Question about Fisher and Paykel DEGX1 Electric Dryer
Dryer drum does not close when starting the dryer
  • 32 Answers
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Posted on Oct 15, 2010
Dryer drum needs several manual pushes to start
or just a bad belt cheap but labor intensive
http://www.youtube.com/watch?v=7OVBi0LcrzQ
Apr 29, 2013 | LG DLE2532W Electric Dryer
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
Maytag Centennial only 18 months old - out of warranty. - When motor engaged drum does not start turning - as if the drum is jammed and motor is whining (attempting to run) - open dryer , rotate...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 14, 2011 | Dryers
Drum will not turn
heatman101
dj
May 22, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Dryer won't start
Try 2 things to see what has happened.
1st listen for a click from the door switch just as the door opens or closes. (No click = no start)
2nd reach in and rotate the drum by hand just a little bit making sure you hear the motor also turn. Then try to restart the dryer.
If rotating the drum enabled you to start the dryer the motor switch is sticking.
Kelly
Feb 25, 2010 | Dryers
Wont start door shut tight can heat timer drum lite on when door open
If you can hear the motor running with door is closed and the dryer is turned on, the the belt that turns the drum is likely off the drum or broken.
If you cannot hear the anything when the door is closed and the dryer is turned on, then the door switch is likely defective.
The other more unlikely causes are either the Timer or Switch that starts the dryer is defective.
Aug 21, 2009 | Kenmore 400 6942 Dryer
Dryer drum will not turn
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch will not activate and the dryer will not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jul 20, 2009 | Dryers
Dryer drum doesn't sart rolling when it is turned on.
It is not using the start winding in the motor. You might be able to remove the end bell and clean the switch?
Apr 24, 2009 | GE DBSR453EBWW Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
101 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
