputs on the Behringer (USB Device In). Is that correct? If so, try going from CD/Tape Out directly to the computer. If not, please explain what the "USB Device In" is.
Thanks,
Rich
Apr 30, 2012 | Music
No sound
no sound well it has to be used w something from garageband reason, etc u cant just plug it in and play it . so for instance garage band , you wanted the grand piano u open the grand piano and start hitting the keys. should be no problem I have the same one
May 14, 2011 | Akai MPK mini MIDI Controller Keyboard,...
How can I save my recorded track in CASIO CTK 810 IN for future use. I can record one performance but cannot save it for ever, if I record another one track the previous one is got deleted. Is there any...
Recording a new tune automatically deletes the previous one.
Solution transfer the recorded song to your computer via USB cable.
It is also possible to store up to 5 additional tunes in the song bank
See page E50 and appendix 9 of the user manual available here. http://support.casio.com/pdf/008/ctk_810_01_e.pdf
Feb 22, 2011 | Casio CTK810 61 Key Keyboard
Have a casio px 320 and trying to use it in GarageBand on my Mac OS X. Connecting USB cable from USB output on Casio to USB input on Mac doesn't work. Any help?
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
Nov 14, 2010 | Casio Privia Keyboard Case
Please teach me how to do a recording of bits with the keyboard PSR S710, it uses a USB drive, but i don't know how to use it
You need to have a basic recording program installed on your computer. If you use Apple you can use garageband. If you use Windows you can install audacity http://sourceforge.net/projects/audacity/
You will have to install the drivers of our yamaha keyboard than connect it with the usb cable to your computer and select the PSR S710 as an input in your recording program.
Mar 10, 2010 | Yamaha Music
Problem with computer recognizing Audio Microphone.
Check if you selected the mic as the default audio input on the respective programs.
Aug 07, 2008 | Samson Audio C01upak C01u Microphone and...
Behringer Pmp3000 16 Channel Audio Mixer Logo
53 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
