Question about Motorola Mobility RAZR V3
Water damage Baby was licking the phone and it was wet when i found it,but working.Turned it off, and on after few hours. Screen works, asks for unlock code, but when i type it VOLUME CONTROL appears instead of 4 digits.Any bottom i press, shows the same - volume! What to do?
  • Anonymous Aug 11, 2008
    water damage to phone, blow dried it out. it does come on but the keys do not work. Any advice?
PUT IN ALCHOL 5 MINUTE AND THAN DRY 6 HOURES
Posted on Aug 11, 2008
  • 975 Answers
OK, before have it serviced , open the back and use a hair blower and point directly to the phone but not too close , for about 30 or 40 secs. hope this helps AJ
Posted on May 07, 2008
Touch screen has stopped working and phone sometimes locks up :(
That happened to me and my htc touch hd the other day. I tuned it off, pulled the battery out and let it dry out completely. The touch screen didn't work until a few hours later. However when water happens to an electronic device it usually will need to be replaced. Just cross your fingers and hope for the best.
Mar 28, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
How do i reboot a moterola K1 phone i got it wet but the phone works but screen is white
Water is deadly to cell phones (except for a few models made to be waterproof.). Usually they won't work at all after they have water damage. And usually water damage is considered to be the user's fault, so it is not covered under warranties or insurance ---but you can check with your provider. I doubt that you will get the screen to work. However, it is possible that you can have a retail location retrieve your phone book (depends on the damage level) to transfer to a new phone. If you have backup assistance that won't be necessary.
Sep 14, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Wett
Hate to tell you this, but you are probably in trouble at this point. A wet phone will usually short-circuit someplace. The advice is to take the battery out as soon as you see that it got wet, wait THREE DAYS, then try it. By powering up, you might've harmed the circuitry. But, you could try taking the battery out and waiting a few days before turning on again.
Jul 25, 2009 | LG Dare VX9700 Cell Phone
Can't use keypad, only the on/off button works
If your baby got a hold of it, it's likely there is water damage.
Check your battery. Most of the batteries have a sticker. depending on the brand it will be red or smudgy purple or something else if it was wet - no way to tell if i dont know what brand you have.
you can go to your local store and get them to plug in their cell brite and download the numbers to a new phone. If the phone will stay on for a few minutes and is on the home screen, they will be able to do this.
Jul 23, 2009 | Motorola Mobility RAZR V3
MY Instinct (SPH-m800)GOT A LITTLE WET
the phone circuit is affected by the moisture in the babywipes.. yu must service yur mobile in a samsung service centre to get it back working.
Jul 05, 2009 | Samsung Instinct SPH-M800 Cell Phone Car...
I have the same problem!!!! I just dropped mine 2 hours ago!!
http://www.fixya.com/support/r3771170-phone_water_damage
Jun 04, 2009 | LG Vu CU920 Cellular Phone
Got Wet = Blank Screen
I helped a friend with a similar problem using the solution below, so I am sure it will work unless your phone has shorted out:
  • Remove the battery from the phone immediately -- preferably right after it had gotten wet.
  • Spray the phone liberally through the keypad and inside the battery compartment with a good brand of electronic cleaner such as "CRC QD Electronic Cleaner Quick Drying Formula". It is important for the cleaner to get into the phone to wash out any water and mineral residues as they can cause a short when you put the batteries back into the phone.
  • Allow it to drain and dry, or better, blow dry it with hairdryer set on cold, or turn upside down on your dashboard for a few hours. Do NOT put the batteries back in the phone while it is drying.
  • When your phone is completely dry, put battery back in and turn it on. If it does not come on, put it on the charger. You should see the indicator come on showing "Charging".
  • After a few minutes to a half an hour, try turning your phone on. It should work if nothing has shorted.
Nov 22, 2008 | Nokia N95 Cellular Phone
Water damage and no signal
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Nov 17, 2008 | LG VOYAGER VX10000 Cellular Phone
My enV
no the same thing is happening with my sister's phone. she dropped her's in a puddle and a toilet and now it wont charge and her screen turned red/orange. you can try airing your phone out but that may not work. the env is a horrible phone. i had four or five of them, get a different phone as soona as you can!!
Oct 23, 2008 | LG enV VX9900 Cellular Phone
Water damage
The phone is most likely done for, but if you have a torx5 driver you can take the upper assembly apart and clean up and reseat the side keys. What's going on is that the side key for some reason is staying pressed which makes all other keys inoperable.
Aug 11, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
24 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
