Question about Bosch AquaStar 2400ES-NG
My water in my shower is hot for 5 minutes then it gets cold for 2 minutes, now i have a ea code flashing.
  • 25 Answers
SOURCE: Keep getting error codes and have to reset too often
This paticular problem your having is specific to the jumper in the heater. The jumper is for condensing heaters. Your heater does not have the specific wiring or computer for condensing. So they added a jumper in the wiring. It is failed or failing. It should ohm out at about 120ohms. sometimes its just a loose connection. Check this out, and called 1-800-642-3111, they have been very busy, but leave them a message and they will call you back.
Posted on Jan 19, 2009
  • 11 Answers
SOURCE: BOSCH AQUASTAR 2400ES NATURAL GAS TANKLESS HOT WATER HEATER
Q. FA - Gas leakage error, gas valve circuit not closing properly
A.
  1. Disconnect power supply cord and check wire connections on gas valve and the two connectors on the control board.
  2. Flow water out of a hot water tap above the minimum activation point of .8GPM. Measure voltage at the gas valve wire connector. The connector should measure 24VDC between the left pair of wires and 24VDC between the right pair of wires when the unit is operating. If voltage is not correct, contact Bosch Water Heating for further instruction.
  3. Gas valve may be defective, contact Bosch Water Heating for further instruction.
Q. EA - No flame ionization detected with water flow
A.
  1. Verify that all manual gas shut off valves are open.
  2. Verify gas type (See Fig. 2 in installation manual) corresponds with the type of gas supplied to the heater.
  3. Reset error code and open a water tap to cycle the heater in an effort to purge air from gas line (especially on new installations). Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater.
  4. Verify the three yellow wire connections to the set of electrodes (underside of the burner assembly) are secure.
  5. Verify gas pressure meets specifications outlined in chapter 3.8. See Bulletin TWH-G2-03.
  6. Verify venting meets specifications outlined in chapter 3.6 of the installation manual. Improper venting may cause premature failure of the flame sensor rod.
  7. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If not, Call Bosch Water Heating with observations. Readings from above gas pressure test will be required.
Q. C1 - Fan rotation too low on startup
A.
  1. Disconnect power supply cord. Check wire connections on back side of fan and the two large wire connectors on the control unit. Removal of lower access panel on control unit is necessary to access connectors.
  2. Verify that supply voltage is 120VAC and is properly grounded.
  3. Verify that venting meets specifications outlined in chapter 3.6 of the installation manual. Long vent lengths, venting with more than three elbows, blocked vent or combination venting may cause this failure. Verify backdraft flapper inside flue gas collector is not stuck shut.
  4. Check gas pressure. See Bulletin TWH-G2-03. Low gas pressure may cause the fan to change its speed to meet desired temperature.
  5. Possible defective control unit. Call Bosch Water Heating for further instructions.
Posted on Mar 15, 2009
  • 6 Answers
SOURCE: hot water problem
Someone has not sized the system correctly. The water heater will heat a certain GPM a certain temperature rise. Most of those "generalizations" from the manufacturers are referencing the lowest of all the flow requirements like 2 lavatories. The truth is, don't use other fixtures while showering or get a bigger system. Lots of information related to sizing the tankless system at http://www.mechanicalengineeronline.com/Mini_Sites/Tankless_Water_Heaters_Ebook/Tankless_Water_Heaters.htm Have a good one. PS:Properly sized On-Demand water heaters are actually really good. Be prepared for the day your water heater quits.
Posted on Jun 10, 2009
  • 82 Answers
SOURCE: Bosch AquaStar 125b ng suddenly goes cold during shower
Does it happen to any other fixture? If not, it's most likely your shower valve and not heater.
Posted on Sep 04, 2009
SOURCE: water runs hot then cold then hot during showers
YOU MAY HAVE TO DESCALE YOUR UNIT I have this problem along with a bunch of error codes. Please don"t call the Bosch 888 number. They want to speak to a tech. In addition, their off during the weekend. Tankless water heaters are great when thier working. Mine is not.
Posted on Jan 25, 2010
Rheem warrior 40 gal warrior
You could start by seeing if the thermostat is wide open. Sounds like it is on low or vacay mode. How far is the run between your heater and the bathing area. Might need to insualet some piping.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 24, 2013 | Water Heaters
Shower goes cold intermittently like there is a restriction in hot water delivery. Plenty of hot water when it comes back, but the cold blast is not fun. No shortage of hot water for long showers or...
Has nothing to do with the expansion tank, the expansion tank whole enough air so that when the heater heats the water it does not build up pressure. You know from school that you can compress ait. you CAN NOT compress water. When you haet water it expands until it turns to steam. So lets rule that out.
First look at all the plumbing in the house where there is a cross conection. This would be like a shower valve that has a personal shower head on it. and you turn of the water using the personal shower handle and not the valve at the wall. This then would let cold water to go into the hot water side piping.
Most people do that with out knowing it at the laundry sink. they put a hose on to was the dog and forget to turn off the faucet and then BANG cold water in the hot side.
Go around the house and turn off all the faucets and valves by using the handles. no add on things.
Now last could be the shower valve itself. . Do this happen in just one shower or all of them???
If its just the one and you spend the day doing the walk around, even check the bidet if you have one
its the valve. you need repair to that.
Best of luck in your hunt Tom
Sep 08, 2011 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
My rinnai heater keeps my water running hot and cold, hot and cold and I can't have a decent shower! How do I stop it from doing that?
if it has been constant from instalation it might be that ur shower head is rated too low to get enogh gpm ( gallons per minute) it will tell u most of the time around the shower head where it threads onto the spot of the wall what the gpm is. alot of the energy saver heads are restricting tehgpm to 1.5 or .5 gpms to conserve water well the water heater will only operate correctally around .5 gpm depending on model so if u are not pulling enough water u will not turn the water heater on to get ur hot water all the time so go to lowes ( or locally trusted hardware) and get a new shower head make shure u look for the gpm on teh head and check in ur owners manual to see what gpm ur water heater kicks on
P.S. if ur shower head is rated at higher gpm say 1.5 and it is corroded or pluged up say with lime it is going to restrict it causing a lower gpm
Jan 13, 2011 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
I have a 40 gal Whirlpool single element 3500 mobile home hot water heater. I have replaced the element thermostat high pressure valve (because it was leaking) & flushed for sediment. In morning I wash...
A 40 gal. electric water heater will give you aprox. 32 gal. of hot water in one setting, since they do not reheat as quickly as gas. So if you are using a newer 1.5 or 2.0 gpm shower head. You could take a 16 minute shower with straight hot water. If you are running 2 new shower heads at once you could get 8 minutes. If you using the tub spout the times decrease. Some of my customers like to turn up the temerature on the thermostat a little so they can mix more cold and get it to last a little longer. Be very careful doing this.
If your water heater has a lot of calcium built up in it the times will decrease.
With out seeing the heater, you mention it is a mobile home heater so I am guessing that it is bottom fed.
I hope this has helped.
May 09, 2010 | Water Heaters
Rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Sep 13, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
I purchased a whirlpool 40 gallon hot water heater model #BFG1J4040T3NOV in November of '08. since its been installed i been having a problem with the water staying hot for more than 1 shower. After about...
Will the water stay hot in the kitchen sink? Try to isolate the problem. If it is happening at all hot water locations, then it will be related to your water heater. If just in the shower then it is related to the mix of water ratio coming out of the shower hear. If its only the shower, then you are getting too much cold and not enough hot through the pipes. This can be very simple to fix by replacing the handle going to the shower. If this does not work then you may have a problem in the hot water pipes. After you isolate the problem, please post another question here.
Apr 16, 2009 | General Electric GE SmartWater Household...
Hot water is cutting out after 2 - 3 minutes whilst showering
check the screen on the cold water intake on the cold side,, you might have to flush the system out, and do you have the shower head water restricter in, if not you may be using to much hot water,,, how many other hot water fixtures are running at the same time? try running just the shower,,,if this is a tank water heater the dip tube could be bad that is on the cold side it takes the cold water to the bottom of the tank and forces the hot water out,, if you ar only getting a couple of min of hot water and the dip tube is bad it is not going to the bottom but just at the top and not getting all the hot water you will need a plumber
Mar 21, 2009 | Water Heaters
Grohe Thermostatic Valve
the temp, control valve is getting to hot!!! there for only let so much hot water go thru, did you take the inner parts out when soldering this in, if not you might have damaged it, and if so need to replace the cartdrige
Feb 10, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Running out of hot water after 5 minutes or so in the shower.
I think the dip tube in your water heater has failed, this is a plastic tube that goes in the cold side of your tank and forces incoming cold water to the bottom of the tank allowing hot water out at the top. When this tube deteiorates the incoming cold water mixes at the top of the tank causing the problem you have. the dip tube runs about 5 bucks but takes someone with pluming skills to install.
Dec 31, 2008 | Water Heaters
Bosch AquaStar 2400ES-NG  Logo
24 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
